The GO-SPORT adventure!
Discussion in 'Some Assembly Required' started by tobiism, May 26, 2016.
  1. tobiism
    tobiism Been here awhile
    Jun 28, 2011
    325
    Chandler AZ
    Seeing all that ground clearance is getting me excited!
    #21
    Te Hopo and larryboy like this.
  2. johnwesley
    johnwesley wanta be
    May 11, 2006
    2,891
    mena, Ar
    Sent ya a pm
    #22
  3. never2old4fun
    never2old4fun Been here awhile
    Jul 2, 2007
    660
    Joliet, Illinois
    Yeah, I could see that it still has a ways to go. Bracing, mounting tabs plus other odds and ends related to getting everything attached. It would still be interesting to see how it compares to a stock sporty frame. Less the swing arms of both. That's if you are going to put a different type/style on it of course.
    Watching the building a frame from the ground up is intriguing and a good learning experience. :lurk
    #23
  4. PHXKLR
    PHXKLR Random internet guy.
    May 4, 2016
    79
    Phoenix, AZ
    :lurk watchin'
    #24
  5. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Just ordered the aluminum stock to make the top hat reducer sleeves to run a three quarter axle on the KTM forks
    #25
  6. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Oh yes indeed
    #26
    AK650, rodteague, Te Hopo and 2 others like this.
  7. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    #27
    Te Hopo likes this.
  8. rodteague
    rodteague Enjoying the ride
    Apr 12, 2013
    761
    Franklin,TN
    What's the plan with the square hole in the tank?
    #28
  9. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Nothing major, I just had to cut the gas filler out to remove the bottom of the tank
    #29
  10. mississippimadman
    mississippimadman Long timer
    Feb 21, 2014
    1,490
    Mississippi
    What tire and wheel combo are you using
    #30
  11. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    2.75x18 rear with 140/80-18 TKC80 and 2.15x19 front with 100/90-19 TKC80
    on harley hubs, buchanan heavy duty stainless spokes and Sun rims
    #31
    johnwesley and mississippimadman like this.
  12. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Alright! My axle spacer reducer material came today. First off was to center the wheel then I got to work making the top hat reducers. The reducers are the same o.d.as the KTM axle and the inside diameter is .75", same as the Harley axle.
    I just need to trim the ends down to a .25" off the slider and they will be finished. After that an axle the correct length and start on my 4 piston R6 caliper mount.
    #32
  13. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Well I got my rotor mounted up to the front wheel only to find out that my front caliper I was going to run fouls on the spokes. Looks like I will have to procure a late-model Harley 4 piston caliper that should clear the spokes.
    #33
  14. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Received the caliper that I'm going to use. It's a little heavier than I wanted to use but I was able to make it clear and that's more important right now. I had an idea of how to mock up the caliper and it worked fantastically. I just used wire taped to the rotor to space off the caliper and then used clear lexan to locate all the holes necessary.
    #34
    AK650, Te Hopo, nuggets and 2 others like this.
  15. never2old4fun
    Jul 2, 2007
    660
    Joliet, Illinois
    It will be interesting to see the frame works out. You did say that you were looking into away lower the swing arm mount and that got me thinking about a frame that friend of mine has and how the swing is mounted in his frame. Now it's not stock frame, but I thought that the pictures might give you some ideas.
    #35
    AK650 likes this.
  16. DayTripper85
    DayTripper85 Been here awhile
    Apr 7, 2016
    199
    Alabama
    Wow, So cool!!
    #36
  17. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Thanks so much! And that is a cool frame!
    #37
  18. tobiism
    Jun 28, 2011
    325
    Chandler AZ
    Slow progress.
    #38
  19. DayTripper85
    Apr 7, 2016
    199
    Alabama
    Never hurts to get better with saw and file!
    #39
  20. never2old4fun
    Jul 2, 2007
    660
    Joliet, Illinois
    Just a little history about that frame. If you know or remember who Mert Lawill is. He designed some of these frames for his own personal XR 750 race bikes. This example is one of his lite weight frames. At this point you don't see many of them round. My friend got this one a couple of weeks ago. He has one other and its on his bike that he raced back in the 1970's.
      File size:
      757.8 KB
      152
    #40
    AK650 and Bearded Hooligan like this.
