The Great Nitro Mousse Controversy/Tyre/Tire Discussion
Discussion in 'Equipment' started by TigerTanker, Jul 26, 2017.
  1. adv_sacrifice
    adv_sacrifice Been here awhile
    Aug 18, 2017
    435
    Whats the opinion on the front? Rock a tube still? Just curious what people are doing
  2. morgan9283
    morgan9283 Adventurer
    Mar 16, 2009
    39
    I couldn't find much info on drilling so I just gave it a try last season--I drilled a set of standard nitro mousses August of last year: after 2-3 races they were noticeably hard so I drilled 1/2-3/4" holes centrally every few inches. They broke in almost immediately and felt great which for me I'm learning means very soft: if the bike isn't rolling sideways in turns the mousse isn't soft enough for me: I love the way they absorb obstacles. I have maybe 80 hours on them since then. The rear had shrunken when I got it (small diameter) probably because it was old stock and it split on one of the drill points within a ride or two of drilling--I stuffed some chunks of old mousse in and rode it for most of those +/- 80 hours. The front got very pancaked but still held the beat and felt great--both the front and rear showed significant evidence of rolling but held the bead solidly through a mix of sand and rocks enduros (I mostly race). I'm a mid-pack C rider but I ride a lot on tough terrain. I'm religious about lubing and use Nuetech's lube. I'm just replacing them now but from a chat with Nuetech I could have continued to run them: as long as they're holding the bead you and you like the feel they say they're safe to run. One issue is the broken rear mousse felt funky on pavement and would throw rim strips (they came out around the bead). Nuetech's tubliss rim tape stayed in place but I do wonder if you need a rim strip with mousses. I'm trying Nuetech's soft mousses now as drilling doesn't seem like an ideal solution and Nuetech says it reduces life. We'll see how they work out!
  3. BobcatSig
    BobcatSig Fresh Off The Couch Racing
    Aug 15, 2014
    4,112
    Protestlandia, OR
    Agreed. I went with mousse last year on my 250 XC-W and it's been terrific, especially when I want to go lightweight.
    Yes absolutely. In fact, I've heard more people do front only if they are adding mousse to only one tire. For me, if you're making that leap, send it and do front and rear.
    Keep in mind that there will be a break-in period where the mousse will be stiffer than you'd like. After a few rides, they break in and you get the soft, squishy, thunky goodness.
    I'll also recommend that you size your mousse specific to the tire you're running. For example, Goldentyre makes mousses specifically for their different tires. Same with Michelin. A good tire shop should be able to help with this.
    adv_sacrifice likes this.
  4. adv_sacrifice
    Aug 18, 2017
    435
    appreciate it. i havent changed the front tire yet so ill probably rock it a little longer until it comes time then ill do a mousse if im liking the rear (running a tusk recon right now)
  5. BobcatSig
    Aug 15, 2014
    4,112
    Protestlandia, OR
    Unless you have yourself a Rabaconda tire machine, you're going to want a shop to install those mousses. Plus, it's just good business to support your local shop.
  6. adv_sacrifice
    Aug 18, 2017
    435
    Ill figure it out:beer
    NoelJ likes this.
  7. N8
    N8 Masked pumpkin rider Supporter
    Dec 27, 2012
    8,607
    Lancaster, PA
    NM21-235 + M59 FTW.
  8. bhmax
    bhmax Adventurer
    Sep 4, 2005
    38
    East TN
    Just read through all this. I had the Nitros installed over two years ago on a WR without really knowing too much about them. I don’t have enough dirt experience to compare the exact feel compared with tubes, but I thought it was awesome doing some solo trail riding and not having to worry about a flat.
    I sold the WR, and am reading up on these a bit more for my next bike. Curious about any more input on the newer soft versions. Also, found it interesting about certain tires like the 21” D606 not having a NM available. Looks like they now have a “210” that fits it and is recommended for others also.
  9. jekaio
    jekaio Ride The Lightning
    Jul 25, 2014
    272
    west
    what kind of road miles are you guys putting on the meeses?
    the heat buildup warning on pavement is the only thing that has ever kept me away from them.
    '17 501 and ride pavement to trails, with some trails being 25-30 miles away.
  10. adv_sacrifice
    Aug 18, 2017
    435
    One down...took 3 hours from removing the wheel off the bike. No tire changing stand. Ended up using vice grips and some "vice grip" style crescent wrenches. Honestly thought these worked better than the little trail buddys or bead buddy. I had trouble moving the trail buddys once my hand got slick and they didnt seem to hold the bead down far enough.
    95% sure i didnt tear the bead but some rubber did kinda get chewed up around the bead. Guess ill know when i go ride it.
    Tusk recon with 12hrs/165 miles of use.
  11. crudmop
    crudmop eTard
    Sep 10, 2008
    342
    NY
    4 or 5 bead buddies help - and not starting on the rim lock so you can get a little more drop on the 180 make it a bit easier. I started using [mention]kjclark7 [/mention]’s method and it really made the whole process pretty painless.
  12. adv_sacrifice
    Aug 18, 2017
    435
    I finished at the rim lock on the second side.
  13. adv_sacrifice
    Aug 18, 2017
    435
    Front went so much smoother. Gt216aa fatty. Looking forward to trying it out with the mousse. Extra spoons didnt hurt this time around either though
    crudmop likes this.
  14. socalluke
    socalluke Been here awhile
    Jul 1, 2014
    304
    Hermosa Beach, CA
    Like the Nitro mousse front with Tubliss rear for off road applications! The new Nitro mousse in the standard pressure is now "gray"
    Some friends like the soft mousse in the back for low speed tech riding where max traction is required.
  15. crudmop
    crudmop eTard
    Sep 10, 2008
    342
    NY
    I’ve found the first 10-20 miles on fresh mousses are bouncy and need to settle-in a bit before they feel good.
  16. brianpc
    brianpc Long timer Supporter
    Feb 20, 2013
    1,853
    CA
    Reviving this thread since it's helpful! I have a dumb question, please don't yell at me.
    I have a set of tires w/ mousses (mounted on my wheels) that have been sitting for a while (about a year) - moving, life, etc, I haven't used them in a while and they were only used about 2x lightly before taken off the bike.
    Should they be re-lubed before use? Are they old enough from disuse that I shouldn't worry about it and ride once or twice and replace them anyway? Tires are still good but I am trying to decide if I should throw them on and ride 'em or unmount / relube / remount.
    I am a slow old rider so I'm not doing anything crazy anyway.
  17. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,701
    On the Ground Laughing
    Mount them up and sit on the bike.... do your tires look flat?
    Dan950ser and brianpc like this.
  18. 911
    911 Been here awhile Supporter
    Mar 16, 2016
    395
    maine
    You should be able to run them for another year and or 800 miles before you need to inspect and lube or replace.
    brianpc likes this.
  19. crudmop
    crudmop eTard
    Sep 10, 2008
    342
    NY
    If they are not on a stand, you'll feel them a bit because they square-off when sitting for extended periods. A mile down the road you'll be good to go.
    brianpc likes this.
  20. jonz
    jonz Miles are my mantra Supporter
    Aug 16, 2004
    5,919
    CA dez (it's a dry heat)/West Yellowstone,MT
    So I just installed the soft Nitro Mousse's front and rear in my 400 XCW with new Maxxis Desert IT tires. Installation was much easier than the Michelin bib mousse's I used last time with the same tires. I liked that the Neutech website had sizes listed for many different tires which may have meant I got a better size for my tires. Or i just learned better technique but I don't think I even cussed one time. I did like the how to video on the Neutech website. I used Murphys tire soap with a little water for the rear and used both tubes of the included Neutech lube on the front. Temp's were mid 70's in my garage for the installation and the Neutech lube started dripping off the tire/mousse like it was melting. Time will tell if there is any difference in the two lubes. My Michelin mousses were installed with the Murphys tire soap and a little water, and still had a little lube left 2 1/2 years later.
    I rode it for the first time today on technical, rocky sandy desert two track and single track. It immediately felt great and kept feeling great the whole ride. I remember the Michelin mousse front feeling giving kind of numb feedback and I never really liked the feedback from it as much as I like the Nitro mousse. The Michelin mousses did get better over time. So will be interesting to see what happens over time.
