The KTM300 Thread
Discussion in 'Thumpers' started by GasGas300, Jan 11, 2010.
  1. Spino
    Spino Adventurer
    Jan 15, 2019
    25
    Boulder, Colorado
    Having some carb trouble with my ‘06. The bike revs really high when idling. Idle screw adjustments make no difference. I tried getting a new idle screw, but that didn’t fix it. Noticed there wasn’t an O-ring between the spring and the carb body on that screw so I added one in case that was the issue. No dice. When I slightly release the clutch while still idling the revs get more normal.
    The idle screw has worked before, fairly recently, so I think I might have messed something up recently when cleaning the carb or something like that.
    I have a JD jet kit at the leanest setting as I live at 5,000 feet and ride up to 10,000+ feet.
    Thanks in advance for the help!
  2. Anatoli
    Anatoli Pale rider
    Nov 6, 2016
    2,408
    Skagit Valley, Washington
    AC20334E-70CE-4F8D-85E7-8DE405B8D957.jpeg B7C4637E-A2E1-44A0-9097-5C4B4D45F9C1.jpeg A617A725-D6C3-4115-B536-B966E97B946E.jpeg 2B11C71F-95CA-4288-B3C0-9FDC957F07D4.jpeg Somewhere near the Canadian border lie a few hidden gems. This is 300 country.
    powderzone, Foiler, Nowwhat and 13 others like this.
  3. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    2,360
    Olympia, WA
    Anatoli likes this.
  4. Anatoli
    Anatoli Pale rider
    Nov 6, 2016
    2,408
    Walker is open all winter. I won’t be running a worn out D 606 on the rear.. I need all the help I can get. Just installed a new 525 Cheater after Mad River. I got 1100 miles out of the last one. Not bad for a sticky tire.
    Bitingdog, Dan950ser, NWBoon and 2 others like this.
  5. 1 lunger
    1 lunger Long timer
    Mar 27, 2011
    2,478
    Bloomfield CT
    Sounds like it running lean or did you AF screw?
  6. Spino
    Spino Adventurer
    Jan 15, 2019
    25
    Boulder, Colorado
    It is running pretty lean but not really more than before when I wasn’t having this problem. AS is about 2-2.5 turns out.
  7. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    15,839
    Tri- Cities TN
    Replace the pilot jet and check the float level. The passage in those jets are really tiny and the slightest build up is huge.
    2 stroke carbs, the mixture screw is an air screw. Opposite the 4 Stroke carbs that have fuel screws. Turn an air screw in to richen things up
  8. 1 lunger
    1 lunger Long timer
    Mar 27, 2011
    2,478
    Bloomfield CT
    I’m 1 or 1.25 out. 2-2.5 is a good bit
    Rusty Rocket likes this.
  9. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,278
    upstate
    Where's it running lean. Can you describe what's happening and when?
    As far as your air screw setting, at 2-2.5, it's set pretty lean.
    I'd first start by going to 1.5 and getting the bike nice and warm. Then reevaluate and if still lean, go on a quarter turn at a time and see if that helps.
    If your in more than .75, then you'll need a bigger pilot. Bump up 1 size and start at 1.5 and test.
    You also may need a bigger main but it depends on where your lean.
    If the bike has sat, it's a good idea to go in and clean it, check/ set the float height and go from there.
    Good luck, you'll get it.
  10. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,278
    upstate
    I took a 3 hour ride up to Mass yesterday to get all the parts I ordered. I also had to pick up replacement parts for the bike since mice found a home in my bike while it was in the crate for years.
    Anyway, I had to replace the wiring harness which was pretty easy.
    Then I got to putting everything else together.
    I finished up around 11pm last night and hope to get out sometime soon for its real maiden voyage.
    At some point, I'l prob take that light switch bracket off and paint it black.
    Dealer ordered a blue spring which I wasn't too pleased with but I'l get over it. 20191004_171645.jpg 20191004_191518.jpg 20191004_193720.jpg 20191004_193726.jpg 20191004_193731.jpg 20191004_202503.jpg 20191004_202511.jpg 20191004_221807.jpg 20191004_221811.jpg 20191004_221816.jpg 20191004_221820.jpg 20191004_221843.jpg 20191004_221848.jpg 20191004_221904.jpg 20191004_231054.jpg 20191004_231029.jpg 20191004_231017.jpg
  11. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    31,754
    NM
    :thumb That looks great!
    That shows part of the brilliance of the 300s. We can hit stuff like that and also take the same bike with little adjustment, blast desert whoops, climb sand hills, pick through rock gardens, race hard enduro, etc.
    When you think that we do all of this packing very few tools or parts (running the same plug for a year+) it's just crazy.
    We are living in good times to have this caliber of motorcycle available for us.
    The same praise for our trials bikes. We can buy basically the same bike that the World Riders compete on (well....except Honda :rolleyes).
    To get comparable machines in most other motor sports you would be spending hundreds of thousands of dollars.
    Just throwing some :raabia:feelgood for these bikes out there!! :lol2
    BTW, it's been pouring rain around here and the desert needed it. Might have some pics this evening. :D
  12. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    14,074
    Out in the NM Dez somewhere
    I'll be out there sunday :evil
    alvincullumyork and Gordy like this.
  13. Anatoli
    Anatoli Pale rider
    Nov 6, 2016
    2,408
    We love your pictures! There are lots of guys who can’t ride for whatever reason ( not me..) and really value the photos and video that other inmates provide. It keeps hope alive for those slogging in the trenches. I have been there, believe me. That is why I now ride absolutely as often as possible: 25 days in August..make every day count my friend. Nobody can take the good times you have shared away from you, unlike your house, children, truck, wife, etc.
  14. cal08
    cal08 Been here awhile
    May 28, 2007
    931
    Calgary, AB
    Spring looks trick. Too much orange gets all matchy matchy. My 2 cents. If any ones asks, just tell them it goes to eleven.
  15. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    12,782
    Vancouver B.C. rainforest
  16. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,278
    upstate
    Oh man
    Just came back from my first trail ride on the xc. Now I see why all the fast guys around here run the xc. That bike just wants to go. The suspension felt promising but needs to break in and will need some fine tuning.
    I knew within the first 5 minutes of riding that I was going to like the xc and linkage.
    I know how my setup xcw reacted over every bump and this bike is just better. I can't wait till I get it dialed in... it will be incredible.
    I did notice climbing some hills that my xc doesn't have the low end grunt that the my xcw had. The bike is still breaking in so time will tell. Only 2 hours on the girl now.
    I can't wait till my next ride where I'l experiment with the psi a little more. 20191005_182343.jpg
  17. guns_equal_freedom
    guns_equal_freedom Long timer
    Jul 1, 2007
    7,318
  18. kjclark7
    kjclark7 Long timer
    Jul 13, 2008
    3,278
    upstate
  19. guns_equal_freedom
    Jul 1, 2007
    7,318
  20. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    31,754
    NM
    Don’t bother. We wrecked the place! :rofl
