The KTM300 Thread
Discussion in 'Thumpers' started by GasGas300, Jan 11, 2010.
  1. alvincullumyork
    alvincullumyork Ol Two Flags Supporter
    Feb 26, 2012
    19,993
    The dry part of the PNW
    The bike is basically brand new, 5 hours on it when I put the new rotor on.
  2. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,039
    On the Ground Laughing
    head bearings loose...?
    petew and Bitingdog like this.
  3. alvincullumyork
    Feb 26, 2012
    19,993
    That would cause a surge in the front brakes? The bike feels perfectly normal everywhere else. High speed through the whoops, jumps, turns, etc. The problem started when I took the stock rotor off and put on an aftermarket rotor. I'm going to swap back and see if that fixes it.
    petew likes this.
  4. Nowwhat
    Mar 2, 2007
    9,039
    Did you buy an ebay Amazon rotor?.....shame....ding ding....shame....ding ding
    Bitingdog and alvincullumyork like this.
  5. alvincullumyork
    Feb 26, 2012
    19,993
    You should know better! :lol3
    It's a fancy one.
    Nowwhat likes this.
  6. adv_sacrifice
    adv_sacrifice Been here awhile
    Aug 18, 2017
    325
    my 690 has a weird surge too when i put on my warp 9s. havent bothered trying to figure it out quite yet though
  7. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,532
    New Mexico
    Did you replace it after only 5 hours because the OEM took a solid hit? I bent a rotor like 30 degrees out and unfortunately it bent the hub as well, after ruining a couple new rotors I noticed a brand new rotor would not sit flat on all the rotor contact points at once.
    alvincullumyork likes this.
  8. alvincullumyork
    Feb 26, 2012
    19,993
    I took the OEM one off to replace a bent one on my 300. The bike with the surge is my 350 and it's only been down once and it was fine after that for the next 2 hours of ride time. It only happened when I put the new rotor on.
  9. guns_equal_freedom
    guns_equal_freedom Long timer
    Jul 1, 2007
    7,452
    A bad new rotor.
    I had a Suzuki TL1000R, the one of the stock rotors was bent, that caused the brakes to pulsate and not work at sppeds above 40 mph.
    I replaced them with new EBC rotors.
    I had the same issue.
    I ended up replacing the fork tubes from a GSXR 750 to get the radially mounted 4 piston calipers (the TLR had 6 piston calipers that mount "normally").
    I mounted up the EBC rotors and again I had the same problem.
    I took my machinists straight edge and found that the old TLR and GSXR rotors were bent as was the "new" set of EBC rotors.
    I ordered a new set of rotors from EBS and they were bent too.
    FML.
    I ended up buying a set of Galfer rotors and - no more brake pulsing.
  10. alvincullumyork
    Feb 26, 2012
    19,993
    I've already gone through one new aftermarket rotor and am now on the second one. I guess two could be bent in a row still in the package.
  11. NCwolf
    NCwolf Been here awhile
    Nov 7, 2018
    102
    Raleigh, NC
    Appreciate it. It is an older bike but like I said, it'll be the newest one in my fleet. Plus I think I can upgrade later and pretty much get out what I put in it.
    :D
    What sold me was the fact that it's bone stock and literally looks like it just rolled out of the dealership. Around 3k was my budget anyway, and that tends to be pretty much rock bottom for a decent KTM around here, so I think it's not a bad deal. Will have some money left over to add a skid plate, tubliss, and a few other goodies before hitting some single track.
    Can anyone tell me what the gas tank on this bad boy might be off of? It is obviously not a W tank but the owner assures me the bike is an XC-W. I'm assuming someone swapped over an SX tank or something...for reasons I don't understand. He's only had it for a month; bought it from the original owner.
    Along those lines, does anyone make a translucent tank for this year? All I've found is natural color but I like the looks of the translucent.
  12. guns_equal_freedom
    Jul 1, 2007
    7,452
    It's an aftermarket high capacity tank.
    It could be IMS, Acerbis or Clarke.
    It could be a a KTM Power Part made by one of those companies or someone else.
  13. GlennR
    GlennR Chasin' my tail
    Nov 4, 2010
    3,937
    Sugar Grove or Denver, NC
    I don't see lights on it. I thought XC-W's have lights. I see it says "XC-W" on the black side panel, but the shroud looks like it reads "XC". I think an XC might have a smaller tank and no lights. (I'm far from a KTM expert...) I can't see a speedometer on it either.
  14. NCwolf
    Nov 7, 2018
    102
    Raleigh, NC
    best I can tell is those shroud graphics that just say XC are correct for the W, and this generation never came with lights. The Speedo and kickstand he did say have been removed but he has them. So really it's just the tank that doesn't match. But who knows, maybe the original owner just wanted a smaller tank.
  15. Anatoli
    Anatoli Pale rider
    Nov 6, 2016
    2,675
    Skagit Valley, Washington
    First check the rotor with a machinist straight edge prior to installation. Then check dynamically ( rotating on the hub/ wheel assembly) with a dial indicator. This will confirm runout. As earlier noted, new rotors can be out of spec, and a bent hub will deform an otherwise in spec rotor. The stock KTM rotors are very thin to save weight. I also have had great luck with Galfer rotors. They are thicker, therefore resist crash damage better and seem to be consistently high quality. About $82 for a rear rotor from Slavens.
  16. vtwinjunkie
    vtwinjunkie Been here awhile
    Oct 3, 2011
    206
    I have been looking at the Dal Soggio XP1 kit for my 2018. How would you compare the kit over the stock setup?
    Mine feels a bit mushy from the factory
  17. vtwinjunkie
    Oct 3, 2011
    206
    your profile pic looks like the overlook from Dirty Dabbers Dual sport ride...Bald eagle state forest?
  18. pjh66
    pjh66 lost in the sauce
    Jul 5, 2009
    121
    Murrieta, CA
    Nowwhat likes this.
  19. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,532
    New Mexico
    Is the front brake definitely not dragging? Maybe the aftermarket is a bit thicker and there's too much fluid in the master to let it retract further? Or not enough free play in the brake lever because of an aftermarket handguard or something? These offroad rotors are pretty light and I would imagine warp quickly if dragging.
  20. alvincullumyork
    Feb 26, 2012
    19,993
    Not dragging and it happened immediately upon install.
