the DR200 thread
Discussion in 'Thumpers' started by klxrdr, May 13, 2007.
  1. mj15
    mj15 Been here awhile
    Dec 18, 2013
    112
    San Jose
    You're good, there is only one volume of oil in the engine, just fill it as normal.
  2. Maxem
    Maxem n00b
    Aug 7, 2021
    2
    Victoria bc
    Thank you!
    mj15 likes this.
  3. Ductor411
    Ductor411 Adventurer
    Feb 9, 2019
    37
    Staffordshire, England
    My footrests have been cut and welded, shortened by an inch, and the riding position is much the better for the modification. My fabricator also made a sump guard (bash plate) and shortened the side stand. The DEP (much lighter than oem) has been fitted and the exhaust note is crisper: it is difficult to assess any increase in power or torque after only one short ride, but I’m pleased with it.
    prays4u likes this.
  4. Mr. Fixit
    Mr. Fixit Reevaluating
    Jan 11, 2008
    7,946
    SWVA
    Very nice. I have the footpeg mod, a bash plate & cargo racks on my fabrication list.
  5. Ductor411
    Feb 9, 2019
    37
    Thanks. I like the look of Ricochet bash plate very much but it would have cost far too much to import: carriage alone would have cost two thirds of the price, then import duty, probably VAT on top and administrative charges to boot. My local fabricator agreed to make it for around £150 and I am happy with the quality of the plate, and the cost.
    The noise from the DEP is not too loud( I would think that, after my previous Dukes with Terminonis and a Guzzi with Lanfranconis) and is a slip-on, which needs a spacer (available at an excessive cost from Suzuki: the old one from the oem silencer was extracted and re-used) and I hope it can be heard on the attached photo. The seat has a gel pad which I had for a short time on a Monster: it wasn’t too bad on the first test ride, but I have other options, including a sheepskin and a bean bag! 3AAAD250-F6AC-4E2B-A40E-4C543FFC1684.jpeg
    Mr. Fixit likes this.
  6. Jay Cohen
    Jay Cohen Gearboy
    Apr 23, 2021
    43
    Shenandoah Valley
    I know there's lots of stuff on the DR200 petcock here but I did not come across my question, so if it's been discussed my apologies. Mine leaked and filled the crankcase with gasoline. Before I realized what had happened I tried to start the bike. My question and concern is that could I have damaged anything by trying to start it with all the gas in it?
  7. Klay
    Klay dreaming adventurer Super Supporter
    Nov 19, 2005
    122,843
    right here on my thermarest
    It's unlikely that anything was damaged. I would just drain the oil/fuel mix out and run it for a few minutes with new oil, and then replace the oil again and not worry about it. Both of our 200s went through this problem with fuel getting into the crankcase without any permanent damage.
  8. Klay
    Nov 19, 2005
    122,843
    Edit: Run it with a new petcock of course.
    prays4u likes this.
  9. Jay Cohen
    Jay Cohen Gearboy
    Apr 23, 2021
    43
    Shenandoah Valley
    Thanks for the reply Klay. That's just what I was thinking of doing. Why do they complicate things by using this type of petcock? Why not a simple on/off/reserve one?
  10. Trailrider200
    Trailrider200 Long timer
    Nov 2, 2010
    1,367
    Exit 10A, RT 42
    govt safety reg sometime back in '80s to have vacuum shutoff if gravity fed fuel from tank
    miniroot likes this.
  11. Jay Cohen
    Jay Cohen Gearboy
    Apr 23, 2021
    43
    Shenandoah Valley
    I got the new petcock, the manual one without the vacuum unit/line. I plugged the vacuum line going into the carb with a screw. The bike runs lousy, but if I take the screw out/unplug it, it runs fine.
  12. mj15
    Dec 18, 2013
    112
    San Jose
    Without that blocked, you should have a vacuum leak. Strange
  13. Klay
    Nov 19, 2005
    122,843
    Try a rubber cap instead of a screw.
    miniroot and prays4u like this.
  14. Jay Cohen
    Jay Cohen Gearboy
    Apr 23, 2021
    43
    Shenandoah Valley
    Thanks for the help Klay and mj. I'll mess around with it today. But as soon as I put my finger to cover the opening of the tube it ran poorly????
  15. Trailrider200
    Nov 2, 2010
    1,367
    Exit 10A, RT 42
    make sure the bowl vent tube is not the one u are plugging.
  16. Mr. Fixit
    Jan 11, 2008
    7,946
    SWVA
    Have you changed the oil? If it has gas in it, it will run rich, as if the choke was on.
  17. Jay Cohen
    Jay Cohen Gearboy
    Apr 23, 2021
    43
    Shenandoah Valley
    Yes, changed the oil.
    Bowl vent tube not blocked.
    Bike appears to be running way too lean now.
  18. mykdee
    mykdee Been here awhile
    Aug 7, 2011
    226
    Litchfield Park, Az
    I just picked up a 2003 DR200 with 3900 miles for $1100, this is the 3rd DR200 I have owned. It runs great and is in good condition, except it was layed down and dented the gas tank bad. Its an eye sore and I would like to get a newer used tank. If anyone has a lead on a tank please let me know.
  19. mykdee
    Aug 7, 2011
    226
    Litchfield Park, Az
    What tires and sizes are you running? Bike looks great!
  20. Jay Cohen
    Jay Cohen Gearboy
    Apr 23, 2021
    43
    Shenandoah Valley
    Got the carb apart. Tons of fine rust inside. Needle O-ring needs replacement. Will Evaporust the tank.
    Mr. Fixit and prays4u like this.
