the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    4,376
    Cypress, TX
    Lucky bastard. We won't get that til November... if we're lucky!
    stoney4vida and yehaaa6 like this.
  2. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    10,072
    Anchorage Alaska
    Anchorage this morning:
    There are several fires burning locally so the smoke is very bad now.
    We don't have fire roads so they only fight fires that endanger homes/businesses.
    The fire to the south of Anchorage on the Kenai Peninsula is more than 148,000 acres burned and is 20% contained.
    It started June 5th from a lightning strike and has closed the highway a few times.
    The fires north of Anchorage have destroyed dozens of homes and closed the railroad and highway for hours/days at a time.
    We are in a record drought with less than 1" of rain since July 1st.
    Unprecedented as we usually have more rain days than not in August.
    We have plenty of water, but the forests are dry.
    Several of the fires were started by people, accidentally...
  3. Buckee
    Buckee Scott
    May 17, 2013
    1,413
    Northern Neck of VA
    Consider yourself immortalized.
  4. amp333
    amp333 Life is short enjoy!
    May 21, 2011
    319
    North Bend WA/Coeur d'Alene ID
    Wow, my mom lived only a few miles from the Kenai fire on Funny river road right on the Kenai river. Beautiful area! I sure miss going up there to visit but the winters just wore her out so she moved south to Idaho. Hope they get it under control.
    stoney4vida and JagLite like this.
  5. cogitech
    cogitech Been here awhile
    Jun 5, 2017
    868
    Kamloops, BC
    Mine is way up in the 15-16 kHz range. It always sounds like there is a CRT TV set in my head.
    Nogoodnamesleft likes this.
  6. Buckee
    Buckee Scott
    May 17, 2013
    1,413
    Northern Neck of VA
    Very challenging rides last weekend - they were up & down days if you get my drift. As usual, anytime Blue Suzi goes down on her left side, she won’t start for at least 10 minutes. Down on the right, she starts right up. Shy of draining the bowl, is there any prescribed routine for a successful restart when she’s been down on the left for a few minutes? Is this normal or indicative of an o ring issue? All new rings just last fall. 5.3 Acerbis & Acerbis petcock.
    Chethro likes this.
  7. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,158
    SE Denver-ish
    I just saw this on DRRiders - good stuff. :thumb I knew it existed but wasn't sure where. I also put it in the DR Index (link in my sig) under Links, Write-Ups & Pictoricals.
    https://procycle.us/info/
  8. cogitech
    Jun 5, 2017
    868
    Kamloops, BC
    No idea at all, but my first experiment would be to let it down on its right side after a left side drop and see if it starts better.
  9. William Wolfen
    Dec 5, 2015
    4,376
    Cypress, TX
    It's just flooded. Good the throttle side open while cranking. It'll start before long. Also, turning off the petcock ASAP to reduce flooding can help.
  10. Chethro
    Chethro Confidence is High
    May 11, 2012
    1,822
    NW WV
    Fantastic ride! Only went 60 miles of gravel, dirt and pavement. I hit 5 miles of new black top that was like a roller coaster. What a hoot. Came up to the next section they were paving and the guy said my tires would tear up the new blacktop and asked me to go around...no problem back that same 5 miles woo hoo!
    I changed the oil out for Rotella T6 synthetic yesterday and the bike shifts much smoother. I don't know if it was the new oil or the cooler weather, but the bike was running great. Really torquey. No bugs were out either since it was so cool.
    These were taking out roads I've shown before near Rock Castle WV, but are some different views. I can't wait until the leaves turn.
    The Olympia Richmond jacket did very well too. I zipped the vents up and only had my mesh padded shirt and a tee under it. Even without the liner it was plenty warm at 55 F.
  11. Chethro
    May 11, 2012
    1,822
    NW WV
    I had mine down on the left side for about 15 minutes once while I was in the middle of nowhere. I got her up right waited 15 minutes and it still wouldn't start. Waited another 10 or 15 minutes and nothing. I was afraid of running the battery dead, so I changed a plug. Pulled panels, seat and slid the "full" tank back what a pain. :muutt
    Giving it full throttle is your only hope. Sometimes it works and sometimes it doesn't.
    JagLite and Buckee like this.
  12. Ride Now
    Ride Now Graybeard
    Aug 17, 2011
    534
    Yakima, WA
    So, not working very well, right? :-)
    yehaaa6 likes this.
  13. Paddle007
    Paddle007 Gun Toting Vegetarian. Supporter
    Jun 30, 2008
    941
    S.E. Louisiana
    What carb are you using?
  14. 97707
    97707 addicted to placebos
    Aug 19, 2014
    17,161
    Oregon, USA
    There's a screw to drain the bowl. You can have it done pdq if you have the right driver. Saves waiting and draining the battery.
    Make sure and shut off the petcock first.
    On edit: found a pic.
  15. Fishnbiker
    Fishnbiker Tire smuddy, hook swet
    Aug 6, 2005
    4,241
    Campbell River, Vancouver Island, BC, Canada
    :wings
  16. Buckee
    Buckee Scott
    May 17, 2013
    1,413
    Northern Neck of VA
    Stock
  17. Paddle007
    Jun 30, 2008
    941
    S.E. Louisiana
    I was curious if it was the stock bst. The throttle doesn't open the throttle plate.
    They can be a bugger to get running after flooding with fuel.
    I see your using Redfish Hunters quote. Was he referring to the cold Dixie beer or his wife?
  18. TypeRated
    TypeRated Airborne Adventurer
    Feb 21, 2013
    413
    Central MO
    I posted a WTB in the Flea Market, but it’s going to get buried...
    anyone have a set of stock turn signals, complete stock rear mudguard/plate holder, and a DRZ250 tail light they’d be willing to let go?
    *Also, is anyone here a mod on the DR650SE Riders group on FB? I put in a request to join days ago, but it’s not been approved.*
  19. procycle
    procycle Long timer
    Jun 7, 2007
    9,240
    Center of the DualSport Adventure universe
    :thumb
    That link may change. For sure the individual page locations will change.
    The entire ProCycle web site has been undergoing a complete rebuild from the foundation up.
    The new place should be open for business some time in September.
  20. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,158
    SE Denver-ish
    I'm being a bit pedantic here but - opening the throttle does open the throttle plate, it doesn't open the slide. I have no idea how far the slide will raise at cranking speeds with the throttle held WFO but that's what I do when dropped and it won't start right up.
    The throttle plate can be seen here in the lower left corner, it opens with the throttle - cable controlled. For the observant - the carb is reversed to the engine here, this end faces the engine. :deal
    thump!, JagLite and Anthiron like this.
