1. Livestream NOW at 9pm EST / 6M PST! Any Questions for Marc?
    Baldy + Alta CEO & Co-Founder Marc Fenigstein YouTube Live Chat here
    Dismiss Notice
the DR200 thread
Discussion in 'Thumpers' started by klxrdr, May 13, 2007.
  1. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
    @ BC1: Nice! We're just down the road a bit in SA. Just trying to help my son put his DR200 together. Don't know if we'll get out this season yet, but we're sure trying!
    On that note, anyone know how many turns out to set the pilot air screw? We couldn't count turns when we cleaned the carb because there was no spring, washer, or o-ring behind it... :-( We've got it at 2 1/2 turns, but would love some 'expert' advice! ;-) Thanks.
  2. Trailrider200
    Trailrider200 Long timer
    Nov 2, 2010
    1,204
    Exit 10A, RT 42
    3 to 3 1/2 turns out works really well.
  3. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
    Thanks Trailrider200! We'll give that a try to begin. It's good to have a reference point! ;-)
    Trailrider200 likes this.
  4. BC1
    BC1 Been here awhile
    Oct 30, 2010
    108
    Kamloops BC Canada
    Im leaner then 3.5 in kamloops. Make a 90 degree screwdriver out of thick wire and ride/tune it. Im about 2.75 or so but i went fatter on the main, 132.5, pilot 37.5.
  5. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
    Another data point--awesome! I like your idea for making a 'screwdriver'; we'll have to rig something up. ;-)
  6. andruboz
    andruboz Serial overfiller
    Oct 17, 2004
    6,166
    central tx
    my Moose Racing carb rebuild kit showed up in the mail today. any tips tricks and sage advice? bought it because 'low speed jet' appears to be gummed up after sitting too long. runs on choke, sometimes makes it up in rpm and runs there too but stalls where the midrange half throttle should be.
  7. Jodaddy
    Jodaddy Been here awhile
    Mar 9, 2013
    186
    Missoula, MT
    No useful advice here. Sorry
  8. Trailrider200
    Nov 2, 2010
    1,204
    Exit 10A, RT 42
    "seat mating surface with some polish and a q tip in a drill."
    one of the worst things one can do, should never be done, unless one is a carb shop with specific tools and expertise.
  9. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
  10. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
    Another data point for the pilot screw setting:
    I have a PDF manual for the DR200SET ('96 model), with supplements for '97-'03, '04-05, '06, '07-08, and '09 models. Buried in the carb specs in two of the supplements ('04-05 and '06), it says "Pilot screw -- 1 1/2 turns out." Every other carb spec chart has "PRE-SET"... The carb for those years is the same MIKUNI BST31SS, but the ID no. in the charts is 42AA, rather than 42AC for all the rest. Anyone know what the difference is? What the charts indicate is:
    Main jet: #125 (42AC) vs. #122.5 (42AA)
    Pilot jet: #35 (42AC) vs. #40 (42AA)
    Anyway, interesting that the 42AA carb is different, and actually has pilot screw turn-out specs listed.
  11. Trailrider200
    Nov 2, 2010
    1,204
    Exit 10A, RT 42
    just about all screwdrivers are designed to work for both screw types today. these harbor freights work extremely well. https://www.harborfreight.com/2-x-4-inch-phillips-screwdriver-94707.html
    http://rtstools.com/jis-vs-phillips-screwdrivers-and-where-to-buy-a-jis-screwdriver/
    "Most JIS advertised screwdrivers sold today by companies like Vessel, Hozan, and others are actually conforming to a new standard: DIN 5260 which is identical (at the tip) to the newer ISO 8764-1."
    "The reason these companies have changed to DIN 5260/ISO 8764-1 is because the new standard is designed to work in both Phillips and JIS screws. For the most part that is true, it does work on both screw types, but like anything meant to work with multiple things, the middle ground means compromise. The JIS standard screwdriver will always outperform a DIN/ISO screw driver in the worst of conditions on a JIS screw, and the same is true in reverse."
    "To date, I have only been able to find one confirmed manufacturer that still uses and builds to JIS B 4633, and that is SUNFLAG otherwise known as New Turtle in Japan:"
    http://www.sunflag.co.jp/english/company/company.html
    Nobade likes this.
  12. Trailrider200
    Nov 2, 2010
    1,204
    Exit 10A, RT 42
    I have same manual. some of those supplement pages are actually for DR200s for other countries. one is actually for the Trojan DR, which helped me find the correct oil amount after I added a Trojan oil cooler.
  13. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
    Didn't know about ISO 8764-1...:p I use this set of Vessel bits: https://www.vesseltools.com/industrial-bits/bit-sets/a-16621-detail. All I know is that with them I can get out screws with heads that "normal" Phillips bits have mangled... They slot in with amazing precision! And the beauty of a 1/4" bit is that you can use it with a ratchet handle to get more torque for screws 'frozen' into aluminum. I've got a collection of regular Phillips screwdrivers, but they don't come close to the Vessel bits for fit. My boys have already learned to leave them aside when working on their bikes. ;-)
  14. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
    Yep! I'm always looking for info for E-28 -- Canada (country codes are listed on page 1-9). Curiously, the supplements include info for an E-06 model; is that the Trojan? Because E-06 isn't listed in the codes on p. 1-9, but it's grouped with the E-24 -- Australia...
  15. Trailrider200
    Nov 2, 2010
    1,204
    Exit 10A, RT 42
    don't disagree, the point is they are all using the new std including vessel, so they are still getting top dollar for the same screw driver one can get at the local store.
  16. Trailrider200
    Nov 2, 2010
    1,204
    Exit 10A, RT 42
    DR200SEK6 is the Trojan pg 11-17, and under E-06, oil capacity is 1.1 qts. It was the only section that shows a larger capacity.
  17. lengolad
    lengolad Adventurer
    Sep 3, 2019
    11
    BC, Canada
    I guess the mangled heads I come across are from previous owners with pre-ISO 8764-1 Phillips screwdrivers (like those in my toolbox...). Bottom line: do your bike a favour and replace your tired, old Phillips screwdriver! :-)
  18. Westcoasthumpin
    Westcoasthumpin Been here awhile
    Jul 20, 2016
    551
    Palm Springs of Washington
    I came across this and figured there must be a DR200 thread.
    buckskinner likes this.
  19. Klay
    Klay dreaming adventurer Supporter
    Nov 19, 2005
    119,988
    right here on my thermarest
    That's one of those "it's not the bike, it's the rider moments."
  20. Jodaddy
    Mar 9, 2013
    186
    Missoula, MT
    I felt so bad for him in those whoops. Brought back memories of having to use a string off my backpack to tie down the seat after the bolts backed out. Good fun.
