The KTM 690 Enduro Thread
Discussion in 'Thumpers' started by neepuk, Mar 6, 2015.
  1. Anders-
    Anders- 690R
    Aug 23, 2013
    4,228
    Швеция
    The same way hydraulic brakes are ”self adjusting”, don’t overthink it :-)
    Dalemation and ErGuss like this.
  2. Dalemation
    Dalemation Addicted >:)
    Aug 3, 2009
    62
    Scotland
    As in adjust as they wear then?
    Right that seems more manageable for my intelectual level :scratch
    Anders- likes this.
  3. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,641
    USA
    What you described isn't normal and not an "auto adjustment"; it sounds like maybe you had air in the line. And search "clutch slave" in this thread for an education on what's likely to be next.
    scfrank, Dalemation and sprouty115 like this.
  4. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    576
    Denmark
    Air in the system.. Or a leaking slave..
  5. Dalemation
    Aug 3, 2009
    62
    Scotland
    Thanks Noel and Rookie. I'll look into this.
  6. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,025
    MN and NM
    It is probably a pain, but I recommend taking the bike back to the dealer. But you might not get it back for a while, at least in the US.
    roookie1 likes this.
  7. JoeMongo
    JoeMongo ¿Por dónde? Supporter
    Dec 9, 2004
    1,025
    SF Bay Area, not exactly dirt moto heaven
    You may have a low level in the clutch master reservoir. Heck, you may have an overfilled reservoir. Considering that there is almost no fluid capacity in the reservoir, either would hardly be surprising. If you do add fluid, do it only about 2 or 3 ml at a time, test and repeat if required. It is very easy to overfill the clutch reservoir.
    j.
    Dalemation likes this.
  8. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,025
    MN and NM
    I regularly overfill the clutch reservoir and have had no problems. I always seem to get a little overflow seepage when I put the bladder back in tighten down the cover.
    What issues would this cause? Maybe a little too much positive pressure? I would have thought the bladder would alleviate any problem like that.
    I have a 2013 that uses mineral oil. But I do the same thing on my 500 exc with brake fluid.
    GF-kam and outbacktm like this.
  9. JoeMongo
    Dec 9, 2004
    1,025
    Failure to fully release clutch pressure will cause clutch slippage, wear, and premature replacement. Other than that, nothing.
    j.
  10. Norty01
    Norty01 Occupant
    Jan 30, 2014
    2,789
    CARLSBAD, CA, USA
    Thanks for this. I didn't even know Fieldsheer was into the battery warmed clothing biz. Turns out they're right here in San Marcos too! (2 doors away from Baja Designs!)
    I know some riders that don't let cold temps slow them down, and this could really help them. Thx again!
    eakins likes this.
  11. Dalemation
    Aug 3, 2009
    62
    Scotland
    If the local guys will even answer their phones :dirtdog
    I may have to ho a little out of my way if o want anything done.
    However, i went out for a wee ride yesterday around some of the local lochs and it was totaly fine.
    Is it possible that the lever, being set too close to the bar, was causing the clutch to not disengage which leads to heating of the fluid which caused the spongyness?
  12. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,641
    USA
    Nope, not possible. The clutch fluid is a small, enclosed volume that isn't exposed to anything but ambient heating. It really sounds like you had an air bubble.
    renogeorge and Dalemation like this.
  13. DutchyKevin
    DutchyKevin Adventurer
    Feb 7, 2013
    66
    The Netherlands
    Rade Garage fairing and tower: done! My god I love the way this looks! Can't wait to see how it feels on the move :clap
    roookie1, GF-kam, Swiftdriver and 3 others like this.
  14. Yille
    Yille RIDE
    Nov 9, 2013
    22
    sweden
    Nice!!! I’m just about to purchase the kit but wanted to see if could find some more pics. And you posted in right time :-)
    Do you think you can post more pics ?
    Maybe one like below example?
  15. Swiftdriver
    Swiftdriver Adventurer
    Nov 1, 2019
    36
    3747
    I'm considering a K3 fairing too. How are the lights performing? Any advice on installation thanks?
    outbacktm likes this.
  16. outbacktm
    outbacktm Bullrun Bison Supporter
    Nov 22, 2013
    1,080
    Bullrun, Or
    Would love to hear your thoughts on the lights
  17. GF-kam
    GF-kam Long timer
    Aug 19, 2013
    1,563
    Great Falls, Virginia, USA
    Nice !
    OK DutchyKevin everyone is asking same questions. You might be one of first posting some pics and info on new Rade Garage K3 fairing. In your post could you include:
    - More pics of install.
    - More pics of post install.
    - Does the extra weight on triple clamp ( front end ) effect how bike feels?
    - How the stock steering / handling feel compared to K3?
    - How is wind protection?
    - How is lighting?
    - Do you feel daytime visibility is good with lights on?
    - How was install instructions and Rade support?
    Thanks.
  18. DutchyKevin
    Feb 7, 2013
    66
    The Netherlands
    I dont have any useful pics from durung the installation, bur it was pretty straightforward.
    The lighting seems to be veey, very good. Strong beam with a clear line where the light stops (in vertical sense) so I won't be blinding oncoming traffic. I haven't ridden with it yet, but the kit only weighs about 3kgs so I don't think I will be able to tell the difference. Can't say much about wind protection either yet of course.
    I'll try to take some pictures of the lighting and a few extra views from the side and the rider's position later!
  19. GF-kam
    GF-kam Long timer
    Aug 19, 2013
    1,563
    C'mon Man !!! No photos and additional info. I guess you have to take it apart and start all over again ;-)
    MVI and Swiftdriver like this.
  20. bikerjim2000
    bikerjim2000 Tree Top
    Apr 1, 2015
    1,345
    Dragons Lair
    @GF-kam I have been looking for the Slave Cylinder o ring locally with no luck and was wondering if you have purchased a quantity if I could purchase one for my backup kit. My 2018 @4700 miles is working well so far! Thanks either way!!
