The CRF250L Owners thread
Discussion in 'Thumpers' started by joec63, Sep 4, 2012.
  1. Sideroadrod
    Sideroadrod Been here awhile
    Jan 20, 2018
    208
    Kars Ontario
    Great picks man!
    Thanks for sharing.
    SRR
  2. 301
    301 Fully Auto
    Feb 8, 2008
    26
    Tampa, Fl
    The 2017 L garage find first oil change and subsequent ride. 8AAE5D5C-B048-4D51-A314-03635C5474E3.jpeg BCFA4637-39CD-49D2-B6DA-754138396F26.jpeg
  3. slattmattery
    slattmattery Adventurer
    Jun 12, 2008
    18
    My headlight stopped working after riding the other day.
    Fuses are good, battery is at 12.7 volts, <1 ohms resistance across at the bulb (low and high). What's odd is that with the key turned on and dimmer switch on low, both the high beam and low beam circuits have 12 volts at the headlight plug. When the dimmer switch is set to high, both circuits drop to 0 volts. When plugged in, the headlight doesn't turn on regardless of dimmer switch position. Any ideas?
  4. breakm
    breakm Been here awhile
    Dec 9, 2015
    454
    Croatia
    Didn't understand fully, seems like it doesnt work at all bike running or not doesnt matter?
    Below starter push button on the right side, just below it there is a little weep hole. Take WD40 and spray a bunch in that hole and beneath the button itself. Then press it about 20 times (key off of course). Wait for half hour for WD40 to drain and give the headlight a try.
    If that doesn't fix it report back maybe I can give some other advice, but that is the usual cause.
  5. slattmattery
    Jun 12, 2008
    18
    Edit: Doh! Opened the headlight plug housing and realized I was measuring the wrong wires. The dimmer works as expected now. I think I’ve narrowed it down to the headlight bulb, even though it appears fine. We’ll see!
    Correct, the headlight doesn’t turn on in any condition when plugged into the bike. Just flushed the starter button drainage hole with WD40 anyway. No change.
    I think the starter circuit is operating correctly, because when I thumb the starter the voltage at the headlight plug goes to zero, then comes back up. Just flushed it with
    What’s hanging me up is the way that the high and low circuits have 12V simultaneously with the dimmer set to low, and they both go to 0V when it’s set to high (measured at the headlight plug). I’d think that this would cause the high and low beams to both be on at the same time, but instead the headlight doesn’t turn on at all? I just pulled the switch and cleaned it — everything seems fine.
  6. breakm
    Dec 9, 2015
    454
    Croatia
    So white and blue wires to the plug, that is the plug itself, measures 12V on both positives when measured against the green. When in low position on dimmer both high and low (white and blue) wires have 12V? But the blue high beam light on the dash either doesn't light up at all or just slight dim light possibly. And the starter button works correctly.
    If the dimmer switch is good, then there is no way that both high and low (white and blue wires) have 12V except if you have a disconnection of ground probably inside the bulb someplace, then 12V travels from "low" filament not to ground as its disconnected but through "high" filament to dash and other places basically floating.
    If the dimmer switch would have been bad, either one of them wouldnt have 12V ever, or they would both be on.
    edit: after the "high" on dimmer switch its basically "Y" connection, so from dimmer switch to both the bulb itself and dash indicator also. And the headlight bulb is also a "Y" connection, ground (negative) is common, connected together, and 2 positives, that is why when you dont have ground line anymore, it goes through the other positive one, back to dimmer switch open contact, and to dashboard.
    So check the plug for ground wire continuity, and since that will probably be fine, its ground connection (negative) fault inside the bulb someplace.
  7. slattmattery
    Jun 12, 2008
    18
    Thanks for the help! It ended up being a combination of a faulty starter button and my incorrect measurements at the plug. Sprayed some WD40 into the drainage hole of the starter button housing and the problem is mostly resolved. Thanks again.
    breakm likes this.
  8. WalterMitty2
    WalterMitty2 Been here awhile
    Sep 11, 2019
    655
    Chicagoland Area
    Not many pics of the 250L were taken, but she made it into a few. Below are some pics and a short video of the Saturday ride.
    breakm, Motonirvana and Skellington like this.
  9. breakm
    Dec 9, 2015
    454
    Croatia
    After all it is the usual cause. Factory greases the 2 sliding contacts of the starter push button, but they also have drain hole, over time dust gets in through it and next to the button itself, collects on the grease, eventually makes it less conductive and bit burnt. I have disassembled and cleaned mine the first time, that lasted less then the next time when I just put a bunch of WD40 :D . Also best not to use electrical contact cleaner as that leaves everything bone dry, that is best for connectors.
    Duck926 likes this.
  10. Samanjo
    Samanjo Long timer
    Jan 2, 2016
    1,423
    South Africa
    Explored some new roads yesterday
    lrgart and Skellington like this.
  11. breakm
    Dec 9, 2015
    454
    Croatia
    Some exploration from last weekend, TW302 at the back does surprisingly good for hills when its down to 1.2-1.3 bar / 17-19psi, too strong sidewall for any more pressure for dual sport 50-50 use.
    Skellington likes this.
  12. GaryP
    GaryP n00b
    Oct 19, 2012
    2
    NH
    Nice. Friend has a 2018 250L Rally with similar mileage for sale that I may purchase this week.
  13. cbc
    cbc Adventurer
    Sep 29, 2017
    75
    Chile
    A few weeks ago I posted my initial experience with a few mods I had done.
    After using the bike foe the last few weeks I wanted to report what I felt about these mods.
    I am really happy with the way the bike rides now. The suspension is finally not crappy ( I’m am a big guy) much more planted and eats up bumps much more smoothly and firm. I like the new bars and pro grips for the road (I am driving on country backroads)
    On the dirt the pro grips though super comfortable sacrifice feel ( coming from ODI which are quite thin) as well as the wider bars compared to the stock bars. Stock was more nimble and responsive. I like it though and since I’m not really dirt bike riding the CRF
    I am happy. cheeers
  14. Suzy America
    Suzy America Adventurer
    Mar 25, 2018
    83
    Portland Oregon USA
    Hey folks :) Just now finding this thread. Usually I stay in the regional forums and nowhere else.
    This summer my 2015L did wonderful duty as an adventure bike. It more than earned its space in the shed. Many mods. Fully replaced suspension. Bigger exhaust + EJK + widened snorkels. Next I'm trying to fab better luggage racks.
  15. Suzy America
    Mar 25, 2018
    83
    Portland Oregon USA
    Adding to the post above .. this summer I took up more-lightweight dual sport camping instead of riding the big pavement princess everywhere. The L got me into little places that would have kept the big bike out. Used a big camo rain fly to cover both the tent and the bike together. Provides a little covered space right outside the front door. Found lots of free camping :)
  16. Swamper
    Swamper Been Nowhere Done Nothing
    Aug 24, 2003
    1,310
    Nor-Cal, Nevada City
    1970 top case!
    Motonirvana likes this.
  17. Sideroadrod
    Jan 20, 2018
    208
    Kars Ontario
    I think he stole that top case off of my old KLR! LOL
    SRR
    KYMike likes this.
  18. WalterMitty2
    Sep 11, 2019
    655
    Chicagoland Area
    She
  19. Blackshirt
    Blackshirt Long timer
    Mar 20, 2011
    1,194
    Waldheim, Louisiana
    As an old Italian bike guy, I’ve found that an occasional spritz of an aerosol product called Deoxit on switches and relay contacts keeps everything working just right. It also works to clean lock sets.
  20. Sideroadrod
    Jan 20, 2018
    208
    Kars Ontario
    :hmmmmmOhhhh I see now. My bad homie !
    SRR
