The DR650 Highway Touring Thread
Discussion in 'Thumpers' started by planemanx15, Mar 25, 2011.
  1. planemanx15
    planemanx15 Long timer
    Dec 4, 2009
    1,027
    Long Island, NY
    Tci brackets, cee baileys, laminar lip. No wind noise or buffetting from 0-85.
    Will still need to be refined, I want to use better bolts and straighten it up, but works great and stops the flex on the number plate.
  2. vintagespeed
    vintagespeed fNg
    May 9, 2011
    3,444
    Rancho Cucamonger, CA
    i've commuted daily on the DR for the last 1.5yr/25k miles and it wasn't until i recently bought my Street Triple that i knew what "clean air" was. the DR definitely has alot of turbulence and the screens i tried didn't really help. my helmet has a visor on it and that doesn't help at all in the equation. i tried the big turbo city wind screen thing which was like pushing a brick and didn't help with the buffeting. so i went screen-less.
    after riding it daily, i have no more issues with buffeting. basically, my body eventually adjusted and i no longer feel blown around on the bike, i ride 80mph + all the way in and never feel it pulling on my helmet anymore.
    as a side benefit, i can probably fight off a Royce Gracie rear naked choke fairly easily as well. neck muscles, who knew?
  3. rockohlic
    rockohlic Been here awhile
    Oct 22, 2009
    137
    arizona
    BTW this is the same bike on page1 several years and 2 owners later.[​IMG][​IMG][​IMG] only diff is fcr39mm and renazco seat
  4. TrophyHunter
    TrophyHunter Long timer Supporter
    Aug 30, 2009
    3,969
    San Diego
    I'd like to see more shots of the GPR mounting. Did you weld the rod to the frame like the Scotts mounting does? I had a GPR on my WR450 and it was a great addition. I haven't added one to the DR...I just stopped trying to keep up in deep sand washes. It really eliminates the headshake so you can just steer by putting pressure on the pegs. I used it for rocky sections too which helped the front just deflect instead of trying to yank the bars out of my hands.
    Interested....
  5. rockohlic
    Oct 22, 2009
    137
    arizona
    welded the post on. If you give gpr the diminsions of the head tube dia I bet they might have a bolt on.
    This was off one of my gasgas enduros wich I believe came off my wr450 yamaha. There is a lot of inter-changability
    with these things, The damper really helps in the occasional sand wash and even more important that obstacle in the
    road you did not see cause the veiws were demanding your attention. The bars are not yanked out of your hands and the natural gyroscopic effects keep you upright.
  6. TrophyHunter
    Aug 30, 2009
    3,969
    San Diego
    Thx. I'll have to run by GPR..they're 20 minutes from me and were very helpful on the WR. Got the nickel tour of the place. Good folks.
  7. kstoo
    kstoo Adventurer
    Nov 4, 2008
    78
    Beloit township, WI
    I was intrigued by this thread right from the beginning and have been following it somewhat all along. It has helped to inspire/encourage me to do this.
    I have this 2007 DR650 specifically because I want a motorcycle that will do it all well except cruising between taverns. I want a dirt bike / commuter / sport cycle / long-distance tourer / camping machine. I want it convertible; I can quickly strip down to bare and lower the tire pressure or outfit it as needed and go. It is getting there!
    The last 1,000 mile trip that I made I forgot that we are transitioning out of summer and I had to go against cold north winds for about 5 hours at 70+ mph. If I didn't have my Gerbing jacket liner and gloves I would have died of exposure. Regret, why did I not put on that TCI wind screen that I had bought at the beginning of the summer? I had put it on to try it out in June and then rode all summer with it off. So, when I got back I did put the TCI wind screen back on and it does help a lot to keep the wind off my body so there is less fatigue and more comfort. As well as it works, though, it directs the wind to about my neck [5' 10"] which steals body heat and makes helmet noise. I had solved this problem previously on a BMW R100RT with a Laminar Lip so I thought that I would look to see what they had. Of course, they don't make a lip for a TCI Adventure Wind Screen on a DR650. I looked at the universals [beware universal fit!] and it looked like the 14 just might possibly work. I thought about it and measured and thought about it and finally decided to give it a try.
    It came yesterday. I turned the garage heater on to get it up to 70° and put it on. The width is perfect, the curve of the universal 14 is prolly a little to radical and the mounting edge of the lip doesn't match the profile of the screen perfectly but close enough. I thought briefly about getting my heat gun out and thought the better of that. Measure, line it up, mark it with dry-erase, take a deep breath and go! I clamped it down with some grippers and turned out the lights for the night.
    It is raining this morning, even better to test it out! The wind is not very strong this morning but I can definitely feel the air pocket is larger and less turbulent. Wind spills out to the sides and to my face shield which is perfect in the rain! I need to put more miles in different conditions on it but so far I feel successful.
    The Lip can be taken off quickly; it is attached with 3M Dual Lock Velcro-like material. The TCI Adventure Wind Screen comes off by removing 4 plastic nuts and bolts with a jackknife screwdriver and put into a backpack. The Seahorse quasi-Pelican panniers come off the TCI Outback luggage rack by pulling a spring loaded pin up and lifting them up. The GL tank bag can be zipped from its base or just unstrap the whole thing. There is a Slime pump in the tank bag for pumping the tires back up when I come back to the road. There is a place to plug in the Gerbing liner and gloves and the Garmin and charge the phone. An Acerbis tank so I get to choose when to take to take a break. Procycle Saddleman seat so I don't need to yet. There it is [so far], my convertible adventure machine! I just need more vacation days!
  8. kstoo
    kstoo Adventurer
    Nov 4, 2008
    78
    Beloit township, WI
    I know that I was already verbose in my original post but I can't help it, I am excited! After a rainy day of painting the bathroom and other home keeping things I decided to test ride. At dusk the rain diminished but the temperature stayed in the fifties. The wind was strong from the SW and I knew that if I went down I-43 I would be straight into it. I saw large flags straight out so I know it was better than 30 mph. So, this test ride included 70+ mph into the wind, with side winds and with the wind to my back. I did about 50 miles, short test ride. All in all I am thrilled with the results. Before I reported that the wind was deflected to my face shield but not so, I had my face shield open with no turbulence coming in.
    If you look at the profile of the TCI Adventure wind screen and the same of the Laminar Lip universal 14, the combination of those two air foils really work good together. It is not a barn door blocking the wind but directing the wind around me with the least turbulence. I like!!
  9. planemanx15
    Dec 4, 2009
    1,027
    Long Island, NY
    :clap
    Feels good when you finally get the windscreen combination working correctly right?
  10. sagedrifter
    sagedrifter Southern Explorer
    Apr 23, 2006
    1,578
    Jacksonville, Alabama
    I'm glad that my Spitfire sceen works for me. Its fairly cheap and it makes all the difference while riding 500 mile days. I put it off for years, but its one of the top farkles I've tried that actually made a large improvement when touring. The center stand is high on the list too.... :1drink
  11. kstoo
    kstoo Adventurer
    Nov 4, 2008
    78
    Beloit township, WI
    Yep, that is what is enjoyable about putting it all together, that the only 'right way' is the way that works for me. That being said ...
    ergonomic mods - complete.
  12. drdubb
    drdubb OFWG Supporter
    Dec 13, 2009
    2,098
    Durham, North Carolina
    Picked up an 06 yesterday. Now to make it mine.
  13. philp38
    philp38 Long timer
    Mar 25, 2006
    3,285
    Decatur TN
    That looks comfy.. :D
  14. Phreaky Phil
    Phreaky Phil Long timer
    Mar 18, 2006
    2,939
    NEW ZEALAND
    It sure is. Couldn't imagine riding the TAT with a standard seat. I had no problems riding 31 days straight with our Russel DayLong seat. Best money ive spent:D A couple of pics from Port Orford at the end of the TAT
  15. straightrod
    straightrod Long timer
    Dec 19, 2006
    1,830
    SoCal
    ^ That is outstanding. I love the seat and that it is longer in the back. I have contemplated a pillion set up like yours but you have done it. May I ask yours and your wife dimensions, weight, height, inseam and what you did to the suspension to support the load. Thanks.
    The Safari tank is killer. I don't remember seeing one that large on a DR before. I love the look. It just means business.
  16. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,158
    SE Denver-ish
  17. Phreaky Phil
    Mar 18, 2006
    2,939
    NEW ZEALAND
    Hi there, im 5'10' 195pounds 33&1/2" inseam. Dawn is 5'5 130pounds 31" inseam. these figures are without riding gear.
    The suspension is quite trick. It has a DRZ 400 front end with 0.48 springs. the rear is an Ohlins with a 0.95 spring. I had the shock valving altered slightly to get it how i like it. There are cheaper alternatives for the suspension.
    Here is a link to my build thread. It shows how the seat base was done. Note that the seat in the pics isnt the Russel seat, it was one done locally. the pillion part was alright for Dawn but the rider part was aweful.
    http://www.advrider.com/forums/showthread.php?t=617031
  18. straightrod
    Dec 19, 2006
    1,830
    SoCal
    ^ Thanks Phil, I will check out your build site.
  19. planemanx15
    Dec 4, 2009
    1,027
    Long Island, NY
    Little update:
    I converted my tubed spoke rims to tubeless. I figured it is safer, since a tube tire would usually end in a blow out of the tube, rather then a slow trickle of air. I understand this isnt alway the case, and I could have a full blow out with a tubeless tire, but it is rare.
    I used the method outlined on smugmug:
    https://cyb.smugmug.com/Motorcycles/KTM/Tubeless/7250813_GmTpNx#!i=465979444&k=cW2xa
    I used JB weld to fill the rim lock holes:
    After 2 coats of seal all, 1 coat of goop, and a bath tub test, it was fine. The next day it lost 3 PSI. Took it off, did another water test, and 1 spoke came undone. I resealed it, tested again, and found another spoke came undone! :huh
    I sealed that spoke and before the glue completely dried, I filled the tire and tested.. it held 30 PSI for a full day. I lowered it to 27 PSI and it has held fine for 4 days now. I am hopeful that it will be fine now, and can't wait to actually ride.
    Thats a Shinko 712 110\90-19
    Whats stopping me from riding you might ask?
    The lack of a rear wheel. Warp 9 has been great, but if I had 1 complaint it would be time management. I was hoping to get the wheel back with a 17x4.25 in under a month...its been 6 weeks. it finally shipped out this week, so I should get it next Thursday. When I get it I will seal those spokes as well, and run this:
    Thats a Shinko 712 150\70-17.
    Its a big, fat rear tire... Something I've never ridden with, and sure to be different.
  20. Adv Grifter
    Adv Grifter on the road o'dreams
    Jan 18, 2010
    6,128
    Passing ADV Stalkers in California
    Any thoughts on riding the bike hard ... and then having the sealed spokes loosen up as a result? Seems to me they are "Glued" in place ... not sure how they could move, but as you showed in above post, they do apparently move or loosen somehow.
    I do rough, rocky roads at very high speed, so I'm a bit concerned about this.
    Would be interested to hear opinions or personal experience riding sealed tubeless rims off road.
    Thanks! :freaky
