The darkside, car tire on motorcycles
Discussion in 'The Perfect Line and Other Riding Myths' started by elkgrichard, Sep 19, 2014.
  1. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,273
    Ah, thanks.
    The BMW Mini weighs in at about 2700 lbs. Per tire, that's about 675 pounds. That's not outside the range of many a motorcycle tire.
    Can't read the sidewalls of the particular tires there on that Mini in the picture. They may well be adequate for the weight load.
    Jabcon2 likes this.
  2. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,879
    Hiding off Hwy 6, B.C.
    Sh(r)inko Verge 011?
  3. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,683
    NW of Philly, Hoboken, Brooklyn.
    Wow, Sarcasm; that's original!
    Hey, it's your life, choose your equipment according to how long you want to live; don't let anyone tell you otherwise.
  4. BetterLateThanNever
    BetterLateThanNever It turns out you can't delete your account...
    Dec 31, 2014
    2,537
    Ontario, Canada
    Doubling down, huh? I'm feeling benevolent this morning, so I'll explain this to you in short sentences. This thread is a ridiculous argument between people who use car tires on their motorcycles and people who don't. Those who use car tires have frequently say to their opponents that theory is just theory, and they have no right to criticize using car tires if they haven't tried it. It is to this rather weak defense I was referring in my humorous post above.
    The "equipment" I "choose" is motorcycle tires, FYI. Thus, sarcasm.
    Okey doke?
  5. foxtrapper
    Sep 6, 2011
    4,273
  6. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,683
    Humorous to you.. yet you fail to detect the sarcasm in:
    With a big smiley face.
  7. foxtrapper
    Sep 6, 2011
    4,273
    Huh.
    My 52 MG TD has 4" wide 15" wheels, and takes a 5.5x15 tubed tire. To say there's nothing exciting in the automotive tire world for it is an understatement.
    But, looking at comparable sized motorcycle tires, there's plenty there with more performance. I can even get white walls!
    Maybe this spring, if I do change tires, I might put motorcycle tires on it just to see. From the very little I've found by people who have to put motorcycle tires on their cars, for various reasons, they've found it to work well enough.
    CROSSBOLT likes this.
  8. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    15,183
    the hills
    Coker tires for the MG. :D
  9. BetterLateThanNever
    Dec 31, 2014
    2,537
    Ontario, Canada
    It has been a unique feature of this thread that even people who agree on the substance will still turn on each other for the sheer pleasure of being shitty...
  10. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,683
    Hardly unique in this forum or internet as a whole, you should surf more.
    BTW that's Sarcasm, in case you didn't get it.
  11. BetterLateThanNever
    Dec 31, 2014
    2,537
    Ontario, Canada
    Car tires are spec'd for GVW, which means the weight of the car plus whatever passenger and luggage load it's meant to carry. Our MINI's tires are rated for 545kg, which is just over 1200lbs.
  12. BetterLateThanNever
    Dec 31, 2014
    2,537
    Ontario, Canada
    STILL at it? What a tragic life you have.
  13. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,683
    I can do this all day long.. go for a ride on my darkside scoot, with my tragic life.. and you?:lol2:lol2:lol2
    kwthom, anotherguy and CROSSBOLT like this.
  14. glory racing
    glory racing Been here awhile
    Aug 23, 2013
    482
    harrison, AR
    After reading this thread for over an hour I am still confused. Is it now considered acceptable to run a car tire on a bike?
  15. liberpolly
    liberpolly Nu, shoyn, nudnick!
    Sep 21, 2015
    5,869
    Seattle
    Depends.
  16. neanderthal
    neanderthal globeriding wannabe
    Nov 26, 2006
    4,889
    Here, but lost. Am I lost if i know i'm here?
    Don't forget that weight is not static in a vehicle. Accelerate and weight transfer occurs, loading up the rear tires. Brake hard and it is the opposite; front tires get loaded. Turn hard to the right and your left tires get loaded.
    So, even if MC tires are used in a MINI and their static weight capacity is greater than the MINI's GVWR, they may actually be inadequate for the vehicle.
  17. neanderthal
    Nov 26, 2006
    4,889
    Wrong. Quite a few of us DON'T equip our bikes with car tires, but are still in favor/ agreement with those doing so.
  18. glory racing
    Aug 23, 2013
    482
    harrison, AR
    Seems to me it either has been safely tested and done many times and considered an option...or it has not.
  19. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,683
    Motorcycling is a dangerous activity, how much risk you want to take it is up to you, what kind of tires you want to you is up to you.
    You decide for yourself whether your riding renders the need for a car tire.
    Others may give you grief about what equipment you use when you ride; but they are not doing the same riding as you.
    If you want advise on car tire usage; specify your needs and maybe you will get better replies.
    FTL900 likes this.
  20. gen1fizzy
    gen1fizzy Been here awhile
    Dec 30, 2018
    180
    North Carolina
    The profile of a car tire is not rounded because they aren't designed for a vehicle that leans in a turn.
    Motorcycle tires are designed specifically for leaning.
    I have not tried this and will not be trying it because when I lean into a turn, I want to know the road contact of my tires isn't decreasing.
