The GO-SPORT adventure!
Discussion in 'Some Assembly Required' started by tobiism, May 26, 2016.
  1. tobiism
    tobiism Been here awhile
    Jun 28, 2011
    547
    Chandler AZ
    Rolled it out for a look-see
    Daaaaaang. As much as I like the sporty tank, a fat, bulbous 5-gallon desert tank is in the works. The tanks will get switched out when the Supermoto wheels go on. Oh yes Supermoto wheels are in the works as well.
    Oh and that's 13 and a half inches of ground clearance at the frame rails!
    #81
    JagLite, AK650, joenuclear and 4 others like this.
  2. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,319
    PNW
    Rekluse and sumo wheels? I like where this is going.. I looked into the rekluse, its a pricey item and couldnt find too many reviews on it either, at least for the sportster.
    #82
    JagLite, tobiism and villageidiot like this.
  3. tobiism
    Jun 28, 2011
    547
    Chandler AZ
    In talking with Bill from biltwell they ran one on the frijole race bike they built. Said it was a lifesaver
    #83
    Helibee, madrider5150 and Webman like this.
  4. tobiism
    Jun 28, 2011
    547
    Chandler AZ
    Headlight and oil cooler setup now all mocked Up
    #84
    JagLite, Helibee, FR700 and 4 others like this.
  5. Webman
    Webman Been here awhile
    Jan 5, 2016
    758
    Arizona
    #85
  6. jays100
    jays100 Been here awhile
    Aug 1, 2006
    417
    CT
    Newly joining your build thread. One thing i've always wondered is what the all-up weight on these sporty builds end up being?
    Am intrigued with the sporty engine, etc. but the builds mostly seem to use the stock frame (well, JTH mods his), which is horribly heavy. But you built your own so if the running gear/rolling chassis, less engine, ends up being in the 150lbs and the Sporty engine is in the neighborhood of 200lbs....is that correct? An adventure sporty 1200 can be 350lbs? not believing it so what's the weight of yours?
    J
    #86
    JagLite likes this.
  7. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    13,327
    Orange County, CA
    I was talking with @AK650 and Richard pollack (AKA mule motorcycles) and he said he got a sportster down to 315lbs, but it was a LOT of work, titanium etc etc.
    #87
    JagLite, AK650, Webman and 1 other person like this.
  8. tobiism
    Jun 28, 2011
    547
    Chandler AZ
    This one's going to be in the neighborhood of 450 lbs.
    I will weigh it once it's done and filled with fluid
    #88
    AK650 likes this.
  9. tobiism
    Jun 28, 2011
    547
    Chandler AZ
    Without the detachable bag setup I built this bike to 416 lbs wet.
    Handled like a dragonfly
    #89
    JagLite, Webman, jays100 and 3 others like this.
  10. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    1,718
    Alaska
    Really cool project! Thanks for the heads up VI !
    #90
    tobiism likes this.
  11. AK650
    Jun 26, 2013
    1,718
    Alaska
    I'll be happy if my project ends up at 415lbs! :D Getting to 315 would be way more work and $$$$ than I'm willing to muster! But, it is cool to know it can be done.
    #91
    JagLite and villageidiot like this.
  12. tobiism
    Jun 28, 2011
    547
    Chandler AZ
    Yeah everything I do is pretty much on a shoestring budget. I didn't have the cash for Exotics to get the Monoshock project lower than 415
    At that point you are talkin about thin wall chromoly tubing chassis, titanium everything, race brakes, magnesium Wheels, Etc
    #92
    AK650, villageidiot and Webman like this.
  13. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,497
    Efm makes an auto clutch too. Think he started with Harley then made some for other bikes. Easy guy to work with. Easiest auto to install. I have three different manufacturers auto clutches, he did mine for the kdx.
    #93
    JagLite, Helibee, c1skout and 2 others like this.
  14. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,660
    Anchorage Alaska
    I really like your build... but...
    :hide
    Your swing arm looks so flimsy :yikes
    Is the axle plate really only welded on only about 3/4"?
    Is the arm double wall full length?
    You could easily measure the twist strength by clamping the swing arm pivot bolt in a fixture to hold it from moving and then put a dial indicator at the axle plate of one arm and see how many pounds force it takes to twist using a jack, or even just a crow bar or length of pipe.
    The compare the deflection number and force applied with other good swingarms.
    I think you will find out it is very weak compared even with a stock Sportser arm.
    You could also test the point loading of the shock location by fixing both axle plates and the pivot point so they cant move and measuring with a dial indicator how much deflection at what force. Ideally you would test to destruction to see how it fails, bending or cracking, but I doubt you want to do that.
    The Carducci Dual Sportster has a good example of a swing arm designed for the loads.
    I'm not a fan of the billet design though, it is very expensive to produce, difficult to clean, and offers minor weight savings over rectangular tube.
    Round tube is really not the best for the bike weight and your shock location, unless you add bracing, something like this:
    That would spread the load from your shock location and dramatically increase the "twist" strength of the swingarm.
    (placing the diagonal brace top location below your mid arm shock mounts)
    Or you could build a proper rectangular swingarm designed for your shock location and length, what was called a banana swingarm in the late 70's.
    Some examples:
    Aluminum would be excellent but is much more expensive and difficult to weld than steel.
    Take a look at THIS SITE for swing arm design and fabrication for more info.
    Carry on brother, I'm just seeing a very likely problem area for your bike. :fpalm
    #94
    jays100, villageidiot and AK650 like this.
  15. tobiism
    Jun 28, 2011
    547
    Chandler AZ
    Haha no worries! That swinger is STOUT. Its 3/8" thick wall 1.25" chromoly with the .120" thick wall 1.5" outer sleeve. I'm going to run it but I'm also not planning on treating it like a race bike.
    #95
  16. JagLite
    Jun 17, 2010
    8,660
    Anchorage Alaska
    :ricky
    #96
    tobiism likes this.
  17. villageidiot
    Apr 29, 2010
    13,327
    Orange County, CA
    Maybe just a bottom/top plate to box in the drop out.
    #97
    JagLite and tobiism like this.
  18. tobiism
    Jun 28, 2011
    547
    Chandler AZ
    Thats not a bad idea
    #98
  19. Helibee
    Helibee Been here awhile Supporter
    Jan 26, 2014
    517
    Do you happen to remember which Mule build was/is 315#?
    #99
  20. villageidiot
    Apr 29, 2010
    13,327
    Orange County, CA
    No, he has said he did a sportster and the goal was 300lbs, he got to 315 and called it good.
    Helibee likes this.
