the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. JRowland
    JRowland Been here awhile Supporter
    Mar 23, 2018
    804
    Maggie Valley, NC
    My wife said maybe that’s where Bigfoot lives.
  2. procycle
    procycle Long timer
    Jun 7, 2007
    6,713
    Center of the DualSport Adventure universe
    Used stock tanks are cheap and plentiful. There are several choices of larger capacity plastic tanks.
    JagLite likes this.
  3. Jimr80gs
    Jimr80gs Been here awhile
    Feb 19, 2010
    202
    North Central MT
    Thanks. Should have said, this is on hacked DR, upper bracket under tank limits aftermarket.
    This being an rural area at least I've got plenty of JB Weld options, suggestions in that vein?
  4. procycle
    procycle Long timer
    Jun 7, 2007
    6,713
    If you are determined to fix the existing tank use a fuel tank sealer.
    IMO the best stuff comes from Eastwood but POR-15 makes some good stuff as well.
    I would not try to patch it from the outside.
    JagLite and drmiller100 like this.
  5. Jimr80gs
    Feb 19, 2010
    202
    North Central MT
    Thank you.
    Anyone got a 2000 blue stock tank for sale? First choice...
  6. AlH
    AlH Long timer
    May 8, 2015
    3,268
    SC/NC
    I have been scouring the internet today- I cannot find anything about that dam.
    It has to be old and it is quite isolated from any modern day activity. There is a much larger river just over a mile away. Why build it there?
    From what I saw the brief time we were there isn't much held back from it, no lake. Water just runs over the top. Very curious.
    EDIT- I believe I found the story on that small dam and the access door- A large dam and 6.2 mile tunnel was built along the Pigeon River creating the Waterville Lake. This was finished in 1930.
    I found a 1938 map that shows the path of the tunnel- which seems to be hard to find on any modern maps.
    This tunnel, from what I can tell passes directly under the small dam we came across.
    I suspect that is some access point to the tunnel for maintenance.
    Pretty cool!
    The drop from the lake to the powerhouse is about 1000ft- I would suppose that much drop, with about 400psi, would spin the turbines quite well.
    I'm going to keep digging for info.
    Red circle is where we were
    ADDITIONAL EDIT> found some more interesting info- that concrete structure is not a dam at all!
    It encases and protects a 14ft diameter steel pipe the water passes through on it's way to the powerhouse.
    The valley there, formed by Mt Sterling Creek, was deep enough they apparently did not want to go below it- so they went through it.
    Below was captured from the July 14, 1929 edition of the Knoxville Journal.
    Again red circle indicates the point we were at
  7. Jimr80gs
    Feb 19, 2010
    202
    North Central MT
    JagLite likes this.
  8. spklbuk
    spklbuk Been here awhile
    Dec 8, 2007
    847
    SE Almost Heaven
    Measure discharge? Power a sawmill and the pond has silted in? Mongle's ancestors water source for distilling honey dew vine water? :ilmostro
    ER70S-2 and William Wolfen like this.
  9. shu
    shu ...
    Feb 23, 2010
    1,741
    Colorado
    I must be missing something about chain construction here.
    Why does the pin wear in 2 separate, side by side grooves?
    That pin is covered by the outer roller, which is just a loose fitting sleeve, no?
    ..............shu
  10. kbuckey
    kbuckey Long timer Super Supporter
    Dec 6, 2005
    1,619
    Sedona, AZ
    My old DR's chains in miles, all replacement chains were DID, except the 520, which I don't know what it was.
    18517 OEM
    10688 a 520
    18300
    18185
    14546 was pretty much still OK but I put a new one on because I just did the engine work on it.
    6302 currently running
    new DR
    16391.6 OEM
    5256.5 currently running
    And I sometimes oil them and even, on rare occasions, clean them!
    JagLite, Hivernaut and ER70S-2 like this.
  11. Ohio_Danimal
    Ohio_Danimal If I die trying, at least I tried Supporter
    Dec 20, 2009
    3,723
    Cuyahoga Falls, Ohio (The Crooked River)
    Many designs have two grooves on the interior ID of the roller. To “hold” lubricants
    Hivernaut, ER70S-2 and shu like this.
  12. Ohio_Danimal
    Dec 20, 2009
    3,723
    And to be fair, chain life has a lot to do with riding “style” and abuse.
    My SV650 which I sold prior to the trip, had 237,000 miles on it. And I used to track chains and consumables on a spreadsheet too.
    Smooth riding. Smooth acceleration. Smooth braking. Proper slack. So many things affect chain life. But riding hard, allowing the chain to accept the abuse of your choices of when to shift or brake, staying on throttle over that sharp edge, cleaning when dirty, etc....all play a part and are hard to quantify
    JagLite, drhippie2 and ER70S-2 like this.
  13. Nobade
    Nobade Keep on keepin' on...
    May 30, 2012
    1,109
    Albuquerque, NM
    I got one of these kits:
    https://www.por15.com/
    from Eastwood to do my TW200 tank. It will certainly seal it, and fix any rust you might have.
    If you subscribe to their email you can get a big discount on your first order.
    Oops, 205'd by Procycle...
  14. biker128pedal
    biker128pedal Super Lurker
    Dec 20, 2008
    6,214
    Eastern, VA
    This is from the OEM chain on my Vstrom but shows how the rollers wear the pins. Back in 2001. Sorry the side plate is off the end of the pins.
  15. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    16,978
    SE Denver-ish
    I flew RC planes for a short while (I hated building them and everyone crashes). One of the more 'frugal' flyers broke the carb off his engine. In an effort to avoid spending money on a new motor that he couldn't afford, he JB welded the carb back on. The JB weld held for the two years I was there and still running when I left.
    After seeing that, I'd use JB weld to hold the Space Shuttle together. :nod So I'd clearance whatever rubbed the hole, clean the surface and JB that beotch. Note that I'm a day rider, any failure will only inconvenience me for a day BUT dripping gasoline on a hot engine could ignite and ruin more than your day - YMMV, use at yer own risk, you din't hear it from me, nothing sticks to a plastic tank, yada yada yada. :uhoh The OP should buy a replacement tank. :deal
    Fishnbiker, NC Rick, JagLite and 3 others like this.
  16. Mongle
    Mongle Knuckle dragger
    Dec 4, 2009
    11,592
    North Carolina Y'all
    I am of the mindset the chains do stretch. Reason being is that you measure from pin end to pin end. Only way that can change is if the side plates stretch. Once stretched it causes heavy load on the rollers which causes the wear you see above...and the quicker wear at the end of it's life.
    dcwilcox, drhippie2 and shu like this.
  17. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    16,978
    SE Denver-ish
    Good point. :hmmmmm :scratch
  18. AlH
    AlH Long timer
    May 8, 2015
    3,268
    SC/NC
    gpfan and spklbuk like this.
  19. Chip Seal
    Chip Seal Long timer Supporter
    Aug 18, 2004
    3,163
    Western Orygun
    Not sure what you are asking?
    I have a Clark tank, 4.9. Loop the wire harness above the knob that slides into the tank. Have had it 6 years, no issues on wear etc. Loose fit zip tie holds harness in place.
  20. procycle
    procycle Long timer
    Jun 7, 2007
    6,713
    Especially since there are TONS of stock tanks that have been removed from nearly new bikes.
    My own opinion -- a reasonable price for a stock tank should be between $50 and $100. High end for something very nice, low end for one that is scuffed up but usable.
    JagLite and ER70S-2 like this.
