The Honda Monkey thread
Discussion in 'Thumpers' started by Kommando, Jun 14, 2018.
  1. JesseeS
    JesseeS Been here awhile Supporter
    Apr 4, 2012
    110
    Killingly, CT
    I think 240 is when this start to get get more dangerous if kept constant, I have mine set for 250
    JoshM likes this.
  2. JoshM
    JoshM mid10josh Supporter
    Jun 10, 2014
    473
    Franklin, TN
    Oh, that's no good. I was at 245ish at some points yesterday - with 70* ambient. Maybe I need an oil cooler sooner than I thought.
  3. JesseeS
    Apr 4, 2012
    110
    Killingly, CT
    Unless it's consistent I wouldn't be too worried. Getting stuck behind a slow moving car will cause my temp to spike but once I'm going at a better speed it drops down. You just don't want high Temps for prolonged periods. If you're not running a big bore and have your ecu flashed for your mods I wouldn't worry
    JoshM likes this.
  4. Baggi'tard
    Baggi'tard If I don't answer I'm ridin' or shootin' Supporter
    Sep 20, 2006
    3,798
    Farmhouse Inn, Tellico Plains, TN
    check your headlight shell. one of my Monkey had a rattle and I finally figured out one of the headlight bezel screws fell out. I'm also going to try and figure out how to install a screw or something to help the bezel stay put. Since there are only two screws, and one "clip" at the 12 oclock, it tends to come loose on rough roads, so every ride, over and over.
    JesseeS likes this.
  5. JesseeS
    Apr 4, 2012
    110
    Killingly, CT
    Thanks for the heads up! I just gave it a once over and sure enough one of my screws was loose. That said, it wasn't the cause of my noise. After way longer than I want to admit, it turned out to be my rear heat shield screw was juuuust loose enough than when in a certain rpm range it would give a rattle. Some loctite and another test ride later, rattle gone. I'm going to keep an eye on the headlight screws though. Thank you!
    Night_Wolf and JoshM like this.
  6. JoshM
    Jun 10, 2014
    473
    Franklin, TN
    It's the little things sometimes. Finally got my real tag!
    JesseeS likes this.
  7. JesseeS
    Apr 4, 2012
    110
    Killingly, CT
    Love the pair of bikes. Big fan of the strom
  8. Night_Wolf
    Night_Wolf Leg Humper
    Feb 17, 2006
    11,246
    Lat: N 90°00'00" Long: N/A
    Me too & owned a pair of them; could never say anything bad about the Wee Strom
  9. wforider
    wforider Adventurer
    Apr 28, 2012
    82
    Marquette, MI
    So I put on a full Yosh race exhaust. Sounds great, borders on too loud. Wish there was a switch to go back and forth between yosh sound and stock stealth. Anyway “off idle” throttle response and power suck. Mid top power better as far as 8 hp goes. Any solution to low end power/response?
  10. JesseeS
    Apr 4, 2012
    110
    Killingly, CT
    You can always go to a 14t to get back some lower end, but will rob top speed. With this bike you can't have your cake and eat it too. Power mods tend to get you more speed at the cost of bottom end
  11. AwDang
    AwDang Enabler
    Sep 1, 2014
    4,383
    MABDR mile 0
    Time for a 180 build!
  12. FLEUP
    FLEUP Adventurer
    Jun 7, 2021
    27
    France
    for the fun
  13. emoose
    emoose I have no idea what I'm doing. Supporter
    Oct 27, 2008
    471
    NC
    What are your other mods? Intake? ECU flash?
    I just purchased a Yoshimura RS3, and in my pre-purchase research, I found that while the stock ECU can adjust for the exhaust, it still runs slightly lean off idle, then rich through the mid range, and finally leans out again up high. An aftermarket intake exacerbates this. A fuel controller or ECU flash can fix this.
    Also, are you running the spark arrestor? Yoshimura told me that the spark arrestor will slightly increase back pressure, which will increase torque at the cost of losing a little up top. It also takes the edge off of the loudness.
    Disclaimer: I haven’t installed anything yet and have only basic knowledge about engines and tuning. I just like to research.
    wforider likes this.
  14. AdvStrider
    AdvStrider Long timer
    Jul 21, 2012
    4,957
    UK
    Me and a mate ordered a couple of ‘22 Monkeys this week. We’re planning some big trips on them, including a 500 mile south west England trip at the end of October.
    Has anyone with a ‘22 changed the exhaust yet, as there’s nothing listed anywhere, so would we be right in thinking the systems for the previous model will fit?
  15. JesseeS
    Apr 4, 2012
    110
    Killingly, CT
    Hope it's ok to post here, I'm going to post on the hondagrom. Net forum too. Since we are a small group I figured it would be better off here than in the flea market , if not, please delete. Trying to fund parts of another build so if anybody needs these things let me know.
    Opmid oil temp/battery voltage dash: $75 shipped
    Kitaco intake: $50 shipped
    Speedo healer: $45 shipped
    DHM high compression piston, ran for around 50 miles and just went big bore. $75 shipped.
    JoshM likes this.
  16. AwDang
    AwDang Enabler
    Sep 1, 2014
    4,383
    MABDR mile 0
    Kinda interested in the piston. What difference did it make?
  17. emoose
    Oct 27, 2008
    471
    NC
  18. JesseeS
    Apr 4, 2012
    110
    Killingly, CT
    It wasn't a HUGE difference like some people claim. Or maybe I just didn't feel it. What it did do was give me back the low end that I lost after I installed my tb cam.
    Night_Wolf likes this.
  19. cogitate
    cogitate What Marcellus Wallace Looks Like
    Nov 23, 2007
    8,593
    North of the Border, CA
    Battery question for you folks: My Monkey needs a new one, it doesn't hold a charge (basically I didn't start it for a quite a few months and failed to put it on the Battery Tender, might have had the key on for a bit, doesn't matter really, now, it's dead. I can charge it up enough to get the bike running, but that's it.).
    The manual says Yuasa YTZ5S (about $100 to 128 locally), the Yuasa website says I can also fit a YTX4L-BS (38 to 50 bucks). The YTZ5S is a High Performance AGM, the YTX4L is AGM.
    Any thoughts? Thanks!
