The Great Nitro Mousse Controversy/Tyre/Tire Discussion
Discussion in 'Equipment' started by TigerTanker, Jul 26, 2017.
  1. TigerTanker
    TigerTanker Husqurducycle
    Jun 2, 2015
    10,414
    Tacoma WA
    The soap/silicone issue is product specific. Petroleum can be a real problem inside rubber tires, and react to mousses. His mousse with the proper lubricant, theirs or the one mentioned above, is the way to go. (according to Nuetech)
    #41
  2. NVTS
    NVTS Arrivee Secteur Special Supporter
    May 18, 2006
    1,406
    Big Lick Virginia
    On a weeklong ride in Colorado last year several riders were running BibMousse. One gentleman had installed Zirk fittings into the rim and pumped "Murphy's tire soap" in every other day.
    I'm interested in these Nitro Mousses for my race bike and if they prove to hold up well; on my dual sport: Tubliss for now.
    #42
    TigerTanker likes this.
  3. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    Ok, I found a tire tool in my attic from my early days with my Triumph Tiger, when I thought I'd regularly change my own tires..... ROTFLMAO!
    #43
    Eldon likes this.
  4. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    Tomorrow, meeting Dan, and we'll start working on these!
    #44
  5. N8
    N8 I prefer my pumpkin with a blue & white mask. Supporter
    Dec 27, 2012
    6,442
    Lancaster, PA
    Looks really similar to the Tusk one I use.
    #45
  6. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    Ok. We rode 40 miles at cap forest. Now mousse party
    #46
    N8 likes this.
  7. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    Started with removing rear. The challenging part is getting the first 8 inches off. Use 3 tire irons then flip.
    #47
  8. N8
    Dec 27, 2012
    6,442
    Lancaster, PA
    A key part is making a ramp for the opposite side of the tire bead to get down out of the rim bead, however you may choose (tire irons, vice grips, etc). You can't just push it down like a deflated tube. That's most of the battle with mousses IMO and I'd imagine once you've got that technique refined to match your tools, you're home free with both install and uninstall. I prefer several tire irons to accomplish this.
    #48
  9. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    "And it pops right off"
    That's what all the videos say.
    Meanwhile greasy hot swearing bloody knuckles beer
    #49
  10. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    Dan got mad at the tire and threw it into the yard.
    #50
  11. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    Long irons?
    #51
  12. Bungholio
    Bungholio Long timer
    Oct 9, 2008
    2,670
    Aberdeen, WA
    Why can't the mousses be installed with a Harbor freight type tire changer, like you would do with car tires--using a bar to spin around the bead pushing it on the rim. With all that grease on everything it should go right on if you can keep the bead in the rim pocket.
    Question: Has anyone you talked with mentioned if the mousse rotates around inside the tire over time? Seems likely with all the grease and nothing to hold it in place.
    If I had a purely offroad bike I would do the mousse thing, but I am not plagued with flats and if I want 8psi one day and 14 the next it's hard to do with a mousse. I would definitely do mousse before Tubliss, but I'm sticking with tubes for now. I am interested in your experiences with the NitroMousse.
    I'm on the downward slope of the roof project and ran out of shingles so I go tin a ride yesterday afternoon in Capitol Forest, it's a dustbowl! Ugh!!. I should be able to join you guys now when you have something planned.
    #52
  13. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    It's all on but the last 8 inches and damn tight. Is there a trick for the last part? Stiff sidewall tire.
    #53
  14. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    #54
  15. Bungholio
    Oct 9, 2008
    2,670
    Aberdeen, WA
    I think you need the short tire irons around the rim to let tire slide into center of rim, keep bead off the rim bead seat.
    #55
  16. N8
    Dec 27, 2012
    6,442
    Lancaster, PA
    For the ramps short ones are fine. For that initial/final spoon-over, long is helpful for leverage.
    #56
  17. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    Ok, that sucked. So...
    #57
    wfv56 and N8 like this.
  18. TigerTanker
    Jun 2, 2015
    10,414
    Tacoma WA
    We got 8 inches from nirvana. Guess we will have to pay for it instead. Burp.
    #58
  19. N8
    Dec 27, 2012
    6,442
    Lancaster, PA
    Gotta ramp that bead down in...don't pay for it!!
    #59
  20. N8
    Dec 27, 2012
    6,442
    Lancaster, PA
    Also, make sure yer beadlock ain't stuck outside the tire. Could be another hangup.
    #60
