the DR200 thread
Discussion in 'Thumpers' started by klxrdr, May 13, 2007.
  1. Trailrider200
    Trailrider200 Long timer
    Nov 2, 2010
    1,253
    Exit 10A, RT 42
    H and S is all u need. check my post about replacing the spring with a better one from a yamaha. I had to crank the oem all the way down to keep from sagging. with the yamaha spring only need to crank half way for a great ride.
    BigIron805 likes this.
  2. BigIron805
    BigIron805 Been here awhile
    Nov 28, 2009
    142
    Ohio
    Thanks. I wanted to try adding some sag for a vertically challenged rider who wont use all of the susp travel.
  3. BC1
    BC1 Been here awhile
    Oct 30, 2010
    108
    Kamloops BC Canada
    Short 80km loop around my backyard today. Very enjoyable ride on the junior DR
    20190526_160253.jpg 20190526_165135.jpg 20190526_150146.jpg 20190526_165919.jpg
    Klay, MYUMPH and Stuart_51 like this.
  4. FAW3
    FAW3 Old wanderer
    Mar 13, 2009
    2,485
    No.VA.
    Well folks, i've had a great ride in DR200 land...but it's time to change the garage fleet around a bit. I've sold the DR to a nice young lady and wish her and you fine folks the best.
    Happy trails and safe riding!
    tony the tiger likes this.
  5. Desert Denizen
    Desert Denizen The least interesting man in the world
    Apr 24, 2016
    261
    29 Palms, CA
    I hope you keep following this thread to lend your experience, thanks.
  6. MYUMPH
    MYUMPH 'Ol Timer Supporter
    Dec 15, 2009
    738
    Va
  7. Desert Denizen
    Apr 24, 2016
    261
    29 Palms, CA
    Yes, just like the Mojave desert but without the distracting trees and lakes!
  8. BC1
    Oct 30, 2010
    108
    Kamloops BC Canada
    I ride 5 minutes up the street to the fsr which leads to many many miles of backroads, im so lucky. I also ride some rugged single track in the same area.
    MYUMPH likes this.
  9. el doug
    el doug n00b
    May 28, 2019
    1
    Islamabad Pakistan (at the moment)
    Hi all. I am looking for some used side panels / fairings in white that would fit a 2007 dr200se. Can't find anything used on ebay, craigslist and new ones like on bikebandit are a bit expensive. I want to have some Pakistani truck art painted on it as a second set of plastics. I am bring back to Islamabad a white front / rear fenders and would like to complement it with some white side panels. New or used but reasonably priced. Any ideas? ... Photos attached show my bike in Colorado as well as examples of Pakistani truck arts so you get my idea.
    doug.abshire@gmail.com
    Thanks in advance,
    Doug
    ScreenHunter 9589.jpg ScreenHunter 9590.jpg ScreenHunter 9591.jpg ScreenHunter 9593.jpg ScreenHunter 9594.jpg ScreenHunter 9595.jpg ScreenHunter 9592.jpg
    Ladybug likes this.
  10. Mick98
    Mick98 n00b
    May 31, 2019
    5
    Campsie NSW 2194, Australia
    Just bought an 87 dr200, I was wondering if anyone knows where I can get a service manual for it? I can only find 96 and up :hmmmmm Cheers !
  11. Klay
    Klay dreaming adventurer Supporter
    Nov 19, 2005
    120,174
    right here on my thermarest
    From the first page:
    https://www.manualslib.com/download/831172/Suzuki-Dr200se.html
    '96 and up ought to be good because the DR200 didn't change untill recently.
  12. Jodaddy
    Jodaddy Been here awhile
    Mar 9, 2013
    202
    Missoula, MT
    87 dirt model? I always wanted to ride one. Six speed pumper carb yay. Kick start only. Looks like fun. Good luck.
  13. Mick98
    Mick98 n00b
    May 31, 2019
    5
    Yep. Cheers mate
  14. Mick98
    Mick98 n00b
    May 31, 2019
    5
  15. 123craig
    123craig Adventurer
    Oct 24, 2016
    31
    Same to you too Old wanderer - and thanks for the info you've shared through the years.
    I've now done valve adjustment to 0.10mm on both intake and exhaust - seem to notice slightly better idle sound (no more noticable clicky/hissy sound). I haven't rode the bike or put it into gear yet since the valve adjustment though.
    When I checked valves before adjusting - the intake (back of engine) was above 0.20mm (too loose), and the exhaust (front of engine) was under 0.04mm (too tight). - Would either of these valve settings possibly damaged engine as I rode it for a further 5000km (or so...)?
  16. kostikos
    kostikos Adventurer
    Nov 7, 2016
    36
    My scientific opinion is: Nah
  17. Trailrider200
    Nov 2, 2010
    1,253
    Exit 10A, RT 42
    nope since they got that way during operation. if u set them that way and then ride, yes it would cause damage, esp the exhaust
  18. BC1
    Oct 30, 2010
    108
    Kamloops BC Canada
    I received my ebay led headlamp after 3 months wait, installed it and tested in the shop. Nice improvement over stock.
    But somehow at some point the key was left on :shog
    The battery reads 1.9 volts with the meter. Is there a chance this battery could recover to being reliable or should I replace?
    Im going to let it rest before putting a charge to it.
    thanks
  19. THRASHED
    THRASHED In your helmet, no-one can hear you sing, I hope.
    Jan 4, 2013
    1,213
    San Dimas, CA
    I've found that running it dead once...maybe twice...won't absolutely kill it, but it will likely shorten the life span.
  20. Trailrider200
    Nov 2, 2010
    1,253
    Exit 10A, RT 42
    low amps and longer time is the best way to charge a battery. use a modern smart motorcycle battery charger for minimum 10 hrs and it will be good to go.
