The KTM300 Thread
Discussion in 'Thumpers' started by GasGas300, Jan 11, 2010.
  1. guns_equal_freedom
    guns_equal_freedom Long timer
    Jul 1, 2007
    7,330
    Lutz and cal08 like this.
  2. Spino
    Spino Adventurer
    Jan 15, 2019
    25
    Boulder, Colorado
    Is it common to have to replace reed valve petals? I’ve realized the boot between the carb and the reed is worn out on my 2006 and I’m wondering if I’ll need to do the reeds too.
  3. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,076
    Reno
    Probably. Check for fraying, breaks, warpage...
    Spino likes this.
  4. guns_equal_freedom
    Jul 1, 2007
    7,330
    Pull the reed cage and see if the reeds are OK.
    Follow the advice of the previous poster (above my post) plus if you can see light between the reeds and the reed cage they are done.
    cal08 and Spino like this.
  5. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,286
    upstate
    Scott_PDX and guns_equal_freedom like this.
  6. alvincullumyork
    alvincullumyork Ol Two Flags Supporter
    Feb 26, 2012
    17,949
    Richland WA
    Is a small gap really an issue? I get a warped cage is a no no along with broken or frayed reeds.
    Scott_PDX likes this.
  7. Mountainhound
    Mountainhound Long timer
    Sep 25, 2015
    1,806
    New Hampshire
    My understanding is you don't wsnt to be able to see any light, you want a complete seal.
  8. cal08
    cal08 Been here awhile
    May 28, 2007
    962
    Calgary, AB
    Slavens has a vid somewhere where he says it's not a big deal. I think by and large that the 2T is at heart a very rudimentary motor, with similar levels of efficiency.
    This falls into 100 percent your call my friend.
    I would swap it out, but that's just me - I enjoy tinkering and i would be curious if I could tell the difference as some say. Also, if I didn't spend the cash, the SO would buy something else with it, a pillow or picture frame with gold trim, or fake flowers......
    Bitingdog and alvincullumyork like this.
  9. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    14,262
    Out in the NM Dez somewhere
    Most of the time the back pressure will cause those small gaps to seal but you never really know if it's leaking a little, at least if there's no gaps you can be pretty sure it's sealing. Id swap the OE reed valve out with Vforce 4 if the stock one was questionable.
  10. P 0 P E Y E
    P 0 P E Y E Bald rider Supporter
    Nov 13, 2008
    1,987
    southern Connecticut U S A
    Preaching to the cryer
    Another epic day on my 300. Loving it more each ride.
    In the tight single track the bike has all the boxes checked.
    The clutch is freaking awesome - one finger actuated hyperspace surge of power or traction on demand it’s mind bending
    Loft the front wheel or get power in any gear
    Tons of power but totally at will
    Suspension- of the Gods
    Super light reacts to rider weighting, de-weighting and position.
    After decades of sloppy seconds, I am so glad I chose this bike to be my first new bike I’ve purchased.
    Sorry for the Rant...as you were
    Bitingdog, nzrian, Anatoli and 3 others like this.
  11. P 0 P E Y E
    Nov 13, 2008
    1,987
    Now if I could only figure out how to get the training wheels off.
  12. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,755
    Golden CO
    Right on popeye!
    Regarding reeds, stock ones in good shape are fine imo. They are a wear item on any two stroke and I generally replace when I do a top end. If replacing the whole cage I usually go for a boysen rad valve as they seem really well made and less fiddly than the vforce/stock style. They've also got +5hp from pure nostalgia factor for this 1990s two stroke mx racer :). In all seriousness I've still got the stock setup in my 19 tx and I couldn't imagine it running any better. Popular wisdom holds that boysen rad valves add a little up top and v force/stock ads a little response off the bottom. I haven't tested back to back to confirm.
  13. guns_equal_freedom
    Jul 1, 2007
    7,330
    A new reed and reed cage made a world of difference on my 17 XCW 150.
    The Vforce I replaced it with had a tight reed to reed cage seal.
    Bitingdog and cal08 like this.
  14. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,286
    upstate
    I put v force in my 14 Berg and my 18 300xcw and I noticed a positive difference in both. Both stock cages/reeds had slight gaps in them where the vforce was tight with no gaps.
    Bitingdog and Thumperama like this.
  15. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,286
    upstate
    I raced with the tusk tire this past weekend and overall it performed well. It was mostly a rock race and the tire held up in my opinion.
    Traction was never an issue but one complaint I had was braking in the softer terrain. I was over shooting corners and locking up the rear when braking hard. Now I heard a few other guys complaining about the same thing so I don't know if it was a tire issue or the terrain that was causing it.
    There was no mud so I can't comment on how the tire performs there but I suspect it won't be a great mud tire.
    Here's a pic of the tire with 90 miles on it. 20190909_094635.jpg 20190909_094627.jpg
    Bitingdog, BikePilot, Anatoli and 5 others like this.
  16. SHEP_5
    SHEP_5 Been here awhile
    Jan 11, 2014
    958
    Western NY, somewhere between Buffalo & Rochester
    my V force reeds have some light gap and run excellent
  17. cal08
    May 28, 2007
    962
    Calgary, AB
    Appreciate the field report. *raises glass of current fav*
    kjclark7 likes this.
  18. Spino
    Spino Adventurer
    Jan 15, 2019
    25
    Boulder, Colorado
    Radiator flushing question: After draining out the old fluid, do you rinse it out with any sort of cleaner or just water? Or, do you just put the new coolant in and bleed it?
  19. scudrunner82
    scudrunner82 combustion addict
    Oct 6, 2012
    4,539
    Taghkanick, NY
    Depends how anal you are! Either way will do the job. If you flush it, just use clean water.
    Bitingdog and Spino like this.
  20. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,286
    upstate
    I drain and add new.
    But if you do flush, use distilled water.
    bikerjim2000 and BikePilot like this.
