The Great Nitro Mousse Controversy/Tyre/Tire Discussion
Discussion in 'Equipment' started by TigerTanker, Jul 26, 2017.
  1. emmi
    emmi Been here awhile
    Apr 28, 2015
    548
    socal
    20hr lube session (first relube done at 10 hours). Still plenty of nitromousse lube in it. 1566525620657-1.JPEG 1566525620038-1.JPEG
  2. N8
    N8 Masked pumpkin rider Supporter
    Dec 27, 2012
    8,598
    Lancaster, PA
    2 things I have found greatly increase the amount of time the mousse stays lubed:
    1. Use the rubber-tipped blow gun trick to seat the bead of the tire on the rim fully after mousse install.
    2. A mousse that is not too small for the tire it's in.
    I jokingly said to @kjclark7 that maybe @TigerTanker wasn't too far off with how long the front mousse could last now that I've been running the NM21-235 in the M59 using the blow gun trick. Every time I pull it, it's still got plenty of lube. I do NOT recommend the NM21-220 in the M59. I ran that combo for 2 seasons and the 235 is so much better in there.
    DockingPilot likes this.
  3. USNRELIC
    USNRELIC Adventurer
    Jul 17, 2011
    65
    Mid Tenn
    Bead not seating on rear tire. Hi, I have a question about seating the bead. I’m a first time mousse user. I put a nitro mousse (soft version) on a beta xtrainer, paired with a 120 shinko 525 cheater. Mousse is new, tire has about 50 miles on it. I can’t get the bead to seat completely. There is a 4 inch section on one side and a 5 inch section on the other side. It only needs to come out about 1/16 of an inch to be fully seated. I’ve tried bouncing, a mallet, adding air, trying to pry it out, and slowly riding it a short distance. Some people say just ride it as long as it stays on the rim (1 rim lock in place). What’s the consensus? I don’t want to ruin the mousse or my tire/rim. Is it okay to run not seated that small amount? I ride single track, rarely over 25 mph. Thanks in advance!
  4. N8
    Dec 27, 2012
    8,598
    Lancaster, PA
    Elaborate please. Rubber-tipped blow gun in one of the rim holes is the best way I've found. I also glaze the tire bead with a thin layer of lube after I put the mousse in. If any part of the bead didn't push out upon install, it pops right out with a shot of air.
  5. USNRELIC
    USNRELIC Adventurer
    Jul 17, 2011
    65
    Mid Tenn
    That’s exactly what I tried, I guess I’ll keep working at it. Thanks
  6. USNRELIC
    USNRELIC Adventurer
    Jul 17, 2011
    65
    Mid Tenn
    My next course of action is to dismount it and put a tubeless valve stem in to hopefully get more pressure than the rubber nozzle.
  7. Lutz
    Lutz Fuzzy Rabbit
    Jul 17, 2010
    3,286
    North Shore of Lake Superior
    If/when I ever mount a mousse, I'll be adding a tubeless valve stem on the first try for that reason, whether it's needed or not. It can't hurt at all, but it sure might help a lot. If you do go that route, make sure you add the blast of air with the core removed from the stem...a trick of the bead-seating trade.
    jimmyh and USNRELIC like this.
  8. theDub
    theDub Adventurer
    Sep 21, 2012
    93
    Gardnerville, NV
    Do you have the rimlock installed with a rubber grommet or something under the nut on the outside of the rim? This will keep all the air you are shooting in from escaping out the rimlock hole.
    USNRELIC likes this.
  9. USNRELIC
    USNRELIC Adventurer
    Jul 17, 2011
    65
    Mid Tenn
    Got home from work and put a rubber washer on the rim lock, used an old valve stem from a car wheel and mashed it into the other hole. I wedged a tire iron into the sections that didn't seat and shot some tire lube on it then used about 80 psi and it popped out where it should be. I really appreciate the tips, when I change tires im going to install a valve stem just for seating purposes. Thanks Everyone!
    N8 likes this.
  10. jimmyh
    jimmyh n00b
    May 13, 2013
    1
    Southern California
    I'm doing something similar to USNRELIC. I like the idea of having the option to blow air in without jeopardizing the ability to keep the wheel sealed and mostly watertight.
    Just cut up an old tube.
    crudmop, USNRELIC and N8 like this.
  11. Just4Fun11
    Just4Fun11 Been here awhile
    Aug 5, 2008
    479
    D594D6E8-B0EA-4034-9ACA-F25B61486174.jpeg 07572D8E-50A4-4688-A684-093ADDCAC8A2.jpeg I put together a spare rim for my 450x, maxxis desert it 120 & 305 mousse. It went together after about a 30 minute wrestling sweating match. But I had the same issue of one area not beading up. It was still on the cheapie tusk tire mounting jig, flipped it around and started pushing the bead down 180* from the unseated bead. Popped right up, I used almost 2 tubes of lube which might have helped. Def appreciate this thread!
  12. moto_dmitriy
    moto_dmitriy que?
    Feb 15, 2011
    289
    SFBay
    Not sure where you got that info from, but you can fit an old NitroMousse to a different tire brand AND/OR size if you want. See the application chart:
    http://nitromousse.com/application-guide/
    In fact I have done that exact thing - I run them for a while in a 120/100 or 140/80 and then downsize to 110/100 when the Mousse shrinks a little
    I have even used a UHD to sleeve the Mousse to get extra life out of it. (Having used one set for over a year, 150 hours, on a 300 it seems like the front almost never wears out)
    Same blowgun trick to seat them when used as others here have posted.
    redkerk84 likes this.
  13. Stoneygrey
    Stoneygrey 17 Fe 250
    Jan 21, 2018
    13
    California
    I had 1600 miles of mostly dirt on a Bridgestone X 40 110/100/18 with -305 mousse. Took it to 3 bros for a tire change (Mx52) yesterday they found somebody’s needle nose pliers. Around 400 miles ago I noticed a puncture between the knobs and never thought more about it..
    You can see where the nose of the pliers bent off the rim. And the whole mess just sucked inside the tire.
    The mousse looked like new and well lubed.. minus the gash.
    More than one person thinks I might’ve hit a trail spike. Or, it was my fault and I’m stupid because I ran over some pliers out in the dirt..
    Either way, controversy over. Drop the Mic
    EF1A6964-A0F9-4953-ADC6-55F31B9E5118.jpeg 31D18C6A-E0B3-4278-AA93-FBA64E66EE40.jpeg
    sashapave, NoelJ, Just4Fun11 and 3 others like this.
  14. N8
    Dec 27, 2012
    8,598
    Lancaster, PA
    That's crazy. Kinda cool that you had a freaking pair of pliers in your damn tire and were able to ride anyway.
    Stoneygrey likes this.
  15. Lager Meister
    Lager Meister Work less, ride more
    Jul 9, 2006
    613
    DFW, Texas
    Fat Chance likes this.
  16. theDub
    theDub Adventurer
    Sep 21, 2012
    93
    Gardnerville, NV
    I was riding in Downieville, CA last weekend, and when we got back to the truck I noticed this cut in my tire. There is some sharp volcanic rock around, so I just figured that's what cut the tire. No big deal, just kept riding and didn't even notice thanks to the Nitromousse.
    I had a race this weekend, so had to put on a new tire. When I took everything apart, I found it wasn't just a cut in the tire, but this big-ass stick had gone through the tire and all the way through the mousse.
    Certainly would have ruined my day with tubes or Tubliss. And it reinstalled that mousse, of course.
  17. thejrod
    thejrod Been here awhile
    Nov 2, 2010
    865
    Arlington, WA
    If you have some trouble seating the bead, double check the circumference of the mousse. I got a Nitro that was undersized - marked as the 305, but measured about 290mm. Nuetec sent a replacement that was a true 305mm, and it fit perfectly.
  18. Its not Ginger!
    Its not Ginger! Long timer
    Jun 9, 2016
    1,225
    Oxford, UK
    What is the consensus on life now these have been out a while?
    I have an FE 350 that will be used for trail riding and Enduro fun days, basically fairly gentle riding in dirt, mud, grass and gravel, but in the UK it is hard to ride for a day without doing as many tarmac miles as dirt miles (but measured in time it is more time off road)
    It will probably get used 10-12 times a year and clock no more than 1,000 miles (<60 Hours) in a year, my question is could i have confidence in a Nitro Mouse lasting me a year - I am guessing the 1,000 miles is not a problem, but if they break down in 6 months it will be very expensive, I am hoping to get away with a new pair of tyres and mousses a year, ideally would love to get 2 years from the mouses and just lube them at the end of their 1st season when putting on new tyres.
  19. KDMNZ
    KDMNZ n00b
    Nov 6, 2013
    3
    Sorry if this has already been addressed in the earlier posts. Do Mousse's shrink over time? I have a KTM 450exc I am thinking of switching over to them but I don't use the bike that often and only go for about 3~4 rides a year. Will they just waste away over time and need replacing too often?
  20. adv_sacrifice
    adv_sacrifice Been here awhile
    Aug 18, 2017
    434
    From what ive read, yes they do shrink. Not sure what would actually cause that though since id imagine its caused by the foam degrading.
    No personal experience
