the DR200 thread
Discussion in 'Thumpers' started by klxrdr, May 13, 2007.
  1. mj15
    mj15 Been here awhile
    Dec 18, 2013
    113
    San Jose
    Add a large, good quality inline filter as well.
  2. Jay Cohen
    Jay Cohen Gearboy
    Apr 23, 2021
    45
    Shenandoah Valley
    Yes, already did. Although the rust was so fine I don't know if a filter could have stopped it.
  3. mykdee
    mykdee Been here awhile
    Aug 7, 2011
    228
    Litchfield Park, Az
    Just picked up this 2005 DR 200 3,900 miles, runs great but the previous owner laid it down pretty hard on the left side. Bought it for $1100 and figured I could fix it up for pretty cheap.
    Bought some Kenda 270 tires, 3.25 front and 4.60 rear. I also picked up a polisport front fender, 13 tooth front sprocket, front brake pads, front and rear wheel bearings, gold chain, Tusk handguards and pro taper ATV hi Bars.
    D559B34D-8DC1-4606-B18F-1AB4F1924B2F.jpeg A777FA15-9EE1-43AE-92FA-A53AC0AB20D9.jpeg
    BGoodiE, T-34, Klay and 4 others like this.
  4. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
    ****HELP!!****
    I replaced my handlebars with some Protaper ATV hi bars and when I removed the throttle tube I realized it was damaged and not reusable. I cannot find a replacement throttle tube, what is everyone using to replace the factory tube?
  5. mj15
    Dec 18, 2013
    113
    San Jose
    prays4u and Mr. Fixit like this.
  6. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
  7. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
    Another quick question, torque specs for triple clamps, front & rear axles? I do not have a manual yet and I have searched everywhere for specs and came up empty.
  8. Trailrider200
    Trailrider200 Long timer
    Nov 2, 2010
    1,367
    Exit 10A, RT 42
  9. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
  10. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
    So finally got evrything mounting up and torqued to specs. Pretty nice transformation, wish I would of taken more prior pics!
    List of everything I installed or maintenance....
    Protaper bars
    Tusk handgaurds
    Micro halogen turn signals
    Polisport free flow front fender
    Kenda 270 tires 3.50-21 & 4.60-18
    13 tooth sprocket
    Oil change with HP4 oil
    Spark plug
    Cleaned & lubed UNI filter
    Adjusted the bar mounts & front fork from previous owner wreck
    Plastic welded the headlight shroud
    Degreased and detailed bike
    I am happy with the progress so far.
    67FF6300-31E7-44B4-9388-DC1B596E21F4.jpeg 08102021-7960-481D-94EF-81653936A77E.jpeg 79BE5476-2DE8-4E0F-93A0-D5FAECCE8A3E.jpeg B59E17B8-4190-4B60-AE1F-BD8F452047DA.jpeg
    T-34, Trailrider200 and AZ TOM like this.
  11. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
    I did notice this when cleaning the bike today. should I be worried?!
    B6586295-334A-4849-8AA3-CE39929238B8.jpeg B00DFCB9-8BD7-4C97-9BD1-A93524D3FB21.jpeg
    Klay, Trailrider200 and miniroot like this.
  12. MtnDR
    MtnDR n00b
    Jul 8, 2021
    1
    80126
    Nice build so far, pretty similar to what I just started. I am pretty familiar with DR650s but first time with a DR200. My son and I are building it as a spare bike for family and friends. 1996 with 3600 miles.
    Plan is:
    Shinko 244 tires
    Tusk hand guards
    Procycle skid
    Generic folding mirrors modified for easier adjustment
    New Fly handle bar and grips
    rebuild carb
    Maybe grease the starter as it has a high pitch whine- or is that normal for these?
    New Fork Seals, does the standard Suzuki fork tool fit these?
    plus a few other things.
  13. Jodaddy
    Jodaddy Been here awhile
    Mar 9, 2013
    301
    Missoula, MT
    Little multiple choice question. You’re about to go on a ride and you check your gas and it’s probably enough to get you home. Do you A- say to yourself it’ll be fine. If I run out I’ll just walk home. B- say to yourself it’ll be fine and then proceed to worry about it the whole day. C-get some fuel. D- fill up the tank and an extra fuel bottle just in case.
    A-just run it with the gouge
    B- put it your the list to get it welded when you can.
    C-ride it straight to the welder shop
    D-get a new or used swing arm
    Klay likes this.
  14. mj15
    Dec 18, 2013
    113
    San Jose
    E. Cover it with a Metal Mullisha sticker
  15. Jodaddy
    Mar 9, 2013
    301
    Missoula, MT
    I was thinking bandaid
  16. mj15
    Dec 18, 2013
    113
    San Jose
    Weld it up if it bugs you, and you have access to an amenable welder. A few minutes work for a good tigger
    Klay likes this.
  17. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
    Thanks for all the responses regarding my swingarm. I am OK with having it welded or even replacing, I geuss I am just wondering if it is even needed? Will it be fine to just ride it as is?
  18. Trailrider200
    Nov 2, 2010
    1,367
    Exit 10A, RT 42
    IMHO if u see crack/s with 5x magnification then repair and/or replace, if not then u are fine as is, unless u plan to do big jumps and motocross with it. but it doesn't look deep from the pic and only scraped the raised thick area.
  19. Trailrider200
    Nov 2, 2010
    1,367
    Exit 10A, RT 42
    are those tires one size larger or OEM size? looks good thanks
  20. mykdee
    Aug 7, 2011
    228
    Litchfield Park, Az
    Still looking for a gas tank, mine has so pretty big dents in it.
