The CRF250L Owners thread
Discussion in 'Thumpers' started by joec63, Sep 4, 2012.
  1. Sidewaysxr
    Sidewaysxr Ass, gas, or grass nobody rides free.
    Feb 22, 2014
    51
    Rocky Mountains
    It is the Tusk brand from Rocky Mountain ATVMC. It is already installed and didn’t weigh the difference but it seems significantly lighter.
  2. Sidewaysxr
    Feb 22, 2014
    51
    Rocky Mountains
  3. Lee Dodge
    Lee Dodge Been here awhile Supporter
    Aug 9, 2002
    645
    Horicon, WI. By da marsh.
    Has anybody with an ABS bike fitted supermoto wheels with ABS rings. Did the ABS work correctly afterwords or did it throw a code?
    OU812 likes this.
  4. SloRonStinkypants
    SloRonStinkypants Without nipples Tits are pointless.
    Jul 10, 2013
    5,154
    Berlin/OceanCity MD
    My 16yo's bike while we were on a trip in pa..
    He is an interactive media student at our county's tech school..
    He did a pretty good job on this project..
    StanBo, td63, OU812 and 4 others like this.
  5. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    8,926
    ADVmonster, CFL, WNC
    OU812 likes this.
  6. SloRonStinkypants
    Jul 10, 2013
    5,154
    Berlin/OceanCity MD
    Put a slim set of leds on the 250l today..
    20191117_112138.jpg 20191117_112148.jpg 20191117_112144.jpg 20191117_112152.jpg 20191117_112156.jpg
    td63, washout800 and OU812 like this.
  7. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,784
    Wicklow Ireland
    OU812 likes this.
  8. SloRonStinkypants
    Jul 10, 2013
    5,154
    Berlin/OceanCity MD
    Swamp!
    I'm far from any desert...
    OU812 and Griff2 like this.
  9. DangerousDan
    DangerousDan Danger Dan
    Oct 15, 2017
    119
    Las Vegas, NV
    So I've been trying to help a buddy install LED turn signals on his 2017 CRF250L. The short version goes like this: after a lot of dicking around trying to make things work, the rear turn signals do not work at all when we have the front LED signals connected. If we connect a non-LED front turn signal, the rears work as well. But despite our best efforts, nothing works if we try to make both the front and rear LED.
    Is this an issue that would be solved by an Fixed Rate Turn Signal Flasher or a LED 12V Signal Flasher? What's the difference between these two cookies as far as functionality goes?
    OU812 likes this.
  10. OU812
    OU812 Legend in my own Mind! Supporter
    Sep 18, 2006
    22,676
    Sleepy Hollow IL
    I had one in my road bike years ago and when they tell you to use the filler foam blocks to shim the battery box whatever you do put the foam blocks on the battery that way if you're stuck someplace and you need to put a stock battery in you don't have to yank the foam outa the box.
    2thdrinOR likes this.
  11. breakm
    breakm Been here awhile
    Dec 9, 2015
    347
    Croatia
    Yes, you need LED specific flasher that is the same as fixed rate flasher. Regular stock OEM flasher interval depends on electric current load, more current more slower rate, less current faster rate. Might have just happened that your LED turn signals now take so little current that they dont even trip the old relay, and if they did it would flash too fast anyhow. Get a LED relay that fits crfl connector.
  12. minkyhead
    minkyhead Long timer
    Jan 4, 2007
    1,448
    uk gods county
    If your just doin the front blinkers. And not the rear. Look for in line resistors. Google them. Pleaty of videos to help
  13. Sidewaysxr
    Feb 22, 2014
    51
    Rocky Mountains
    If interested - Costco has a charger/maintainer for lithium batteries on sale right now. It is $12 off so it ends up about $38.
  14. WalterMitty2
    WalterMitty2 Been here awhile
    Sep 11, 2019
    281
    Chicagoland Area
    I just bought this one not too long ago....
    Sidewaysxr likes this.
  15. minkyhead
    Jan 4, 2007
    1,448
    uk gods county
    anyone spot summet new in this picture ??:D
    [​IMG]aaa by minkyhead56, on Flickr
  16. michaelkozera
    michaelkozera Long timer
    Jan 11, 2015
    1,434
    calgary
    yeah, the white bird shit on the left fork leg guard. disgusting.
    OU812 likes this.
  17. kebrider
    kebrider Been here awhile
    Mar 19, 2011
    200
    Knoxville
    Floating rotor?
    OU812 likes this.
  18. minkyhead
    Jan 4, 2007
    1,448
    uk gods county
    :hmmmmm:doh
    [​IMG]bbbbb by minkyhead56, on Flickr
    OU812 and michaelkozera like this.
  19. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,784
    Wicklow Ireland
    Bigger tank, black motor
    sanjoh and OU812 like this.
  20. SAPB
    SAPB Long timer
    Sep 27, 2012
    2,322
    Rhode Island
    Not sure what that is on the top of the left fork, some adjustment function?
    OU812 likes this.
