The KTM300 Thread
Discussion in 'Thumpers' started by GasGas300, Jan 11, 2010.
  1. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    31,753
    NM
    :thumb
    I’m mostly just messin with you. I’m fairly certain that a fan can help but my belief in conspiracy theories is un-stoppable. :lol2
    Why doesn’t KTM sell the bikes with one? They have to be concerned about all these bikes out there melting down, right?
    I think that a fan restricts air flow more than it creates at most speeds. Mostly slow crawling speeds could obviously use something more than “moving along”.
    I’m going to put some heat indicator tape around mine to get some real world high temps. If it’s hot, I’ll try one. See???? I’m willing to listen and (maybe) change!
    Bitingdog and alvincullumyork like this.
  2. retroone
    retroone Long timer
    Jan 11, 2006
    2,045
    albq NM
    My new 300 TPI fan comes on maybe once a ride if that... I average 14 mph on a good day...
    Gordy likes this.
  3. adv_sacrifice
    adv_sacrifice Been here awhile
    Aug 18, 2017
    136
    i just put one on to prevent overheating. i was riding my yz450f in the woods and it would boil over with my skill/terrain. i put a fan on and didnt have the issue again (along with some other non-cooling related bike changes/added skill). so it works for me. just being proactive in keeping the bike happy since its my first 2 stroke/woods bike
  4. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,225
    On the Ground Laughing
    I am shocked how little the fan comes on.....2020 300tpi xc....
  5. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    31,753
    NM
    A 450 4T is a different animal and needs one to survive any ride.
    Ahhh.....retroone stays moving, like maybe one stop all day! :rofl
    retroone, adv_sacrifice and Nowwhat like this.
  6. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    14,074
    Out in the NM Dez somewhere
    Do you use a lower pressure cap with the catch bottle? If not anytime there's coolant transfer into the catch tank you've subjected the system to the max pressure the factory deems safe. Catching the coolant is definately a benifit but I would prefer not reach point that exceeds the pressure relief which is basically the boil over temp. I may be wrong but I thought the catch system uses the OEM rad cap.
    alvincullumyork likes this.
  7. RideFreak
    Apr 17, 2009
    14,074
    I don't think KTM pritoitizes a fan over weight on the 2T, look what happened to the subframes. These days it's all about how light they can make it and of course they expect you to rebuild pretty frequently. Also like you said there's plenty of riders that don't use one, especially guys racing. If you put tape on, place it on the bottom edge of the radiator, that will give you comparable values, placing it on the cyl will be a bit higher. You ride well enough where I doubt it would be an issue.
  8. guns_equal_freedom
    guns_equal_freedom Long timer
    Jul 1, 2007
    7,318
    For the same reasons why they don't sell them with spark arrestors or radiator guards or aluminum hand guards or....
    Bitingdog likes this.
  9. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    31,753
    NM
    That's funny, I've never ran radiator guards either and haven't got around to aluminum hand guards on the new bike either. Not sure if I will, I kinda like not having them up there. My friend messed up his wrist pretty bad when he got it caught in one so I'm deliberating the pros and cons right now. My old bush whacking bike wil keep em though.
    Btw, none of the armour things mentioned could cause an engine to overheat so that's not a valid argument. If these bikes were overheating riding like they are meant to be ridden, KTM would be forced to sell them with fans, much like they do with most of their 4Ts.
    I suspect that quite a few overheating issues are 1) jetting related and 2) clutch abuse. :dunno
    I also think that a fan on a 2T is not a bad idea but not necessarily a good one either. :scratch
    Remember, it's Ready to Race, not Ready to Idle! :rofl
  10. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,048
    New Mexico
    Their stuff is beautiful and also effective in my experience. However I went with cheaper (DeVol) guards on my 300 because they have an additional backplate (behind the radiator) to protect against folding and which I hope will make them stronger. The bulletproof guard on my 500 bowed out a bit when I dropped it on its side on a rock and the guard took the brunt. I am not complaining, given the choice at equal cost I would probably still choose them, but I am not sure the extra cost of milling the whole guard from a block results in additional strength.
    Now that I think about it, mounting a radiator fan with the Devol guards is going to be difficult because they cover the back of the radiator too.
  11. IanInCalgary
    IanInCalgary Been here awhile
    Nov 22, 2011
    277
    Will a "standard" sealed chain such as a DID VX2 fit on the '19+ bikes? The stock chain is narrower than typical so that its dimensions are close to a non-sealed (old-style) chain.
    Ian
  12. N8
    N8 I prefer my pumpkin with a blue & white mask. Supporter
    Dec 27, 2012
    5,636
    Lancaster, PA
    Yes, but my experience with the non-VT2 chains is excessive masterlink clip & pin wear.
    IanInCalgary likes this.
  13. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    12,773
    Vancouver B.C. rainforest
    I've never overheated my 300 when riding desert and flowing trails in 100°F+ heat.
    On the other hand, I have boiled over in tight and technical slow terrain, muddy hillclimbs, and situations where plenty of crawling & clutch slipping is necessary; even at below 32°F.
    I don't have a fan, but I need one sometimes photo0.jpeg 20190322_153321.jpg
  14. ChasM
    ChasM Been here awhile
    Nov 27, 2007
    739
    Loomis, CA (Sacramento area)
    The OEM rad cap is perfectly fine although I prefer the Tusk 2.0 thermo cap. I have successfully used the Tusk rad cap on two previous KTM's and my current Beta.
  15. Nowwhat
    Mar 2, 2007
    8,225
    Just buy a 2020 tpi.... they run cooler...... think of all the money you will save on a fan....
  16. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    31,753
    NM
    Does Slavens have an ECU tuner/fan bundle for that bike? :lol2
    alvincullumyork and Bitingdog like this.
  17. Nowwhat
    Mar 2, 2007
    8,225
    Oct 15th hahaha
  18. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    2,360
    Olympia, WA
    What do you need a tuner for? I did put a fan on mine but I ride a lot of slow technical ST that goes from 1500-6500 feet during the prime trial riding of the year. In winter it’s low land riding or snow biking so the fan could be taken off but I’m to lazy to do that.
  19. Spino
    Spino Adventurer
    Jan 15, 2019
    25
    Boulder, Colorado
    Another fan question: Does Trail Tech’s “universal” kit work on a bike that doesn’t have a battery? Can it run off a 9v or something?
  20. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,048
    New Mexico
    Does the bike in question have a DC electrical system?
