The CRF1000L Africa Twin problem thread
Discussion in 'Japanese polycylindered adventure bikes' started by twinrider, Mar 18, 2016.
  1. ArcticTwin
    ArcticTwin Adventurer
    May 31, 2016
    59
    Tromso, Norway
    Thanks for the input. I will be taking my time going through all cables, check for damaged insulation and bad connections.
  2. SkipD
    SkipD That looks stickey
    Aug 19, 2010
    513
    Gold Coast
    The only time I have seen anything out of spec is at the first valve check always the no2 exhaust valve on cylinder 1 is slightly bigger gap than spec. Never seen an inlet valve out of spec. I have seen ALL the exhaust valves adjusted to the inlet valve spec by a Honda dealer and 24,000 km later I adjusted them all back and there were no issues with bike.
    swimmer likes this.
  3. RBMann
    RBMann Been here awhile
    Aug 17, 2006
    314
    North of Seattle
    Can you shed some light on which wires might need to be checked?
  4. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    5,594
    Upper Michigan
    It was back in 2017 I read it somewhere here and tied them down.I think it was on left side up by radiator under tank if I remember right.Have really just run the hell out of bike since then with just basic maintenance.I am not even going to admit how much I am over on the valve check but it should have been done 2 years ago.
  5. Yooper_Bob
    Yooper_Bob Insert witty saying here....
    Aug 31, 2005
    5,270
    Da UP, eh! (Marquette, MI)
    How many miles are you at?
    I'm closing in on 30K. :shog
  6. Junglejeff1
    Oct 20, 2016
    5,594
    Upper Michigan
    24k, Guess I will check valves this winter.
  7. SkipD
    Aug 19, 2010
    513
    Gold Coast
    The loom that goes over the left hand radiator had not been cable tied correctly and was sitting on the radiator and not the little plastic stand off that it was meant to be on. This mean that the wires could rub through with contact on the hot radiator. You had to loosen the cable tie down further (required the back of the tank to be lifted) towards back of the bike about 100mm (4 inches) then lift the wiring loom up about 20mm onto the plastic support on the radiator and re tie the 2-3 locations. If you look in by the outside edge of the left radiator you will see the loom either sitting on the plastic support (good) or pulled tight accross the edge of the radiator (bad).
  8. docgonzo
    docgonzo Old Gadfly
    Mar 1, 2002
    21,668
    within 20 miles of the Center of the Universe
    2016 Africa Twin DCT at 50,000 miles!
    Only problem I've had is that the stepper motor ratio controller wore out at 40,000 miles. Symptom? Bike would stick in gear.
    I believe that the Honda engineers considered this a wear item, because they made it readily accessible on the left side of the motor. $205 dollar part and about 15 minute's work. My dealer installed it for free it was so simple. I've now gotten another trouble-free 10,000 miles out of it so far.
    Here's what it looks like (yes, I originally thought it was a filter!):
    The part is Honda OEM 31 300-MJP-G81 and the gasket that goes with it is 91301-MJP-G81
    So, if your DCT starts to get stuck in 5th gear when hot, this needs to be replaced. For $205!
    Flying Marmot, Honda-50 and Todd157k like this.
  9. Nomadic_adv
    Nomadic_adv Been here awhile
    Oct 31, 2019
    234
    N GA
    Sounds like the horn wires in the loom on left radiator is what you're talking about.
    Strange the issues didn't manifest until after the battery replacement. With the replacement battery, the first part sounds like a low / bad battery. Check the battery terminals and threaded inserts in the posts to make sure everything is seated properly and tight. Check - pull and look at all the fuses before. Disconnect or remove any added electrical accessories. Hopefully no reverse polarity occurred when jumping/charging and your test meter is good.
  10. carlrf
    carlrf Been here awhile
    Apr 3, 2004
    393
    Grand Junction Colorado
    Just wanted to follow up. Replaced the water pump and no issues since. However I don't think I have really simulated the conditions of when it gets noisy.
    swimmer likes this.
  11. gve.mcmlxxiv
    gve.mcmlxxiv 2016 Africa Twin DCT No.272
    Sep 5, 2017
    468
    Arkansas
    maybe a problem without a symptom isn't a problem.
  12. carlrf
    Apr 3, 2004
    393
    Another follow up;
    I decided to let the shop I work for part time to have a shot at it. To make a long story short, they found and corrected an issue with a balancer bearing.
    swimmer likes this.
  13. canyncarvr
    canyncarvr Been here awhile
    Apr 7, 2005
    163
    Name that noise!
    My AT has always done it. I've heard the same noise in other ATs. It occurs immediately after a start. There is a small 'chirp' that might be (seems to be) coming from the right/front area of the engine.
    It's not a problem, nothing I'm worried about. I'm just curious what the bike is chirping about. Some kind of sensor reset maybe...although I don't know what sensor would be resetting at that time.
    Anyone know or maybe just have a good idea about it?
  14. RustySpokes
    RustySpokes Ordinary average guy
    May 13, 2004
    2,149
    Between here and there.
    Maybe the the starter clutch.
    Junglejeff1 likes this.
  15. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    19,981
    Tucson, AZ
    Is the noise associated with an engine stumble or misfire type condition?
  16. bbanker
    bbanker Been here awhile Supporter
    Feb 24, 2011
    601
    Beautiful NC
    Mine does it sometimes. I don't worry about it.
    simmons1 and carlrf like this.
  17. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    3,810
    Ventura, CA
    The great thing about little noises you can't figure out... they will get louder and let you know what's happening.. eventually. :deal
    simmons1, LouisPK and windowto like this.
  18. Flying Marmot
    Flying Marmot Been here awhile
    Jan 23, 2016
    107
    Norcal
    This is a fantastic bit of advice and I’ll get mine changed ASAP. It crapped out on a notorious piece of steep road in the middle of nowhere. I figured I could free my gears by rolling the bike back and forth then turning it on. Gears work again but the hesitation in shifts and slipping of the clutches is appearing again. So no I know. My AT DCT is not bomb proof and had this happened on the freeway….
