The KTM 690 Enduro Thread
Discussion in 'Thumpers' started by neepuk, Mar 6, 2015.
  1. Anders-
    Anders- 690R
    Aug 23, 2013
    4,163
    Швеция
    I dunno about that, I'm sure the ecu will compensate to some amount - but if it did the job 100% there would be no reason for ktm to provide a different mapping when one is purchasing their open airbox cover?
    From https://www.ktm.com/se/powerparts/e...el=F9703R8&category=KE3-16007255/KE4-16007257
    "For perfect function, the special tuning/mapping (included) and the Akrapovič EVO exhaust (not included) are required. The tuning kit calibrated specifically for the bike generates more torque and a perceptible increase in performance. Complete with open air filter box cover. Only for the racetrack."
  2. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    7,448
    Providence, RI
    I think the only way to settle this is with a dyno run...
    Anders- likes this.
  3. Anders-
    Anders- 690R
    Aug 23, 2013
    4,163
    Швеция
    Is this a viable excuse to go out and buy some new bikes? :lol3
    sprouty115 likes this.
  4. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,268
    USA
    LOL. I bought one right after I watched the video. If I like it, I'll certainly buy a second....sorry man. I have the same illness.
  5. 222k km adv bike
    222k km adv bike Been here awhile
    May 20, 2019
    637
    FRANCE
    Hi, ecu will compensate enough for afr ratio, but not for better perf all along the curve. Without evo 1 map, the 4-5 hp you gain in the low range are lost on top end revs. The evo1 map is an average improvement all along the curve, supposed to work good enough for any weather/temp/altitude conditions, so it's not "max perf" oriented. Look at the chart. Since end 2018, and for sure 2019, ktm and husky (French) dealers are not allowed anymore to load any perf alternative map. And for 2019 ktm enduro/smc, there is no evo map available including modes 1&2 and TC. I know one dealer who loaded a duke evo map on 2019 smc, lost 1&2modes and TC, and deleted automatically during next service due to ktm official tool.
    The last remaining solution is to set a piggyback device like a Pc5.
    This way you can open more the air intake, choosing either a short intake hose that will resonate high = max flow at high revs, or a longer one with low resonance for low revs = low end power. Oem airbox is again an average.
    The resonance phenomenon is the same for the exhaust, like an organ pipe : big / long = low end power, short = high revs power. Depends on the design, but some mufflers with cat, as they reduce the flow speed, can enhance the torque by maximising the low resonance of the flow.
    Its quite like suspensions, high speed big jumps settings, low speed hard enduro / step climbing settings, or average...
  6. Bhart89
    Bhart89 Long timer Supporter
    Nov 12, 2013
    1,339
    Indianapolis, IN
    Is that RWHP? 80+hp :hmmmmm
  7. 222k km adv bike
    May 20, 2019
    637
    FRANCE
    No, I don't think it's at rear wheel, should be at the crank shaft, same as manufacturer's communication, last 690 engine with no modifications has 74-75 hp. Note that every bike has been tested with a rear street tyre, no knobbies (I think you loose 5 to 10% power with knobbies on the dyno).
    So 3 to 5 more hp in the midrange with open airbox + exhaust, and 10 to 11hp with pc5 and proper mapping on top of this (fuel and ignition advance I presume). I should buy a pc5...
    Bhart89 and sprouty115 like this.
  8. a_ron
    a_ron Adventurer
    Aug 3, 2015
    74
    White Salmon, WA
    I’m having an issue with my 2009 not starting without the bike in neutral even with clutch pulled in. Can find a solution online.
  9. AllSeasonRider
    AllSeasonRider Wandering, maybe a little lost...
    Feb 20, 2008
    2,863
    Los Angeles, CA
    If it will keep running when you put in gear after you've started it, it sounds like a bad clutch switch. If it dies when you put it in gear it's most likely a side stand switch.
  10. a_ron
    a_ron Adventurer
    Aug 3, 2015
    74
    White Salmon, WA
    Definitely the clutch switch but I can’t even see where it’s broken or if it’s possible to just bypass it.
  11. 222k km adv bike
    May 20, 2019
    637
    FRANCE
    DustyWheels, a_ron and sprouty115 like this.
  12. Hosebag
    Hosebag Difficult but Useful
    Oct 24, 2006
    5,678
    Douchevillia
    Need some help.
    Can’t get the sidestand spring back on my 690.
    Who’s got a ‘technique’?
  13. Anders-
    Anders- 690R
    Aug 23, 2013
    4,163
    Швеция
    Hook it up on the top side, loop a thin rope between bottom hook and the kickstand foot - use a small rod to twist the rope and tighten it, just push hook into position once it’s more or less in the right place.
    And don’t forget the safety glasses when working with springs :-)
    daveburton, sprouty115 and wass like this.
  14. bpowa
    bpowa Been here awhile
    Oct 7, 2010
    235
    i used a needle nose vise grip and yank.. or you can buy a 20 dollar hook tool.
    DustyWheels likes this.
  15. a_ron
    a_ron Adventurer
    Aug 3, 2015
    74
    White Salmon, WA
  16. woodzrider
    woodzrider Long timer
    Jan 30, 2008
    1,339
    anywhere I happen to be
    I use a brake spring tool. For the springs used to hold drum brake shoes. If you remember drum brakes.."...
    LSGiant and STRich like this.
  17. AllSeasonRider
    Feb 20, 2008
    2,863
    Los Angeles, CA
    Brake spring tool for drum brakes is either needle nose pliers or a pair of cutting pliers :)
    Shawnee Bill likes this.
  18. a2zworks
    a2zworks Trust me, I'm Pablo
    Mar 11, 2013
    2,282
    West Hobart
    I have always been able to put the spring on and then the bolt will go on without too much effort using the stand itself as a lever.
  19. s.ga.rider
    s.ga.rider Been here awhile
    Feb 1, 2016
    241
    Ga
    Does anyone have a part number and how to for a better o ring for the clutch slave? After reading about all the failures, I want to replace it before a trip next month. Not wanting to spend the money on the oberon right now.
  20. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,505
    West of the West, Oregon
    I have the size for a 950/990, but not sure it's the same for 690's.
    You may have to just pull it down and mic it. Inside diameter (on the piston) and thickness (slot width on the piston). Then go to McMaster Carr and order. A viton compound would hold up better to oil and brake fluid.
