The F800 ST ---- The Storm Trooper Bike Build
Discussion in 'Parallel Universe' started by Lost Roadie, Apr 6, 2011.
  1. Lost Roadie
    Lost Roadie Rider
    Oct 15, 2006
    3,708
    Kernville, CA
  2. WoodWorks
    WoodWorks House Ape
    Feb 11, 2003
    2,811
    Ashland, OR, USA
    Oh man, this is gonna be so cool! I'm definitely subscribed to this one! :tb
  3. dendrophobe
    dendrophobe Motorbike Junky
    Nov 30, 2008
    859
    Ypsilanti, MI
    Subscribed! Can't wait to see more, this already looks great!
    I can't wait to see what you do with that headlight... I'm tempted to try the same myself after you pave the way! :lol3
  4. Trout
    Trout Been here awhile
    Nov 24, 2008
    341
    SoCal (91356)
    Epic rebuild! Can't wait to see what comes of this!
  5. EnderTheX
    EnderTheX Dirt Rider
    Mar 14, 2009
    2,821
    DFW Area, TX
    Awesome!
    I bet this will turn out to be the best Zombie Apocalypse survival bike ever!
    :freaky
  6. rc mad
    rc mad Physycotic gecko
    May 9, 2006
    1,748
    Deeping About
    :clap I so want one of those 8" lights
    Think it may look out of place on a guzzi v50 tho :lol3
    I read through your other thread not long after i'd fitted a f800 low fender to my f650 dakar, talk about butt clenching :eek1 Glad you came out of that almost unscathed.
    Can't wait to see wht the bike look like when it's done
  7. angellr
    angellr Adventurer
    Apr 25, 2010
    23
    I'm in as well! Should be quite interesting to see how this one turns out ... love that tank/light combo so far.
    -Bob-
  8. itsatdm
    itsatdm Long timer
    Jun 19, 2004
    5,440
    Nor Ca.
    The Lithium batteries are so light, it may not matter, but I have wondered if they would fit behind the cylinders where the charcoal canister resides. There are some threaded holes for a tray. Heat is not supposed to hurt them.
    I know you are thinking single rotor and have questions about the master cylinder. You might take a look at the caliper for one of the 800 street models. 4 piston brakes vs 2 might give you plenty of stopping power. The mounting flanges are different but the mounting holes are close.
    For as heavy as this bike is, there is not a lot to strip off that weighs that much. A rotor. a caliper, narrow lightweight rims, battery replacement. The plastic is lightweight. I figured at about $100 per lb.
    Looking forward to the project.
    #8
  9. lmclamore
    lmclamore Citation Collector
    Jul 9, 2010
    412
    Washington DC area
    One thought on your gas dispensing idea (which I like)...Are you locking yourself into always having a high CG when the aux tank has more fuel than what's below? You will need to use your reg tank's fuel to make room for the aux fuel. Worst case...right before you transfer fuel...your CG will feel very high. Is there any way to draw from the aux tank first is where I'm heading with this?
    Or did I miss something?
    #9
  10. dendrophobe
    Nov 30, 2008
    859
    Ypsilanti, MI
    Color? Are you going with white again?
    What are your plans for a windscreen? Stock? Desierto III? None?
    #10
  11. Motorfiets
    Motorfiets Long timer
    Oct 1, 2007
    2,981
    Southern California
    subscribed!!! :lurk:lurk:lurk
    btw.... line-x sprayed my TT tank.... LOVE IT!
    #11
  12. Wildman
    Wildman Long timer
    Feb 12, 2007
    19,919
    Awww no! This is going make me want one of those tanks again!
    #12
  13. Two Moto Kiwis
    Two Moto Kiwis Homeless Somewhere
    Apr 12, 2007
    4,396
    Wanaka, New Zealand, ....What Trip!!!
    Well cool and groovy, I have a sneaking suspicion you are about to build what a lot of people would want and with a cool canvas to start with.
    Definitely keen to see your work, I have built a few good customs and can appreciate the level of work too, game on!!
    #13
  14. Wildman
    Wildman Long timer
    Feb 12, 2007
    19,919
    #14
  15. lmclamore
    Jul 9, 2010
    412
    Washington DC area
    I agree that having your fuel pump working when it isn't needed is a bad idea. Is there any way to route a selector in-line before the fuel pump, allowing you to switch between tanks at will? I know if this was easy it would be marketed and readily available but this is a chance to truly customize, right?
    If some version of this idea is po$$ible and you retain your independent fueling capability idea...Wow! You could go into the off-road rescue business.
    #15
  16. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,492
    On a RTW ride - currently touring the U.S.
    Sounds great Finn, I'll be watching.
    If you can find a set, the actual Super Enduro forks would be pretty much ideal for your bike. They are about 25 mm longer, if you drop them in the clamps a bit they should be spot on and add 20mm of travel. The stock springs are a bit heavy for the SE but right for your bike with the TT tank. Your F800 left caliper will bolt on with the right bracket, and you can use the F650 or a similar sized master cylinder to handle the reduced volume. Stock SE rim is a really strong 1.85" DID Dirt Star with thick spokes.
    Great overall package, much better than a set of stock forks with the expensive inserts. :wink:
    #16
  17. Motorfiets
    Oct 1, 2007
    2,981
    Southern California
    gonna give it a test with the lighter? :lol3
    #17
  18. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,661
    Grand Valley, Colorado
    A fellow inmate contacted me on ideas for kevlar protection on the bottom front of the big tank. In case your bike takes a nap....( could happen....you know...:D:D) he mentioned that those corners would not fare well in a big spill....... I would gladly help with protection....... In case your interested..... I might be going to Carlsbad,CA in the next 30 days..... I could bring some composite goodies......... I have never seen the tank in person..... But I think the other inmate might be onto something....... :thumb:thumb
    Erling
    #18
  19. Camel ADV
    Camel ADV Long timer Supporter
    Mar 4, 2009
    2,218
    Cowtown
    Should be awesome Finn!
    Couple thoughts...
    -The HID should be fine without resistors. Easy enough to run it off a relay if it is an issue.
    -COG with empty main and full TT tank sounds much worse than it is. I generally run on the main, fill it when empty and alway have the TT full for emergences. I was stressed about it before I installed but it ended up being fine.
    -Kevlar/CF armour for the bottom of the TT tank. I didn't give ebrabaek enough of a heads up before I was through and we couldn't get the right fabric/color in time. I've got a few ideas in mind for the armour. If you end up doing it, let me know. I'll be in for a pair if you can whip up 2 sets while you're at it.
    Good luck with the build brother!
    #19
  20. Camel ADV
    Mar 4, 2009
    2,218
    Cowtown
    Gotcha. You probably already posted it and I missed it as I'm not a thread reader, I'm a thread skimmer :shog Easiest fix... piece of electrical tape over the display:D
    Battery, have you thought about fabbing a low mount for it? Colebatch had a skid plate/battery tray made up for his 650X-Challenge. I think it's a great idea. The weight is really low and the battery is easily accessible (unlike with the TT Tank). You can store things that you very rarely need in the spot the battery was originally in. I carry a spare air filter, 2 spark plugs and a coil on long trips. I though I'd store them in the OEM battery tray. If and when I need them, I need to pull the tank to install them anyway. I'm sure there's lots of odd ball spares you rarely need that you could store in there. Just a thought.
    #20
