The darkside, car tire on motorcycles
Discussion in 'The Perfect Line and Other Riding Myths' started by elkgrichard, Sep 19, 2014.
  1. windmill
    windmill Long timer
    Feb 18, 2008
    6,559
    Kent, Washington State
    Interesting,
    I've used dual position motorcycle tires, Sidecar specific car profile tires, and car tires on my Ural, and have never seen any if them marked for more than one direction for rotation. I've also never had anyone recommend mounting a tire reversed on the front of a vehicle except for AWD tractors, and construction equipment.
    Perhaps with the asymmetrical tread pattern of contemporary motorcycle tires its worth considering. All that I've used on my Ural were classic patterns that are symmetrical, and present the same pattern in either direction. I think in the OPs situation of using a car tire on the front, I would stick with the manufacturers recommended rotation.
    phughes likes this.
  2. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,747
    A bazillion years ago, a motorcycle magazine did a nice article about running a rear tire up front. Even got specific instructions on it from two manufacturers. Who explained exactly opposite reasons to each other. One saying reverse rotation, the other saying not to. All having to do with water ejection.
    The tire carcass couldn’t care less, as far as I know. There is some thought still that a radial carcass, after extended use in one direction, should not be reversed. Be it in simple rotation or applied forces. But that’s long been shown to actually not be an issue. The plies simply don’t delaminate from this.
    Personally, I want the tread V, if there is one, to enter the water on the road center first, splaying outwards as the tire rotated. Every water plate study I’ve seen of tires and how they work with water shows this to work better than reversing the contact.
    As for a car tire up front, that was common for a lot of decades. It works. Nuns and kittens survived. With a trike, I think you’ve a very valid reason to give it a try. The tire forces would be very car like. If you do try a car tire up front, I hope you post back on what you found.
    Treadless likes this.
  3. tom c
    tom c Teflon Tommy Supporter
    May 21, 2012
    8,680
    Delaware
    Pretty sure this guy has run through a few car tires..... :)
    Davidprej and Cat0020 like this.
  4. glory racing
    glory racing Been here awhile
    Aug 23, 2013
    673
    harrison, AR
    He needs one up front now too.
  5. Davidprej
    Davidprej Davidprej Supporter
    Dec 27, 2012
    981
    Lafayette, LA
    Lesson - Hoarding and motorcycling don't mix?
    Steve_h1963 and gateman like this.
  6. Lapchik
    Lapchik Tinkeritis posterboy
    Sep 5, 2012
    1,999
    Minnesota
    Or, if she kicks you out, you can live on a motorcycle.
    Davidprej likes this.
  7. AviatorTroy
    AviatorTroy Following my front fender
    Oct 15, 2007
    2,564
    Castle Rock, CO
    Yep the front tire of a motorcycle mounted in the correct direction should have the V of the tread pattern inverted. It seems this would push water and debris inward except that when a bike is in a turn and leaning it is actually ejecting it out, toward the outside of the turn.
  8. st3ryder
    st3ryder Long timer
    Jan 27, 2012
    1,238
    Needs some good counselling too. Isn't that the dude who uses a seat belt? :norton
  9. glory racing
    Aug 23, 2013
    673
    harrison, AR
    I see seat belts hanging in the pic. Surely he doesn't strap to the bike. Gotta be to allow more stuff to be attached to the bike, other than himself.
  10. Junyah
    Junyah @ the speed of plaid
    Mar 19, 2011
    1,896
    Between the seat and bars
    Looks like he has more stuff on the bike since I last met him a few years ago. Yes, he wears the seat belt :confused
  11. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    11,491
    central USA
    But he is riding, so I approve.
    anotherguy likes this.
  12. dinkydonuts
    dinkydonuts Been here awhile
    Sep 1, 2015
    278
    OK
    I would at least ditch the rolling AIRPORT luggage and get duffels to hold whatever is in those. Sheesh that looks like a disaster in the making. His forks and monoshock are done for.
  13. foxtrapper
    Sep 6, 2011
    4,747
    I’m sure the handling of that bike is...interesting. Regardless of what tires he’s running! :lol3:lol3
  14. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,876
    NW of Philly, Hoboken, Brooklyn.
    Not mounted on a motorcycle, but interesting view:
    Treadless and phughes like this.
  15. phughes
    phughes Long timer Supporter
    Jul 10, 2015
    2,234
    Pennsylvania
    Wait... you put a car tire on your Ural? Tell me more.
  16. windmill
    windmill Long timer
    Feb 18, 2008
    6,559
    There are some vintage car tires that will work, such as Excelsior.
    [​IMG] [​IMG]
    I found they're not as good as specialty sidecar tires such as the Hiedenau K28, Avon triple duty, and Metzler block K..
    phughes likes this.
  17. foxtrapper
    Sep 6, 2011
    4,747
    I’d hoped he would do more turns. I was curious to observe side deflections. Ah well. Perhaps someone else will do it.
    did find the minute center bulging over the ground contact point interesting.
    Cat0020 likes this.
  18. phughes
    Jul 10, 2015
    2,234
    Pennsylvania
    Thanks. I sort of figured you had gone vintage, but I still held out hope for some miracle discovery. :lol3
  19. jules083
    jules083 Long timer Supporter
    Jan 26, 2011
    8,464
    Richmond, Ohio
    Well, done ruined my brand new goldwing. Handles pretty good so far. We have a stupid rocky rutted up parking lot at work that's annoying now when the side of the tire hits a high or low spot, but other than that it's fine.
    The profile of a car tire to the old bike tire actually isn't much different:
  20. glory racing
    Aug 23, 2013
    673
    harrison, AR
    Experiment with air pressures as they can dramatically effect the ride.
