the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. Fishnbiker
    Fishnbiker Tire smuddy, hook swet
    Aug 6, 2005
    2,496
    Campbell River, Vancouver Island, BC, Canada
    OK, now I see why you jilted me on the free beer previous visit. The great cuisine. Got it.
    Nogoodnamesleft likes this.
  2. YukoRider
    YukoRider Adventurer
    Jan 22, 2016
    55
    Yukon, Canada
    Damn! Just threw mine in the garbage last week. On a purge here.
  3. sniffter
    sniffter n00b
    May 22, 2019
    3
    cape town
    thanks drmiller. you reckon that even my depressing the switch (and with no effect) can mean the switch is dodgy? So in other words having no effect....?
  4. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    @Paddle007 posted a video that shows you exactly what parts can go wrong with the side stand switch and how to bypass them.
    drmiller100 and Nogoodnamesleft like this.
  5. mr.jadkowski
    mr.jadkowski Been here awhile
    Jun 8, 2013
    382
    Vermont
    That system works by completing a circuit when the sidestand is in the up position. Anything in the circuit that prevents electricity from flowing will cause the problem you're describing; a physically broken switch, a broken wire or connector, or just corrosion on the switch contacts (ever ride in the rain?). You can test that by bypassing the switch, temporarily or permanently. If you're just doing it temporarily, you can use a paperclip instead of crimping up a little jumper wire like the video suggests. If you jumper the correct wires with a paperclip and it still does it, your problem is not the switch.
    drmiller100 likes this.
  6. mr.jadkowski
    Jun 8, 2013
    382
    Vermont
    I've been giving away a bunch of parts lately, so I'm gonna try to cash in on that good karma: Anyone have a set of straight down peg lowering mounts sitting around that I can buy? I have the plates that take the stock peg mounts lower and back, but my feet want to be forward.
  7. procycle
    procycle Long timer
    Jun 7, 2007
    6,410
    Center of the DualSport Adventure universe
    The side stand switch is a known common failure item on the DR650.
    Your symptoms are exactly what happens when the switch isn't working.
    Also, the diodes in the circuit that connect the sidestand, clutch switch and neutral switch can fail causing a similar problem.
  8. jeepgeek2002
    jeepgeek2002 Long timer
    Jun 7, 2007
    3,386
    Jacksonville, FL
    Note to self: 29" inseams suck.....
    carry on with your tractor posts... nothing to see here
    Nogoodnamesleft and cyberdos like this.
  9. worncog
    worncog YBNormal Supporter
    Oct 19, 2011
    891
    Florida Panhandle
    Did you ever get in contact with those wheels for sale up in Atlanta?
  10. jeepgeek2002
    Jun 7, 2007
    3,386
    Jacksonville, FL
    the guy messaged me but i had already bought wheels somewhere else
    he took like 4 days to get back to me
    he also posted them on the DR650 group on FB
  11. drmiller100
    drmiller100 Long timer
    Sep 29, 2015
    1,688
    Boise Idaho
    a LOT of Dr's have problems with the kickstand switch. if you don't have the problems now, you probably will in the future.
  12. Scribe
    Scribe £Bob£
    Nov 8, 2004
    12,535
    In my natural state
    Thought I'd update everyone on the quest for decent mileage on my stock-carbed '06 so you can get back to sleeping well at night. :D
    Previous episode recap: Replaced DJ needle and jets with stock Mikuni in stock size, plugged up the drilled slide hole, reset the float. Result: 27 mpg city, 34 easy cruising, i.e. complete shit.
    Tore the carb apart (again), replaced the o-ring under the slide guide, o-ring under the cap for the vacuum port, squirted carb cleaner everywhere, blew it out (and right into my eye) with compressed air, put it all back together and reset the float (again), reconnected right side breather hose that had fallen off. Result: 39.48 mpg in mixed riding, including a couple nice full-throttle pulls. I'm calling it 40, so sue me.
    Takeaway: it was either the float level, or the slightly sticky choke plunger causing me grief. I may tinker with the float one more time just to see if I can break that 40 mpg barrier, but at this point it is good enough to carry me 200 miles on an IMS tankful, and that plus my spare fuel bag will allow me to cover the 260-mile, no-gas stretch of the Continental Divide Ride. And that was the goal. Bonus: I can now strip a carb like a mofo.
  13. Tall Man
    Tall Man Priest, Temple of Syrinx
    Jul 14, 2007
    5,881
    The Occident
    @Scribe -- My 100% stock BST-40 returns 48-50 mpg all day long (with a 14T CS in situ, which increases engine RPM slightly).
    Just some motivation for you during your next tinker session. :thumb
  14. procycle
    procycle Long timer
    Jun 7, 2007
    6,410
    +1
    When it's right you should easily get high 40s and even squeeze mid-high 50s out of it with sedate riding.
  15. Schmokel
    Schmokel Key to Happiness: Low Expectations
    Jun 29, 2015
    15,841
    Up. And to the right.
    I was getting 32mpg last year. Tore the carb apart, replaced the pilot jet and rings. I get 42 to 43 with fairly aggressive riding. 14/42 and knobbies. I'll take it.
    Dad gets 60mpg on his KLR with the carb mod and lower tooth on his front sprocket. :bluduh
  16. procycle
    procycle Long timer
    Jun 7, 2007
    6,410
    Did it have a DynoJet needle but no modification to the airbox?
    If so, that would explain a large part of the poor mileage.
  17. joenuclear
    joenuclear Still here....
    Mar 16, 2007
    10,125
    Fort Smith, Arkansas
    Good for you! Inquiring minds want to know if you went to a bigger or smaller hammer?
  18. boulet_boulet
    boulet_boulet Been here awhile
    May 14, 2018
    645
    Maine
    My bike barely passed the state inspection after I promised to change out my brake pads ASAP. Therefore I'll be replacing the front and rear brake pads tomorrow or Saturday. Thanks to Clymer, the Suzuki Shop Manual, YouTube University and a little tinkering, I have a sense of the job and I think I'm ready to tackle it. One area of confusion remains: the (rear only?) OEM pads come with a shim but aftermarket ones apparently do not. I assume that I need to transfer the shim from existing pads if using aftermarket? Is this an easy task or are they likely to be stubborn? Are these shims also likely in need of replacement? Please set me straight because as much as I like going, I also like stopping.
  19. Schmokel
    Jun 29, 2015
    15,841
    Rear brakes are a two minute job. Two allen head bolts. Pop em' out, swap in new pads.
  20. boulet_boulet
    May 14, 2018
    645
    Maine
    Thanks, but what about the shims?
    NC Rick likes this.
