1. eNewsletter Sign Up
the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. adam728
    adam728 Long timer
    Dec 1, 2014
    2,368
    Michigan
    Oil is a big deal. And by that, I mean a manufacture definitely does not want to recommend something that could increase warranty claims, or worse, cause excess wear or deposits that cause an emissions failure.
    I've worked with a number of engine manufactures and witnessed a few oil tests. It's serious stuff. They might pay a 3rd party tens of thousands of dollars per engine to run durability. Or test 3 or 4 oils in house, across 50 or 100 engines per oil. It's not taken lightly!
    And then in engineering half the time whatever is on hand in a weight that's "close enough" gets dumped in test mules, because "that's what the customer is going to do anyway."
  2. Donniejoe
    Donniejoe Adventurer
    Feb 6, 2016
    61
    The Arkansas Ozarks
    I'll be glad when the weather warms up and we can talk about the stupid stuff we did while riding today.
  3. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,099
    SE Denver-ish
    Note that the DR has 'lazy' steering - the stock geometry has the forks well 'laid out'. If you get energetic, try raising the back end back to stock to see if it sharpens your steering. This is strictly theory on my part (and doesn't allow for the smaller front wheel) and if it induces a speed wobble, I'll deny ever thang. But if it doesn't you might have an exceptional canyon carver … maybe … :D We got men on the moon by taking chances, so are ya feelin' lucky - well, are ya?
    Any second opinions? :ear
    How did you drop 41 pounds from the 366 listed by Suzuki? Half a tank only drops 1.7 gallons, or about 12 pounds. Inquiring minds want to know. :lurk
    William Wolfen, NC Rick and psmcd like this.
  4. joenuclear
    joenuclear Still here....
    Mar 16, 2007
    10,233
    Fort Smith, Arkansas
    I'm not seeing your pics. Dunno why.
    Redfish Hunter and ER70S-2 like this.
  5. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    12,248
    Snowy Mountains Oz
    Annoyingly, a seeming random issue with Google pics. This one will work:
    JagLite and Nogoodnamesleft like this.
  6. OdinTheWise
    OdinTheWise WOLVERINES!!!!
    Apr 20, 2019
    30
    virgo supercluster (SE Michigan)
    what is the average MPG you guys getting from the acerbis 5.3 and 6.6 gal tanks. i cant find good info on what the reserve point is for these tanks either.
    Anyone likes this.
  7. joenuclear
    Mar 16, 2007
    10,233
    Yes it does!
  8. TaZ9
    TaZ9 Been here awhile
    May 29, 2007
    903
    Northern Colorado
    OK, I should be working on my taxes, but I like to use any excuse to put it off, so here we go. While looking through my photo files, I found some pictures of my DR650 "squealing starter fix" from a few years back. I know this subject has been cussed and discussed here many times, but the difference in the way I did mine is super simple and quick compared to many others that I have read where some have even removed the exhaust and the cam chain tensioner. The secret is you don't have remove anything other than the tiny bolts that hold the clutch cable retainer plate to the starter cap, the starter cap retainer bolts, and the lower oil line banjo bolt.
    This is made easier by using a 1/4" drive handle that easily fits in the tight spaces. First remove the clutch cable retainer plate, then the starter cap bolts. Remove the oil line banjo bolt, being careful to save the copper washer, then remove the starter end cap (see photos). No worries, nothing will go flying when the cap is gently removed. You can now visually inspect the starter for debris or wear. If all is good, apply a small dab of grease in the end cap and re-install. Then attach the clutch cable retainer plate and the oil line banjo bolt and copper washer. Double check your work, and you're ready ride. If someone has previously posted this abbreviated method to fixing this problem, then lets get back to the usual discussions about oil, tires, and how much we hate winter weather.
    Ride safe,
    TaZ9
    remove starter end cap with drive handle and socket.jpg oil cooler line removal.jpg remove replace end cap.jpg end cap off.jpg IMG0008.JPG IMG0005.JPG
  9. cyberdos
    cyberdos Easy Bonus Loop ♦♦
    Sep 2, 2005
    48,076
    Queen Creek, AZ
    I hate to interrupt such interesting oil debates but I have a matter of great importance to deal with. In my quest to replenish my much depleted 'tool' kit I am faced with a tough decision. While I'm certainly not a pretencios type of fella I do admit that switching to cucumber and tea scented does sound quite extraordinary.
    My dilemma, of course, is that when I ran this idea by my wife she was intrigued by my sudden shift from beign normal to wanting to put cucumbers in my butt.
    Made me second guess myself.
  10. Schmokel
    Schmokel Key to Happiness: Low Expectations
    Jun 29, 2015
    17,320
    Up. And to the right.
    I've got three cases, yes cases, of those in the closet. :D
  11. psmcd
    psmcd Long timer
    Aug 27, 2012
    1,978
    Pendleton, OR
    Rick shortened my Ohlins about 1/2" to stock length on revalve and service but I had been running it long for past 5 years with no ill effect. Only speed wobble I ever experienced was with stock suspension on washboard gravel.:eekers With proper springs and damping I think what you suggest would be a go.
    JagLite, ER70S-2 and AK650 like this.
  12. cyberdos
    Sep 2, 2005
    48,076
    Queen Creek, AZ
    On the 6.6 I'm getting around 225 miles to reserve. No idea how much to empty from there as I have yet to completely run out. 250 something was when I filled up last.
    yehaaa6 and AK650 like this.
  13. OdinTheWise
    Apr 20, 2019
    30
    what MPG you get usually. i am trying to decide if i want the 5.3 or the 6.6 and deal with the goofy looks
  14. cyberdos
    Sep 2, 2005
    48,076
    Queen Creek, AZ
    Mid to upper 30s typically. 44 was the best I've recorded. I've been running stock gearing now for a couple of months.
  15. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    1,375
    Alaska
    Looks like an excellent job to me! And hell for stout. Also reminds me that I need to get longer bolts as well, as they stand off the bike a bit more than the stockers.
  16. cyberdos
    Sep 2, 2005
    48,076
    Queen Creek, AZ
    ...and they do stretch a little.
    JagLite likes this.
  17. MattR302
    MattR302 Awesomeness, Inc.
    Jan 2, 2009
    481
    New Haven, CT
    These stocked at the Suzuki dealer or the KTM dealer??
  18. Daniel3640
    Daniel3640 Moto_Dans
    May 31, 2015
    136
    Ashburton, New Zealand
    Most I have done on my 6.6 is 520kms and still not hit reserve took 24 litres to fill r(I mine must be stretched ) reckon I could reach 600kms without to much drama. No idea what that works out in mpg but I'm happy enough.
    Nogoodnamesleft likes this.
  19. TrophyHunter
    TrophyHunter Long timer Supporter
    Aug 30, 2009
    3,784
    San Diego
    @cyberdos is riding a 790 kitted DR - this could effect things.
    My DR650 has a stock carb, uncut airbox with snorkel still in it. GSXR "040" exhaust, no header weld grind. Loaded on the ID BDR and lightly loaded for daytrips at Moab - I got 52-56 MPG. I run the 6.6, so very safely 300 mile range. I had the 5.3 on my last DR but I never checked the MPG - highly modded.
    I like the looks of the 5.3 better but I just wanted the "wonder what's down that road" extra gallon or so. Honestly, I haven't used it but it's also been nice to have on rides where others may be pushing their fuel limits a bit as a buffer.
  20. ADVBedouin
    ADVBedouin fly pelican!
    Aug 2, 2009
    757
    CA. Central Coast
    Agreed on the handling..the 18” rear & 805 tire combined w the 19” front steepened it & it feels sharper & more planted on turn-in..it’s likely psychological too.
    I dropped @40 lbs by deleting everything I didn’t need, & weighed it on three different scales to be sure...kind of did it to see that a light DR is as capable as any of the newer bikes in twisties without all their hi tech efi/abs/tc bs, but mainly I just like a lighter bike.
    I deleted the stock grab bars, rear fender/lic plate brkt, taillight, steel handlebars/bar ends, fork spacers, stock foot pegs & mounts, pass pegs/mounts, blinkers, mirrors, chain guard/sprocket cover, mounts, helmet lock & mount, stock muffler, speedo/cable, tool bag, all evap stuff & misc bits...stuff adds up.
    I still want a (grey) Clarke tank, lithium battery, 7” round Hella...it friggin never stops.. :-/
    wilfred, drhippie2, ER70S-2 and 9 others like this.
