the DR200 thread
Discussion in 'Thumpers' started by klxrdr, May 13, 2007.
  1. Jodaddy
    Jodaddy Been here awhile
    Mar 9, 2013
    182
    Missoula, MT
    I went one tooth down on the cs sprocket which helped a lot. Pumper carb also helped. I Plan to swap in a lt230 cylinder head when its time for a new top end. Also have ktm 450 in the garage. The 200 is capable but not always the best tool for the job. Long steep hills require some work which will improve your skills.
    FoggRider likes this.
  2. FoggRider
    FoggRider Been here awhile
    Aug 24, 2015
    783
    California
    What model pumper carb did you go with? Is it compatible with late model DRs?
  3. Desert Denizen
    Desert Denizen The least interesting man in the world
    Apr 24, 2016
    261
    29 Palms, CA
    According to the wiring diagram, the center terminal is common. So assuming (danger!) you have the multimeter set to Ohms (resistance), with one test lead
    on the center and the other test lead on one of the other two terminals, you will have high resistance shown and by reversing the leads you will have much lower resistance.
    Keeping one lead on the center terminal and the other lead on the other outside terminal, you should have the same results. There are actually two diodes in that little gizmo.
    A diode is essentially a one-way electrical valve, permitting current to flow in one direction a blocking current in the other.
  4. BC1
    BC1 Been here awhile
    Oct 30, 2010
    100
    Kamloops BC Canada
    Thanks, im pretty sure its fine. I bumped the battery post against the rectifier, now i have nothing but a bright neutral indicator. Unfortunately it wasnt simple like a fuse.
    Still trying to diagnose what blew.
  5. BigIron805
    BigIron805 Been here awhile
    Nov 28, 2009
    141
    Ohio
    Has anyone found that the side stand folds up a little too easy? Is there a fix for this? Maybe I'm just used to a heavier bike?
  6. BC1
    Oct 30, 2010
    100
    Kamloops BC Canada
    My sidestand seems to work as it should, and stays put. Not sure what to suggest.
    BigIron805 likes this.
  7. 3bangin
    3bangin 2014 tiger 800, 2018 tiger 800 xca Supporter
    Jun 4, 2007
    371
    Chehalis wa
    Fuel petcock advise ..........or just beat the wife?
    So, this is literally the 10th phucking time I've drained a gallon or so of gas out of the crank case in the past 5 years.
    I've changed the needle and seat a couple times and have tried two different vacuum peacocks in the past. Always going back to the tried and true plain, on/off/reserve
    Petcock.
    The problem, the wife can't seem to remember to shut the petcock off after she rides the bike. It sits sometimes for months .
    I say, just turn the petcock to off when your done..............her, I dont have to do that to my Triumph!
    I try to explain the differences but I get the empty (there is no amount of explaining that's going to make a difference look) look.
    It's almost comical because I cant remember to look or to remind her.
    I do seem to remember to check the sight glass every time though.
  8. BC1
    Oct 30, 2010
    100
    Kamloops BC Canada
    I replaced mine with the yamaha one reccomended in this thread, the raptor quad i think. I few times i forgot to shut it off but no leak issues. The stock one is faulty.
  9. Jimo368
    Jimo368 Quantum Mechanic
    Feb 23, 2011
    532
    Northwestern Ontario
    My DRZ did the same thing until I replaced it with the Yamaha petcock as well.
  10. BigIron805
    Nov 28, 2009
    141
    Ohio
    Was the petcock issue fixed on the 15 and up models?
  11. 3bangin
    Jun 4, 2007
    371
    Chehalis wa
    Yamaha vacuum petcock?
    Figures, sometimes you stumble over the obvious until someone slaps you with a smart stick.
    Thanks, Bob.
  12. 3bangin
    Jun 4, 2007
    371
    Chehalis wa
    So, one reason this issue needs to be fixed is late this fall we are trying to plan a trip down to Todo Santos Baja with both bikes.
    Trailering them close to the border.
  13. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    9,439
    Southern New Jersey
    You should turn the petcock off on every bike that is not fuel injected.
    It should be a habit, done with the bike, petcock off, key out.
    Vacuum petcocks fail eventually, one way or another, I bin them at the start.
  14. 3bangin
    Jun 4, 2007
    371
    Chehalis wa
    Yup, agree.
  15. Jodaddy
    Mar 9, 2013
    182
    Missoula, MT
    Mikuni tm31 from a dr250. I wasn’t sure how well it was going to work so I bought one used from a fellow inmate. That said it probably would have better to have bought a new tm28 pumper and used the jetting specs from the 80’s dirt models. Had to do a little work to make the cables function and do away with the vacuum petcock. These flat slide pumper carbs do wear out so I was really lucky to get one in really good shape.
  16. XArmy
    XArmy uhhhhh......
    Jun 3, 2013
    69
    West Michigan
    Well, She's alive! Here is my little 99 200 I picked up for $800. Put new tires, chain, sprockets, hand guards and a lithium battery on it (and a few other odds and ends). Runs like a champ. Hardly a scratch on it.
    Bors, tony the tiger, 3bangin and 4 others like this.
  17. BC1
    Oct 30, 2010
    100
    Kamloops BC Canada
    Thief :lol3:lol2
  18. BC1
    Oct 30, 2010
    100
    Kamloops BC Canada
    Fwiw I made a USB adapter and mounted it off the turn signal bracket, connected to an unused plug under the headlight cover. Works gR8
    Made a how to video
  19. BigMac774
    BigMac774 n00b
    Jul 8, 2019
    3
    Massachusetts
    I recently bought a 2006 DR200. Its previous owner had disconnected the clutch position sensor and I reconnected it but saw an unused plug under the headlight cover while doing so. The plug has a black wire with a white stripe and a brown wire attached to it. I assumed it was for something else the previous owner had also disconnected but couldn't find anything for it to plug into.
    I'm I looking at the same unused plug you used for your USB adapter? If that's the case, I guess I don't need to concern myself anymore about what the plug could be for. I've been wondering what it's for ever since noticing it and thinking just my DR200 had it because something was removed from it before I bought it.
  20. Trailrider200
    Trailrider200 Long timer
    Nov 2, 2010
    1,175
    Exit 10A, RT 42
    that might be the accessory plug. talked about over 20 posts ago. also see some recent posts for free manual download.
