The definitive Aurora Cockpit Thread...
Discussion in 'Parallel World (790/890)' started by braaap!, Jun 14, 2020.
  1. crashpads
    crashpads Adventurer
    Jun 20, 2009
    35
    Norway
    Finally all sorted :) We actually got some warm days and I got to take a ride today too! Very happy with it all in all, although the aerodynamics are still a bit violent in the helmet area for me at 186cm and a peaked helmet. Big thanks to Aurora for great service!
    braaap! and leekdesign like this.
  2. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    11,070
    The Delta Ghetto, GA (aka PTC)
    Found similar effects myself; a small spoiler on top, oriented almost exactly vertical did the job. I will also add that the lighter the helmet, the more the buffeting is felt. With my stupid light endurocarbon helmet, it still wanted to bounce around, with or without peak. Heavier Shoei helmet, no problem. Will be trying an AGV9 later today will hopefully be the just right in between weight.
  3. crashpads
    Jun 20, 2009
    35
    Norway
    Something like this? I found it helped pretty much up to a certain speed. But overall the wind protection to the body is really good and stable.
    thirsty 1 likes this.
  4. SoilSampleDave
    Jan 21, 2005
    11,070
    Mostly. I tried that fancy one with no luck on the stock windscreen. I also tried a nice Touratech one on the Aurora screen with no luck. I then tried a $15 ebay one and it solved 95% of the buffeting. I’ll take a picture in a minute or three. Also, why is there a remote reservoir for your clutch when it looks like you still have the OEM master cylinder with integral reservoir?
  5. leekdesign
    leekdesign Adventurer
    Aug 23, 2016
    11
    Bonn, Germany
    Finally did it today. Thank you for this kit!
    1coolbanana likes this.
  6. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    5,371
    Melbourne - AU
    Looks great!!! Liking the low fender :thumb
    leekdesign likes this.
  7. SoilSampleDave
    Jan 21, 2005
    11,070
    Here’s your $15 ebay special.
  8. SoilSampleDave
    Jan 21, 2005
    11,070
    I liked my low fender too, but the fork guards are way too short if you go 270mm on the Pro suspension. I mean, obviously it fits, but it leaves a little more gap than I am comfortable with.
    leekdesign and braaap! like this.
  9. braaap!
    Mar 16, 2005
    5,371
    Melbourne - AU
    For my riding I don't need 270mm travel :) I'm slow and old and have no intention of hitting anything where 270mm travel might be of use... The low guard certainly suits the aesthetic of the Aurora kit. Hmmm. another purchase coming up me thinks.
  10. leekdesign
    Aug 23, 2016
    11
    Bonn, Germany
    You are right. The look of the Aurora Kit with the low fender is perfekt to me.
    I bought it and ordered a used low fender from ebay. It was the S, so it doesn't fit. :lol3
    @SoilSampleDave Good to know. If I am going to make the KTM perfect, there must be a solution for the Xplore Pro with a low fender.:photog
    braaap! likes this.
  11. crashpads
    Jun 20, 2009
    35
    Norway
    Sweet, I actually have one of those in the garage :) Will try that next. Regarding the brake, I have a 17,5 mm radial front brake master on it that performs way better than original (Adeline pump from china, works great) and a left hand rear brake setup also.
    SoilSampleDave likes this.
  12. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,828
    NW Sydney, Australia
    Any old 1090, 1190, 1290 low guard fits.
    First mod I did to the bike and and extra 20mm rise with some home made brackets
    MN rider, leekdesign and braaap! like this.
  13. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,615
    Thousand Oaks, CA
    Mod v3.0
  14. MN rider
    MN rider Been here awhile Supporter
    Mar 1, 2018
    163
    MN
    I've got the same issue, USA spec bike. I don't have the dlr option in my menu. The hlu error comes up when I start the bike, so does the malfunction indicator light, when you go to the warning page it only shows the hlu error so I assume they are both in relation to the hlu. Also my low beam only comes on with the Aurora switch.
  15. 640 Armageddon
    640 Armageddon Xplorer Supporter
    Mar 4, 2009
    4,603
    Greece
    The bus code in some 890s, irrelevant to where they are from at the moment, it's not the day lights or anything, the code itself is different now. @Yellow Pig 's light is on our CANbus developer and we are making a new bus controller with a switch to select bikes. Unknown from which 890s this started, some of them are ok from our customer base. we've stopped supplying controllers to 890s and we give only a simple harness and then as soon as the new controller is ready we will ship there.
    They don't make it easy, but we will get there.
    Yellow Pig and braaap! like this.
  16. leekdesign
    Aug 23, 2016
    11
    Bonn, Germany
    Awesome looking KTM!
    ErGuss, advdoctor, perlx and 4 others like this.
  17. braaap!
    Mar 16, 2005
    5,371
    Melbourne - AU
    640 Armageddon and leekdesign like this.
  18. Yellow Pig
    Oct 28, 2004
    9,615
    Thousand Oaks, CA
    Pretty much done.
    The only things missing are the single sided brake and the Konflict H.A.S. Suspension.
    pjh66, TrailTrauma, DirtBrain and 6 others like this.
  19. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,264
    Upstate NY
    @640 Armageddon take a look at the bike in this post. I think there is a good chance that this fairing modification would significantly improve the airflow of the bike, and provide a better basis for modifying the airflow and allow riders flexibility in "tuning" for reduced/eliminated buffeting. It would also simplify the attachment of the fairings to the bike over your current design. If you had those panels available, I would order them today.
    Lill-Erik likes this.
  20. Idaho1
    Idaho1 Adventurer
    Apr 10, 2013
    32
    Northern Idaho
