the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. Nogoodnamesleft
    Nogoodnamesleft Long timer
    Jun 9, 2015
    6,884
    Brisbane
    :hmmmmm.. hmm..
    i know..
    ROAD TRIP..!!
    we could ride to japan..
    made from icebergs and seaweed and flowers.
    i bet it tastes just as delicious as @cyberdos regular blue fizzy..
    Nobade likes this.
  2. JRowland
    JRowland Been here awhile Supporter
    Mar 23, 2018
    926
    Maggie Valley, NC
    gpfan likes this.
  3. NC Rick
    NC Rick Cogent Dynamics Inc
    Aug 31, 2007
    6,979
    Asheville, NC
    I’ll send you one for shipping. It has a smallish dent from my knee.
    kbuckey, Sonny S., MikeFromMT and 5 others like this.
  4. Jimr80gs
    Jimr80gs Been here awhile
    Feb 19, 2010
    208
    North Central MT
    Rick, thanks. PM sent.
    Jim
  5. drmiller100
    drmiller100 Long timer
    Sep 29, 2015
    1,800
    Boise Idaho
    I am NOT overtightening it. a bit loose? probably. not ignorantly loose though.
    ER70S-2 likes this.
  6. Nogoodnamesleft
    Jun 9, 2015
    6,884
    Brisbane
    i think it's a little bit of column a, and a little bit of column b
    the combo effect. minute stretch and wear adding to each other causing stretch and slop, due to design.
    a little bit like if you have a length of steel strap then bend it, then straighten it, it can become marginally thinner on the bend points and thus minutely longer when straightened - the side plates in a chain. wear on steel also makes it thinner and easier to stretch under load forces. then add pin wear.
    sort of like timing chains, belts and solid gear drives.
    if you have over spec run out say from the crank and you can't run solid safely,
    not efficient / safe for direct drive set ups, then there's belts and double rows for the lesser spec or simply for design and cost.
    run out to me, is a bit like but not the cush hub rear wear and slop and then the front sprocket play on the spline,
    both combined with the slow variables of wear caused on the chain by minute slow flex to stretch over time,
    due to the length of the chain between sprockets and induced side loading due to drive and weight.
    but don't pay any attention to me.
    i can't even remember the last time i lubed my DR's chain..
    it could be 3 years and about 12k.. dunno..
    i'm just cranky because i found my GPS phone, and it no longer works..
    looks like it may or may not have been dropped..
    someone needs to un-invent the word "update".. stupid new phones.
    at least i found my paper maps.
    Hivernaut, drmiller100 and Mongle like this.
  7. Pastapete
    Pastapete Adventurer
    May 24, 2018
    15
    Australia
    dcwilcox, Hivernaut and JagLite like this.
  8. drhippie2
    drhippie2 Adventurer
    Jan 6, 2019
    55
    Coldwater, MI
    Got two blue tanks both with light scratches.. willing to part with for low $$$..
    04 and 05 graphics....
    PM me if needed...
    Jimr80gs and JagLite like this.
  9. Mongle
    Mongle Knuckle dragger
    Dec 4, 2009
    11,746
    North Carolina Y'all
    20+k on my chain. Mine is so loose I still have the upper roller...intact. :D. I can take the small sprocket off without loosening the axle.
    I feel the DR chain geometry isn't great and looser is better. Manual specs need multiplied by 3 or 4...
    Nobade and drhippie2 like this.
  10. drmiller100
    Sep 29, 2015
    1,800
    Boise Idaho
    Well hell. Your 520 ek chain got about identical miles I've been getting. I am fatter than most, and probably ride harder than most. Never cleaned a chain in my life.
    Looks like I'll run a vx2.
    what is the difference between did vx2 and did GOLD vx2? EDIT: one is gold colored, one is natural. I asked my scooter and it didn't indicate it cared.
    any negatives to a 525 on 520 rear sprocket?
  11. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    11,901
    Snowy Mountains Oz
    Have you actually measured sideplates that have got longer over time? Seems a 'stretch' to me that they do :D
    Others have done it, I've always run the right width sprocket for the chain. It might move about enough to interact with the chain guide, dunno.
    I was disappointed with the life of the EK SRX chain. I got, I think, 3 at the time. One is on my wife's KLX300 which doesn't get the flogging, or travel the distance other bikes in the fleet do, and its OK so far, but < 2k kms only.
    There was a clear out of 520 VX2 chains here a while back and I think I got 6, they were less than half price. It doesn't take long for the gold ones to look much the same as the natural ones on my DR, so much of a muchness.
    drmiller100, JagLite and Hivernaut like this.
  12. amp333
    amp333 Life is short enjoy!
    May 21, 2011
    176
    North Bend Washington
    I've got a 2000 tank and can send you pics if you want. All I'm looking for is shipping as well. I'm in New Mexico for my dad's 90th birthday so it would be next week.
    ER70S-2 and Jimr80gs like this.
  13. Mongle
    Dec 4, 2009
    11,746
    True. Hard to believe there is enough wear in the pins alone to "elongate" the chain enough to be measurable.
    Was just a thought.
    I know a new timing chain will "stretch" enough to retard cam timing 1-2 degrees during the first run in. Then it seems to take a set and not move for many thousands of miles. I can't say exactly where said "stretch" occurs because I have never tried measuring the chain. Nothing can be done about it (unless you step up to a timing belt) so I just plan for it.
  14. kezzajohnson
    kezzajohnson kezza
    Apr 17, 2007
    3,856
    Cairns - Queensland Australia
    Nope, I have been on that combo (525 chain on 520 rear sprocket) for a while now, mostly because I couldn't get a 46 tooth in a 525 (18 inch rear wheel) - no signs of anything untoward.
  15. AlH
    AlH Long timer
    May 8, 2015
    3,319
    SC/NC
    What is interesting too is the spot we stopped is the middle of the tunnel route as the crow flies. The tunnel is a straight line to that point from the lake then jogs west a little then gets a few curves before the powerhouse so it isn't exactly the midpoint inside it. tunnelmidpoint.JPG
    Plot of our ride and line drawn on Topo North America. A great product that Garmin killed when they bought Delorme.
    Actual complete tunnel route on the 1938 map
    ER70S-2, gpfan and JRowland like this.
  16. boulet_boulet
    boulet_boulet Been here awhile
    May 14, 2018
    924
    Maine
    The foliage is stunning up here in Maine right now. Here is a nice shot that @Grinnin took of me on a ride yesterday.
  17. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    15,890
    Tri- Cities TN
    I've seen them in the area. Paint Creek area in TN (just over the hill from the gated hole in the dam)
  18. 805gregg
    805gregg Long timer
    Jan 14, 2006
    2,256
    Ojai, Ca
    Go back to a 525 and get a DID ZVM-X chain, 520 is what Suzuki puts on the DR200
    ER70S-2 likes this.
  19. adam728
    adam728 Long timer
    Dec 1, 2014
    2,334
    Michigan
    520 is also on a 50+ hp RMZ450.
  20. Jimr80gs
    Feb 19, 2010
    208
    North Central MT
    Thanks. Already called Rick before I saw this post.
    This is a great group!
    dcwilcox, drhippie2, JagLite and 3 others like this.
