the DR200 thread
Discussion in 'Thumpers' started by klxrdr, May 13, 2007.
  1. Bassman55
    Bassman55 Adventurer
    Jul 11, 2018
    71
    California
    Thank you, the only link I seen that did not work was the happy trails one.
  2. no
    no way man no how
    Nov 19, 2005
    114,316
    Minnesota
    Good to know, I'll change it.
    Bassman55 likes this.
  3. Trailrider200
    Trailrider200 Been here awhile
    Nov 2, 2010
    920
    Exit 10A, RT 42
  4. Trailrider200
    Nov 2, 2010
    920
    Exit 10A, RT 42
  5. Bassman55
    Jul 11, 2018
    71
    California
  6. Bassman55
    Jul 11, 2018
    71
    California
    Reading all the old posts on this thread that go back years I became quite fond of some of the inmates and the replies. As the pages progressed I noticed that some of them dropped off and were no longer posting. I suppose they moved on, bought another bike, or maybe got a new name? Anyway I enjoy reading pretty much all of the posts.
  7. Trailrider200
    Nov 2, 2010
    920
    Exit 10A, RT 42
    H4
  8. Bassman55
    Jul 11, 2018
    71
    California
    I believe it is the H4 for mine. DR200SE
    I’m also looking for LED replacement bulbs for the stock rear blinkers. I did a search through this thread but I did not see a link or a write up anywhere specifically for them. Anybody know where to get some?
  9. Bassman55
    Jul 11, 2018
    71
    California
    Thanks Trailrider. Didn’t see your reply.
    Trailrider200 likes this.
  10. GSguy
    GSguy Here's a quarter.
    Aug 10, 2003
    3,320
    Valley of the Tulips
    Baseman you are correct, lots of info and ppl that don’t get all bent bc you are asking questions
    I found this tread few months ago when my DR was not running right due to carb issues, found even tho I cleaned the crud out of it float level was slightly off causing issue. Readjusted using info from here and boom runs great again
    Lots of really good posts from trail rider in up-grades I plan on doing to the old girl
    Bassman55 and Trailrider200 like this.
  11. bIackjack1995
    bIackjack1995 n00b
    Sep 6, 2017
    1
    Honolulu
    Hello I live in Hawaii and have a 2009 DR200 SE, I have a leaking gasket problem or something all around the engine from the mechanic I spoke to he said just forget trying to fix it because it will probably just come back and cost too much to fix and just keep replacing the oil. Ive stuck to his advice and just keep cleaning the oil all the time nearly every ride. Is it too difficult to fix it by myself and how to go about it? or should I just do what he said and forget it. Another problem I have is my steering gets like stuck when I turn on the road they've said it was a bushing issue and I look to fix that one day but its still rideable fine. Another problem recently was my spedomete went out know what do about that? and at last my friend has a Yamaha 250 brand new one and id like to use his turn signals on my bike as he bought new ones im unsure how to go about this and if its very difficult. any help would be sweet thanks
  12. Bassman55
    Jul 11, 2018
    71
    California
    That’s great to know. Isn’t it great when somebody help somebody else and it works in your bike starts running great again? What a feeling thanks for the post.
  13. Bassman55
    Jul 11, 2018
    71
    California
    What is the size of theDR200 stock fuel line 1/4” or 5/16”? Thanks
  14. no
    no way man no how
    Nov 19, 2005
    114,316
    Minnesota
    Which gasket is leaking?
  15. Trailrider200
    Nov 2, 2010
    920
    Exit 10A, RT 42
    not worth doing in my opinion since they are not running light type whereas the electrical load would be reduced. I changed the panel light bulbs to all LED. for the turn signals u also have to change the flasher relay. https://www.ebay.com/itm/Suzuki-Fla...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
  16. Bassman55
    Jul 11, 2018
    71
    California
    Thanks for that trail rider. I probably won’t do it it makes sense. You seem to have some good ideas have you ever had to take a dent out of a gas tank? I got one on the side of my DR200. I saw some cheap dent puller’s that use a glue gun on Amazon but I’m not sure they’re any good.
  17. GSguy
    Aug 10, 2003
    3,320
    Several years ago I saw a guy use shop air pressure to remove a dent in the side of the tank. Pet cock was closed, used like a large beaker rubber plug with a hole in the middle to seal the fuel inlet. Applied just a quick shot of air pressure and popped the dent right out
  18. Trailrider200
    Nov 2, 2010
    920
    Exit 10A, RT 42
    no experience besides just reading others attempts and it always depends on the dent what works or not. youtube it and compare to your dent for a fix.
  19. Bassman55
    Jul 11, 2018
    71
    California
    Thank you for the tip, I also just saw somebody do that on YouTube for a relatively small dent. I might give that a try and look at a few other options as well.
  20. Bassman55
    Jul 11, 2018
    71
    California
    Bought a set of Handlebar risers 7/8” x 30 mm and received them today. Going to put them on tonight. I hope they fit without any problems.
