The KTM300 Thread
Discussion in 'Thumpers' started by GasGas300, Jan 11, 2010.
  1. N8
    N8 Masked pumpkin rider Supporter
    Dec 27, 2012
    9,282
    Lancaster, PA
    Interesting. My 125 looked like that after cold seize but tested at 195 psi. Also felt "off".
  2. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    19,926
    The bad side of the PNW
    Haven't pulled it out yet, but suspect clutch side. The odd whiff of transmission oil when starting it hot, occasional racing idle.
    Bike has been boiled in the gnar a few times, which tends to cook them.
    *Just put it off amongst work, kids, elderly parents, and a moody wife.
    alvincullumyork likes this.
  3. 911
    911 Been here awhile Supporter
    Mar 16, 2016
    497
    maine
    Okay
    I installed the tusk fan kit with temp gauge.
    It works really well.
    Bitingdog likes this.
  4. 911
    Mar 16, 2016
    497
    maine
    I did not expect this tire to perform well because it's about $60 and made in china.
    But the tusk recon has a gummy compound and works really well.
    They run on the big side.
    Was running a dunlop 803 trials.
    230 miles on it in the photo
    alvincullumyork, cal08 and Bitingdog like this.
  5. vtwinjunkie
    vtwinjunkie Been here awhile
    Oct 3, 2011
    259
    I went down one in the front on my 250 xcw and its perfect for me riding enduro style stuff. Took a bit more off the top than I would have liked but its amazing to have 2nd and third for the hill climbs.
    Later this year when I put my 300 kit on... 2018 carb bike so I can do that ;) Ill have to figure it all over again.
    MadM likes this.
  6. vtwinjunkie
    Oct 3, 2011
    259
    I really like the recon as well. They do well on small bits of road, as well as gravel forest roads and seem to last a long time! Diddnt work well for me in enduro type stuff but decent.
  7. TrailBreak
    TrailBreak Willfully Stupid
    Nov 10, 2014
    299
    Vermont
    Does anyone know if a 2020 XC rear fender will mount up to a 2020 XC-W minus the underfender/license plate holder? Asking for a friend who looped it......:doh
  8. adv_sacrifice
    adv_sacrifice Been here awhile
    Aug 18, 2017
    573
    i thought i liked the recon at first. it was an improvement from the stock AT81 but didnt like it after a while. wouldnt hook on anything wet and would spin quite a bit on rocks
    yes. i pulled both my lights off and put xc panels
    TrailBreak likes this.
  9. N8
    Dec 27, 2012
    9,282
    Lancaster, PA
    This might be a dumb question but why would you think tranny side crank seal failure would have caused that issue? I have ridden a couple bikes with leaking tranny side crank seals and never seen it do anything like that.
  10. vtwinjunkie
    Oct 3, 2011
    259
    Yep they should be the same minus the mounts for the rear brake light holder piece.
  11. vtwinjunkie
    Oct 3, 2011
    259
    I had the same issue with rocks and lack of traction in areas that I needed it but for gravel riding or light easy trails it is ok. I decided on two sets of wheels so that I could have these for times when I diddnt want to eat up my VE33s 's
  12. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    16,895
    Out in the NM Dez somewhere
    I just put one on the 300 to try out, I've been running it @ 8psi. Its got a big footprint for a 110 tire.
    So far its only seen desert, out there any fresh knobby works pretty well so I'm not sure what I think about it. Price was right though.
  13. 911
    Mar 16, 2016
    497
    maine
  14. Bitingdog
    Apr 2, 2015
    19,926
    I tried a Tusk gummy, and it had decent traction when perpendicular to the rock, but it would let go quick if leaned over.
    Also felt a bit spooky on the fast sections, even at 12 psi. It looks like a very soft sidewall that doesn't really work with the tread?
    I ruled it as "not ready for prime time". Prefer (in no particular order) the Kenda, Shinko, IRC, and Dunlop gummies. But I'm also a bit of a tire slut, so take it with a grain of salt.
    :rofl
  15. Bitingdog
    Apr 2, 2015
    19,926
    That was the prevailing wisdom, but possible it's the other side? Just guessing. But that suggestion was from our local two-stroke race engine builder. I did run the piston way too long also, FWIW
    Whizzelberry school of maintenance...
  16. N8
    Dec 27, 2012
    9,282
    Lancaster, PA
    I think that'd be the other side indeed.
    Bitingdog and alvincullumyork like this.
  17. RideFreak
    Apr 17, 2009
    16,895
    Did it seize on the last ride? I'm skeptical about the clutch side seal also, more likely the ign side. When the RH seal goes out it will typically smoke like no tomorrow, at least till it burns down the tranny fluid below the seal level. But...if the tranny oil was low enough it's possible and you might not have that. I'd look closely at the crank bearings also to see if there's any play, some 250/300s have had them fail, some due in no part to how it was ridden or maintained, just a few bad parts. Leaky seals are one of the symptoms, most other air leaks could cause a similar failure.
    I'm curious BD, did you check to see how much coolant was in the radiator when you drained it? Or have you had to add any coolant recently. The "getting real hot" a couple times is what points me in that area, a blown head oring can cause a similar seizure and is usually caused by overheating. Many times all you'll notice is the bike's running is a little off right up till it siezes. It's because when that happens there's no coolant circulating in the system to turn the fan on so it sits there fat dumb and happy till it melts down. Sometimes you'll be able to smell it as parts on the motor get toasty, it'll be pretty obvious, coolant is very low or out and the damage will be visible on the inner head o-ring.
  18. timeOday
    timeOday Long timer
    Jun 20, 2008
    4,397
    New Mexico
    Go on, spill the beans,how many hours on the piston.
    I think I speak for everybody on the internet when I say that we will be real nice about it :photog
    Bitingdog, Anatoli and Rusty Rocket like this.
  19. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,139
    When you have the cover off play with the fly wheel. Any movement of the fly wheel and its crank bearing time.
  20. 911
    Mar 16, 2016
    497
    maine
    Hopefully less than 400 !!
