the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. procycle
    procycle ~Retired~
    Jun 7, 2007
    11,527
    It ain't New and it ain't Mexico
    It must be me. I don't know any other Corvette drivers that would let their tires get dirty.
    Ya know, that Vette will put an ass whuppin' on the Talon (as long as there's no rocks, etc). It really is a very good tool for frightening a passenger :bmwrider
  2. JRowland
    JRowland joyrider Supporter
    Mar 23, 2018
    9,201
    Maggie Valley, NC
    20* tonight :vardy
  3. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    3,531
    Alaska
    It's 33* in Alaska...........so there!
  4. Lil' Steve
    Lil' Steve Every day is Saturday
    Oct 3, 2006
    6,164
    Gilbert, AZ
    You're the only person that came to mind when I saw a Vette in an OHV parking area! I ain't got nothin for a Vette on any relatively smooth surface, but I'd pay admission to see one try the Montana Mountain loop.
    Above freezing in Alaska but snow in Tennessee and NC? :scratch
    JagLite, Redfish Hunter and procycle like this.
  5. Nogoodnamesleft
    Nogoodnamesleft Long timer
    Jun 9, 2015
    12,072
    Brisbane
    For carb I think procycle sells most bits..
    Be worth cleaning the filter and checking the valves first as well.
    For the noise I'd check the easy stuff first. Check chain tension.
    Sometimes there is a top roller if it hasn't been removed, the stock ones - bottom if only one left can make a strange think sound, I swapped over my bottom one.
    Then have a look on the rear shock and check the bump stop hasn't risen or perished.
    There's a big washer underneath that can clank around under load going over bumps.
    Sometimes it reseats and is hard to nail down. But check the stop is snug.
    It is a fairly loud clank noise , like metal on metal tools.
    If it's not something loose on the bike, internal is hard to diagnose online, as everyone describes things differently.
    Weldr, drhippie2, NC Rick and 4 others like this.
  6. Nogoodnamesleft
    Jun 9, 2015
    12,072
    Brisbane
    Does he work on stuff for a 650 though ?? :D
    He seems a bit precious with that whole, must be a 790 thing..:lol3
    JagLite, NC Rick, RedEX and 5 others like this.
  7. psmcd
    psmcd Long timer
    Aug 27, 2012
    3,765
    Pendleton, OR
    Chain slap is a possibility. Does the sound go away as rpm increases? The DR likes a little more rpm than you might think for a big single. Best thing would be to get a local inmate to have a look/listen. Who we got in Naples? What's become of Kommando these days?
    drhippie2, ER70S-2, yehaaa6 and 2 others like this.
  8. AK650
    Jun 26, 2013
    3,531
    Alaska
    Sadly, that will change this weekend. Supposed to hit -2F on Sunday.:(
    JagLite and NC Rick like this.
  9. Fishnbiker
    Fishnbiker Tire smuddy, hook swet
    Aug 6, 2005
    5,394
    Campbell River, Vancouver Island, BC, Canada
    West Coast rocks ...
    Culvert washout ...
    Abandoned logging road ...
    Lakefront logging road ride ...
    Hillclimb cut short ...
  10. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,711
    Up. And to the right.
    It's -5°F right now.
    Ya.
    JagLite likes this.
  11. Paddle007
    Paddle007 Gun Toting Vegetarian. Supporter
    Jun 30, 2008
    997
    S.E. Louisiana
    Drain the oil and inspect it for metal shavings. This will likely ease your mind with the internals.
    Congratulation on your bike. Very similar to what I did. I remember the test ride and being concerned with noises.
    Many of us use a magnetic drain plug which can catch a failed part before it's catastrophic.
    As others have suggested don't lug the engine.
    Does it have a bash plate?
    The things are designed by some demented engineer to amplify the smallest noise and direct it the riders ear.
  12. RedEX
    RedEX NeverSatisfied
    Apr 25, 2007
    2,129
    S.E. Michigan
    Yea Schmokel, ya better have your Cogent upgrades in for that! :D
    JagLite, Lil' Steve, JRowland and 2 others like this.
  13. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,711
    Along with getting my head checked.
  14. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    6,491
    Over here
    You saw what they did to Matt right ? I forget his screen name. Flipped the DR on a hill almost landed on a cactus sold DR guy.
  15. SloSolo2
    SloSolo2 Long timer
    May 10, 2006
    2,604
    Fort Mill, SC
    @psmcd beat me to it but I suspect an overly loose chain. That said, just about anything wrong with a DR is simple to fix. Maybe you can post up a video of the noise?
    It is possible that your NSU screw(s) are bouncing around in the gearbox which you will want to address ASAP if that's the case (This is unlikely since I think you'd hear it in every gear). Getting to the NSU for an inspection is pretty easy unless you tear the gasket. In short remove the clutch cover, clutch and basket, safety wire or loctite the screws and reverse the process.
    Assuming you don't have a magnetic drain plug drain the oil into a clean pan and run a magnet through the oil to see if you get a lot of shavings. If not then I doubt the noise is anything expensive.
    On the carb rebuild; look into shimming the needle while you have it apart. If you want to have a more beastly machine then get a jet kit and airbox cut diagram. I like mine fine with just the shim.
    Make sure you look at the little carb breather filter it will likely be rotten and possibly missing entirely. I and many others have cut up a lawn mower filter to replace the foam however you can order replacements.
  16. Lil' Steve
    Oct 3, 2006
    6,164
    Gilbert, AZ
    And we're off....
  17. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,156
    SE Denver-ish
    Bad carburation can cause all kinds of ugly vibrations. Unless it's been sitting a long time, it's likely that it will 'look' clean inside but there are two areas of conern - 1. Float bowl O-rings. At least one is proprietary so you'll have to get them through Suzuki or ProCycle. Replace these no matter how good they look. 2. Pilot jet - this is most likely your problem. It's usually recommended to replace the jet, the orifice is super tiny and any scratches in that bore will mess with your jetting. My pilot got gummed up sitting for 29 days and I know it was the pilot because a quick replacement fixed the problem. I keep a spare handy. Ethanol SUCKS. :bluduh
    Driveline vibration - could be your upper chain roller, remove it and replace with a set screw, not anything with a head - even a button head will get hit by the chain.
    Fixt and QFT :uhoh
  18. Schmokel
    Schmokel Long timer
    Jun 29, 2015
    17,711
    In regards to noise on the DR, once I installed the skid plate it sound like bolts inside a coffee can. Think its just the sound of the bike. I lined the inside of the skid plate and it dampened the sound a bit.
  19. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    13,122
    Anchorage Alaska
    Noisy, expensive sounding engine sounds? :yikes
    My fix is simple, inexpensive, and works great. :thumb
    Earplugs :jkam
    Lil' Steve, shu, ER70S-2 and 8 others like this.
  20. JagLite
    Jun 17, 2010
    13,122
    Anchorage Alaska
    Today the weather forecast is
