the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. Road Barnacle
    Road Barnacle Been here awhile
    Oct 5, 2017
    754
    Burnsville MN
    The lack of internal support can be a good thing. I have a similar CH bag with the bungee mount and a small pelican case. When I need the extra storage I just unravel the CH bag and strap it in place. Otherwise it stays balled up and out of the way.
    sarcoid, JagLite and LexTalionis like this.
  2. NC Rick
    NC Rick Cogent Dynamics Inc
    Aug 31, 2007
    11,089
    Asheville, NC
    I got the hint about “freeing up space”.
  3. Fishnbiker
    Fishnbiker Tire smuddy, hook swet
    Aug 6, 2005
    4,260
    Campbell River, Vancouver Island, BC, Canada
  4. Ohio_Danimal
    Ohio_Danimal If I die trying, at least I tried Supporter
    Dec 20, 2009
    5,900
    Cuyahoga Falls, Ohio (The Crooked River)
    Dunno yet. Will report back when I start work.
    JagLite likes this.
  5. Chethro
    Chethro Confidence is High
    May 11, 2012
    1,841
    NW WV
    A little shed time this morning. Thanks @BergDonk, i used your valve adjustment procedure again. Now I have to wait until Wednesday to put on some Bikemaster heated grips. :D All that's left to do this winter is an oil change and to clean the filters.
  6. sandwash
    sandwash Long timer
    Oct 26, 2007
    3,417
    Az 7000'
    Ohm it out before you start it and after it warms up, green and blue wires. Resistance 170-256 ohms @100 range on the meter( this is from the service manual) Mine was in range before start, (it did start) but after it was warmed up it was on the high side and out of spec. Give it throttle and 60+ feet and it would shut off. Maybe guess work on my part, but that was the fix and it's been 4-6 years and no problems.
  7. Tall Man
    Tall Man Privileged.
    Jul 14, 2007
    8,046
    The Occident
    Are those Tom's Moto-Racks on your DR?
  8. Road Barnacle
    Oct 5, 2017
    754
    Burnsville MN
    yes … They are a little on the pricey side but I was won over by the fact they are somewhat minimal and have the rotopax mounts. They are versatile and the fit/finish is top notch.
  9. TrophyHunter
    TrophyHunter Long timer Supporter
    Aug 30, 2009
    4,141
    San Diego
    I printed Jim's document and carry it on the DR with a spare coil and a few other things specific to the job. When I cracked mine open to change the screws to allen heads, it'd already been done. I wasn't quick enough with the washer Jim warned about and had to go fishing. Suzuki put that thrust washer directly above an opening into the transmission. I did find a magnetic tool that will fit into the slot - which now goes with the pulse coil kit.
    https://www.amazon.com/gp/product/B002YKNOLQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Pic is with the rotor off - probably could be done with it on.
  10. x32792
    x32792 Cracker American
    Jun 9, 2007
    2,848
    Winter Park, Florida
    Just emailed Tom to ask if he offered something minimal on the left side to carry a rotopax ..."Get the rotopax away from the exhaust, off my rear rack and lower the center of gravity of the loaded bike."
    Will share his response.
    JagLite likes this.
  11. Tall Man
    Jul 14, 2007
    8,046
    The Occident
    I've the same pannier and top racks on my DR, and I too am well-pleased with their construction and fit. They were perhaps the last set Tom fabricated before his accident in Sept. 2016, which affected his production capability until 2020 (IIRC). The RotopaX mounting plates, now standard, were extra-cost options when mine were purchased.
    Recommended.
  12. BergDonk
    BergDonk Old Enough to Know Better
    Nov 15, 2010
    16,225
    Snowy Mountains Oz
    My take on heated grips FWIW. Living where I do, they've been essential since the early '80s when I discovered them. On my dirtier bikes, like the DRs, I prefer to keep my dirt bike grips of choice, so film type heaters are the go.
    Add some heat shrink to the left bar end. The knurling means it grips fine, if not, add some contact adhesive before the heat to be sure.
    Warp the heaters on and use a few zip ties to keep them in place.
    I use some brake cleaner as a lube to slide the grips on.
    Then a few wraps of stainless tie wire keeps them secure., along with the residual adhesiveness of the brake cleaner.
    For control, I've been using the Bikemaster/Tusk 5 setting controller and its associated wiring harness. I just cut the grips off that come with the kits and attach the films. Works great, I have this setup now on 4 of my bikes, and a couple of mates' bikes too.
    sarcoid, JagLite, JRowland and 9 others like this.
  13. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    4,393
    Cypress, TX
    So I got followed home today...
  14. LexTalionis
    LexTalionis Inciteful
    Nov 3, 2008
    887
    Ochoco & Tahoe Nat'l Forests
    https://www.pmracks.com/
    I have these on both my DRs, and on both DRs I needed to install a ~1" spacer and longer bolt on the lower left connection point for the left side rack to line up properly. Other than that, very strong, well made, attractive.
    sarcoid, JagLite and Fishnbiker like this.
  15. procycle
    procycle Long timer
    Jun 7, 2007
    9,276
    Center of the DualSport Adventure universe
    Wow :clap
    JRowland and NC Rick like this.
  16. William Wolfen
    Dec 5, 2015
    4,393
    Cypress, TX
    It's for my mom. 2 up bike. Inaugural ride to eat for us tomorrow!
  17. hock2e
    hock2e I'm a crastinator, still holding off on going pro
    Sep 29, 2015
    278
    The Circle City, Dothan Alabama
    So why is there a half eatin samwitch on the seat ?
    JRowland, NC Rick and Sonny S. like this.
  18. William Wolfen
    Dec 5, 2015
    4,393
    Cypress, TX
    Because I was halfway through eating it when I took the picture. I was making room in the garage and sitting up the front tire (the shop didn't put enough in it) and my mom brought out a peanut butter sandwich for me.
  19. SR56
    SR56 Long timer
    Feb 7, 2013
    6,679
    NW Florida
    "Mom" is going to enjoy that bike :-).
    JagLite likes this.
  20. William Wolfen
    Dec 5, 2015
    4,393
    Cypress, TX
    She's quite excited. I know y'all aren't gonna believe me, but I didn't get it for me. I'm happy with my Africa Twin for riding solo.
    stoney4vida, kbuckey, JagLite and 2 others like this.
