The Lifan engine thread
Discussion in 'Battle Scooters' started by hugemoth, Feb 22, 2011.
  1. YamaGeek
    YamaGeek Skeletor sparklemuffin.
    Jun 24, 2007
    31,325
    western oregon
    If I'm not mistaken the Lifan-ZongShen OHV engines are all based on installation bolt footprint of the Honda 125 vertical cylinder engine from the 1970's. I do believe the SL and XL 100 engines are slightly smaller, but I would also expect the clone engines could be installed with custom mount plates in the Honda vert cylindered 100cc bike frames.
  2. PTC
    PTC Turd polisher
    Nov 20, 2008
    835
    masshole mofo
    FINALLY got around to stuffing the 3 valve lifan in this.
    Pretty fun. Hit 45.
    I’m sure it could pull 55+ with a bigger exhaust, but I just had to keep the stocker.
    Gonna look into possibly making a bigger baffle.
    The stock pipe goes down to penny size! EC274BDD-C263-4B51-8403-18391936B576.jpeg
    CJ3Flyer, rdhood, Pete-NZ and 4 others like this.
  3. PTC
    PTC Turd polisher
    Nov 20, 2008
    835
    masshole mofo
    I know they are the same as the Honda z50/ct70
  4. YamaGeek
    Jun 24, 2007
    31,325
    western oregon
    I'm talking about this engine...
    Which is not the same as the Honda clone horizontal engine.
  5. PTC
    PTC Turd polisher
    Nov 20, 2008
    835
    masshole mofo
    Gotcha!
    I read too fast
  6. WECSOG
    WECSOG Dirt Road Denizen
    Mar 30, 2013
    1,949
    Just past the pavement's end in North Alabama
    Nice! ST90, right?
    CJ3Flyer likes this.
  7. PTC
    PTC Turd polisher
    Nov 20, 2008
    835
    masshole mofo
    Yessir. Circa 73. Mighty green
    CJ3Flyer and WECSOG like this.
  8. 11motos
    11motos Feral Rider
    Oct 27, 2017
    2,296
    On the Road
    What is the maximum displacement for either one of those designs?
    I mean, including big bore kits available.
    I have seen vertical with 250 factory and horizontal with 140 but nothing higher.
  9. Franque
    Franque Been here awhile
    Apr 26, 2015
    457
    Dallas, Tx -> Aubagne, France
    229ccs for the vertical motors (the 250 is marketing speak), and you can buy a 190 horizontal motor, but there is a kit that'll make it a 212cc motor, and you can get a 4v head, but you'll need to run an oil cooler. There are Chinese air-cooled 250s, but they're a somewhat redesigned architecture. For that CG you posted, it's either a 223 or 229 depending on who made it, and when.
    WECSOG and 11motos like this.
  10. fullmetalscooter
    fullmetalscooter Let me take this duck off
    Apr 28, 2009
    4,964
    BC
    Anyone post this since it it's running a Lifan engine . Basically it's lifan engine sport 250 cc or is 200 cc ? bike that's 2400.00 off Amazon.com and the kicker is you can buy the after market warranty for $250 for 3 year off amazon to. The same company the insure cell phone etc will give you 3 year of warranty. No it's not a honda but for 2400 what you bitch about . Bonus is that you could ride it and when it brakes down you ve got the warranty for 3 years. Even in 3 year it's still going to be worth at least a grand .
    if you ever wonder how much abuse a Lifan engine can take watch .
    WECSOG and "None" like this.
  11. CrapKerouac
    CrapKerouac Long timer
    Sep 19, 2019
    1,410
    Canada
    In the first video he said it looked better than the 1st gen Kawasaki 250 then proceeds to thrash the hell out of it in the second. Impressive little bike. Richard Hammond rode a Chinese bike to hell and back in one of the road trips in I think, Top Gear? That one held up well, as well. Cheers, good link.
  12. pnw
    pnw Long timer
    Oct 30, 2012
    1,707
    I'm wondering how necessary an oil cooler is for a 140cc and if I should add one to my lifan - one of the 120/125cc with 140cc BBK? This is a good time for me to order one if needed, especially since shipping is so slow these days.
  13. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,737
    NW of Philly, Hoboken, Brooklyn.
    I have an oil-cooler installed with my 140cc engine.. it helps.. but can't really tell how much. Maybe better placement of the cooler can make it more effective.
    IME, 140cc engine has too much vibration, 125cc is much smoother.
  14. hugemoth
    hugemoth Big Brother is watching you!
    Sep 6, 2007
    4,716
    RESIST!
    The 140s require an oil cooler and the crankcase has an inlet and outlet port built into it. The 125 crankcase doesn't have the ports but a cooler kit is made to attach to the cylinder head. Can't hurt to have a cooler unless you snag a line on something and pump oil all over your shoe.
    WECSOG, Dirt Road Cowboy and pnw like this.
  15. wanna bECO
    wanna bECO Long timer
    Jul 3, 2008
    1,110
    Third stone from the sun
    My self and 2 other friends all have harley's . We all have an oil temp gauge. I have an oil cooler. I run 40 degrees cooler than them when we all ride together. At gas stops and such we will do a temp check and always.... I am 40 degree's cooler. FWIW
    pnw and WECSOG like this.
  16. Cat0020
    Cat0020 El cheapo
    May 1, 2002
    6,737
    40 degrees out of how much for baseline?
    pnw likes this.
  17. wanna bECO
    Jul 3, 2008
    1,110
    They will get close to 200 degrees. Sometime a bit more.
  18. pnw
    pnw Long timer
    Oct 30, 2012
    1,707
    Is 200 degrees a good temp? Any idea what would be excessive temp? I have a non-contact infrared thermometer that I can use to check and monitor head temps if that would be representative.
    Edit: I found this with a web search and will go with that for now.
    "Most air cooled engines should never exceed 300 degrees. They usually run around the mid 200's. The reason is because the oil breaks down at 300 degrees."
    "None" likes this.
  19. Alzero
    Alzero Been here awhile
    Jan 13, 2019
    241
    Onboard
    Any information on the Lifan copy of the 250cc Yamaha Virago engine? I see a few for sale on eBay.
  20. 11motos
    11motos Feral Rider
    Oct 27, 2017
    2,296
    On the Road
    Thanks. I was reading and I guess you are right those are all 229cc.
    It looks like the 400cc , like the Shineray, are a newer thing and at a different tier like brands Mash, Herald, CSC etc... and they seem reissues of the old classic 4 valve honda engine with the dry sump.
    But it also seems weird they do not have the same 230cc in 290 or 340 or whatever the next bore step is and no big bore kits for them neither?
    Also could not find any or reliability reports even they seem to make millions of those.
