    Dismiss Notice
The DR650 Highway Touring Thread
Discussion in 'Thumpers' started by planemanx15, Mar 25, 2011.
  1. Nessman
    Nessman From the western slope of the bell curve
    Feb 3, 2004
    3,561
    Kleptocracy, USA
    16/42 520 kit from Procycle in a box awaiting installation. Looking forward to better freeway manners.
    It's my commuter. No dirt, no fun. Just work.
  2. x32792
    x32792 Cracker American
    Jun 9, 2007
    2,491
    Winter Park, Florida
    The 16T seems to give me +2 mpg on the highway, BUT -2 mpg in the city.
    From my limited experiment, it seems the right c/s (for me) depends on where and how I ride....Also on how you're loaded. I travel light and don't go 2 up. If you're really loaded with metal panniers and carrying the kitchen sink, you may need to drop down to 14T?
    I've switched back to the 15T (a good in town compromise sprocket) and carry the 16T as a GO LONG back up spare.
  3. sagedrifter
    sagedrifter Southern Explorer
    Apr 23, 2006
    1,577
    Jacksonville, Alabama
    In reality the stock gearing is best all around. 16T sprockets make 5th gear useless around here rolling along hills. 14T will make my pegs buzz much more over 65 mph, those couple hundred rpm doesn't matter much though. I've done a few 500 to 600 mile days crossing states and the bike is fine with stock gears, its when you go off road that you will want a 520 conversion to something reasonable that won't have you feathering the clutch too much.
    To me the 15T fits well with the 42 rear since I only see mild roads. I like to run around the rural roads in 4th gear around 55 to 60 mph. Works well, gets around 51 mpg average with a pumper carb and exhaust. Its a little thumper, it likes RPM. On my last 1,000 mile trip I did a lot of 75/80 mph cruising while connecting scenic roads and the bike still averaged over 51 mpg. I was loaded most of the time with hard luggage and the tanks were 49 to 54 mpg.
    To me what makes a huge difference while touring with the DR650 is the GSXR exhaust, TM40 carb, larger fuel tank and a good seat. :D
    I ran stock exhaust with the pumper carb for too long, adding the exhaust and going to a 150 mian jet really helped on the interstate. Much more than I was expecting. It squirts right up to 85 mph per the GPS on flat ground. :roflNot so briskly climbing a mountain, but it gets it done. My 2007 has never burned oil or ever failed me and I've tested it a good bit. Great little bike. :freaky
    NicorAdv and f800kris like this.
  4. GypsyWriter
    GypsyWriter Yup, I'm a girl.
    Aug 28, 2009
    2,110
    Visalia CA
    *bump*
  5. planemanx15
    planemanx15 Long timer
    Dec 4, 2009
    1,027
    Long Island, NY
    I find with the 790 kit, no wind screen and a top case, my DR will cruise at 85 (gps) with no issues at all. Gearing is 16-42. Its even got a lot more pep in her past 90.
  6. f800kris
    f800kris Been here awhile
    May 14, 2013
    297
    Middle Tennessee
    Bump, took me several days to get through it but completed. Good one
    Baldyman1 likes this.
  7. Baldyman1
    Baldyman1 Adventurer
    Mar 22, 2008
    22
    Auckland, NZ
    Just found this thread (Thanks for the Bump) Some good info.
  8. DMOBill
    DMOBill Been here awhile
    Dec 21, 2013
    174
    Kittanning, PA
  9. Cro59
    Cro59 Been here awhile
    Sep 27, 2015
    829
    Tucson, Arizona
    so....vstrom guy here. Love the DL on the road, not so much in the dirt. Thinking the DR would be a good compromise but just wondering what the long time users think about a DR for a long distance machine.
  10. drdubb
    drdubb OFWG Supporter
    Dec 13, 2009
    2,076
    Durham, North Carolina
    Get a good saddle and go. I liked the seat concepts. Need to figure out some highway pegs.
    Cro59 likes this.
  11. x32792
    Jun 9, 2007
    2,491
    After almost 38K miles on two lane back roads and some super slab here in the States, I'll give you my 2 cents worth:
    Stock carb, suspension and gearing are just fine -- The closer to stock the better, but IF you like to tinker, have at it -- While others will tell you the DR needs extensive modification, I believe your gains will be minimal and may effect reliability.
    My Mighty DR has a better seat (I have Sargent, but there are others), 2" bar risers, mirror extensions, skid plate, rear rack w/rotopax (my Texas Tank which gives me 3.4+1.75 = 5.1 gallons which is plenty), Acme Zoom peg lowering hardware, bigger eBay knock-off IMS foot pegs, 12v outlet for GPS (or whatever), tool tube, 130 rear tire (I like Shinko 705). I also have a flat washer on my rear brake peddle to make it easier to find when wet and a 2"x 3" plate welded to the base of my kick stand to prevent the bike from falling over on soft or sandy ground.
    I rarely cruise above 65 mph and get 56-58 mpg. I don't bounce off the rev limiter.
    If you're not in a BIG hurry, the DR will take you anywhere you point it, up to and including RTW. :)
    Issues and Maintenance
    CCT gasket leaked, mended with RTV (be sure to study online DIY tutorial)
    Petcock began to leak, replaced it.
    Starter motor began to sound like a tormented rooster, removed starter motor (not as easy as it sounds), packed DRY bearing with heavy grease -- All quiet now
    Chains and sprockets, tires and tubes
    Oil and filters -- I use Rotella Dino oil from Walmart, buy it in one gallon container
    Keep Air Filter clean and lightly oiled
    Front light burned out, buy another
    Add gas, ride, repeat and enjoy.
    EDIT: DR too high?
    If you're under 6' tall, you may be intimidated by the 34.5" seat height. But not to worry, there is a standard OEM option which allows you (or your dealer) to lower the seat height by 1.4" -- All parts and pieces necessary are on the DR.
    TaZ9 and Cro59 like this.
  12. Cro59
    Sep 27, 2015
    829
    Tucson, Arizona
    Thanks for the in-depth reply. Long distance at 65 doesn't make me smile, but I see other guys are cruising as high as 85. Sooner or later, I'm just going to have to buy on and try it.
    RuffnReadyXJ likes this.
  13. fbritt5
    fbritt5 Been here awhile
    Nov 26, 2009
    219
    Albany, Oregon
    Seat. I've done 450 miles in a day and I'm fine. With the stock seat, you're good for about 25 miles or so.
    Foot pegs, throttle rocker on long trips, but be careful with these. One fall from it getting stuck on my glove around a tight corner. Windscreen, heated grips if its winter time. I have bar risers too do standing up at times. It helps. 70 mph on the speedo and you can cover a lot of road. Thanks.
    Cro59 likes this.
  14. drdubb
    Dec 13, 2009
    2,076
    Don't forget that the speedo is optimistic. a reading of 70 is more like 65.
    mesoman likes this.
  15. shu
    shu ...
    Feb 23, 2010
    1,850
    Colorado
    The DR is an excellent traveling bike, (I've put on more than 100,000 miles traveling on DRs- 2 different bikes) but you have to be willing to use it as it is.
    Cruising all day long, day after day, you'll find that 65-75 is fine (stock gearing) but 85 really gets pretty tiring. Adapt your expectations to the bike, and you'll love it- expect it to be a high speed road burner? it's not.
    ................shu
    TaZ9, mesoman and Cro59 like this.
  16. Cro59
    Sep 27, 2015
    829
    Tucson, Arizona
    Thanks for all the replies. I think we are kind of spoiled in the US and developed West where high speed highways are the norm. In most of the world 65-75 is probably just fine, maybe even too fast. Even in the US, I am trending more towards off highway riding when time permits, so it sounds like a DR would be fine. Now I just need to find the money....
  17. mesoman
    mesoman Been here awhile
    Jul 13, 2015
    851
    California
    Great thread and most questions can be answered within the previous 27 pages.
    I suggest reading it before repeating questions that have already been answered.
    One thing I notice is some DR riders neglect drive line and wonder why the DR feels rough or vibey.
    A few things to consider when doing set up would be: Fresh Cush Drive rubbers, really good, new or new-ish Chain, NEW Front and Rear Sprocket. ALL affect feel and when new, really smooth out the DR.
    Front sprocket wears quickly and IMO should be changed every 8K miles. This will smooth out DR feel, extend chain and rear sprocket life by a lot. Simple and cheap to get the most out of your chain.
    Seats are subjective but anything is better than stock torture rack. I prefer stock gearing most of the time. Easy cruise at 70-75 mph. For off road swap in the 14T. It helps a bit but for true low gearing a different rear sprocket is needed.
    Once out of the USA most times speed averages are far lower, this nearly everywhere in 3rd world.
    I understand why guys like wind shields, but fact is, most add noise. But good in COLD weather, terrible in the heat as they BLOCK air flow. I prefer clean air, no shield, ear plugs always.
    Ride Safe, Ride Long!
    TaZ9 likes this.
  18. pne
    pne Long timer
    Mar 21, 2007
    1,327
    Alberta, Canada
    bumping this thread for some advice. I took my GF out on my mostly stock DR650, we stayed on smooth gravel but the rear shock was still bottomed out almost the entire time and the seat made her miserable after a couple of hours. I'm 170 and she is 110lbs. I was wondering the feasibility of doing a longer 2up trip this summer and what upgrades would need to be done. Specifically to the suspension and rear seat. Which company offers the most padding/comfort? And can the suspension be fixed with new springs or will I need a new shock? Finally, what luggage solutions exist that still allow for 2up?
  19. x32792
    Jun 9, 2007
    2,491
    ^^170 lbs +110 lbs + some gear is a loaded DR650. I might suggest you get your GF her own, lowered 1.4" with OEM option, DR650 to make a long passage. Many good seat options available. Your back and legs will appreciate bar risers (I have Power Mad 2") and Acme Zoom bolt on peg lowering hardware (1" lower, 1 inch back). You might also enjoy some larger, cheap, eBay IMS knock-off pegs. The DR will take you anywhere you point it, including RTW, just not overloaded or real fast.
  20. Rob.G
    Rob.G Mostly Harmless
    Jan 14, 2010
    2,870
    Fulltiming in an RV! Currently Arizona
    IMO, you will be happier if you go all the way with an upgraded shock and spring. I have the Cogent rear shock and the heavier 8.15 kg/mm rear spring and love it. You will want to have Cogent valve the shock according to your combined weight, and hopefully have enough adjustability in it to turn it down for when you ride solo.
    NicorAdv likes this.
