1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
The definitive Aurora Cockpit Thread...
Discussion in 'Parallel World (790/890)' started by braaap!, Jun 14, 2020.
  1. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    6,771
    Ontario .. Superior
    Imagine this thread populated with 20 or 50 or 100 adopters. Yikes. But by then some uber motivated individual will already have the data laid out in a table of variables .. what fits, and more importantly HOW it fits in regards to bar position, riser, Scotts, handguards and so on. Then sticky that atop this thread so new comers, with little hair left to pull out, come looking for salvation.
  2. MN rider
    MN rider Been here awhile Supporter
    Mar 1, 2018
    163
    MN
    I just double checked. The TCM baseplate bolts to the tripleclamp on the most rearward hole. There is two locations for the risers to bolt to the baseplate. Mine is in the rear hole, which lines up with the middle set on the tripleclamp. If the risers are in the rear offset position they hit the Scott's, in the forward position they clear by just over 1/16". TCM offers two versions of the baseplate, I have version 1 which keeps the 90mm spread so it's compatable with the hbd handguards, the v2 are wider so they would be able to be flipped. IMG_20210116_161458946~2.jpg
  3. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,643
    Thousand Oaks, CA
    Maiden Voyage!
    DirtBrain, MN rider, kzeb and 13 others like this.
  4. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,834
    NW Sydney, Australia
    Fantastic :clap
  5. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    11,331
    The Delta Ghetto, GA (aka PTC)
    Did you find any maidens?
  6. SoilSampleDave
    Jan 21, 2005
    11,331
    That’s wild; I never knew they had two versions. I don’t remember a choice when I ordered either. I guess maybe they only do V2 now.
    640 Armageddon likes this.
  7. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    5,473
    Melbourne - AU
    640 Armageddon and TrailTrauma like this.
  8. braaap!
    Mar 16, 2005
    5,473
    Melbourne - AU
    You did a great job getting daylight between the bottom edge of the light housing and the top of the guard! :thumb
    Mine only clears by approx' 3mm :(:
  9. Yellow Pig
    Oct 28, 2004
    9,643
    Thousand Oaks, CA
    More weekend testing.
    Can't state enough how much I like this bike and the Aurora kit!
    Finished up my sub-dash and installed a switch for the heated grips and one for the GPS. I like having the GPS wired to a constant on power-source so I can look at the GPS and check tracks when stopped, but I don't want to have to take the GPS off the bike every time I park it at home, so it's nice to have a switch to turn it off.
  10. TrailTrauma
    Jan 17, 2012
    6,771
    Ontario .. Superior
    Jesus...that last one blew me away! Gorgeous. You did a great job too of balancing the aesthetics with the practical.
  11. SoilSampleDave
    Jan 21, 2005
    11,331
    Freaking awesome! Did you get up high enough to get in the snow? I saw video from the DesertMC Hare and Hound and there was now everywhere!
  12. Yellow Pig
    Oct 28, 2004
    9,643
    Thousand Oaks, CA
    No stayed low where it was warmer.
  13. SoilSampleDave
    Jan 21, 2005
    11,331
    I hear you, I hate the cold, but it sure looked amazing.
  14. Yellow Pig
    Oct 28, 2004
    9,643
    Thousand Oaks, CA
    Public service announcement: Check the lower bolt of the spider clamp and make sure the extra threads are not hitting the fork tube, could be an expensive fork fix if the hit is hard enough.
    I had to trim mine w/ a dremmel to get rid of the contact:
  15. SoilSampleDave
    Jan 21, 2005
    11,331
    You’re not the boss of me!!!
    EvilSteve likes this.
  16. braaap!
    Mar 16, 2005
    5,473
    Melbourne - AU
    @Yellow Pig thanks for the heads up... Bolt removed and faced off on the linisher :)
    My fork tube indeed bears witness to a slight contact...
    640 Armageddon and Yellow Pig like this.
  17. 1coolbanana
    Aug 25, 2009
    6,834
    I cant see the images?
  18. braaap!
    Mar 16, 2005
    5,473
    Melbourne - AU
    Might look something like this... Lower bolt looked like the upper before trimming down. At full lock (on the stop, left) there's now at least 5mm clearance between the end of the bolt and the fork tube.
    640 Armageddon and 1coolbanana like this.
  19. MN rider
    Mar 1, 2018
    163
    MN
    Not much clearance on mine. Pic is on the stops, 890 adv R. IMG_20210125_201129840_HDR~2.jpg
  20. braaap!
    Mar 16, 2005
    5,473
    Melbourne - AU
    Minor contact mark on the fork tube - Eek!
    Again thanks for the heads up Yellow Pig! Might pay for all Aurora kit owners to have a double check... Peace of mind.
