The Lifan engine thread
Discussion in 'Battle Scooters' started by hugemoth, Feb 22, 2011.
  1. hugemoth
    hugemoth Big Brother is watching you!
    Sep 6, 2007
    4,492
    RESIST!
    Lifan is the most common Chinese vertical engine you'll find on Ebay but there are other brands. Most of them are clones of the Honda CG125 and you'll find them up to 250cc. I have a Lifan 200 with the CG type engine and also a Zongshen with the same type but slightly different. I haven't put many miles on the Zongshen yet but it appears to be equal in quality to the Lifan. As far as measurements to determine if it'll fit you'll have to search google
  2. WECSOG
    WECSOG Dirt Road Denizen
    Mar 30, 2013
    1,795
    Just past the pavement's end in North Alabama
    I would say definitely, go for it! I bought one of those Lifan 200 engines and am getting ready to install it in a '72 XL250.
    I'm pretty sure it can be made to fit a CL175 frame without too much trouble.
  3. BiellaBound
    BiellaBound Adventurer
    Jan 26, 2015
    11
    Thanks for the info, I am not very familiar with Chinese engine yet.
  4. BiellaBound
    Jan 26, 2015
    11
    Yeah I am leaning there, but that 175 engine had a mean looking dual exhaust, it's going to take a little to beautify the lifan. Overall I am going for the modded triumph scrambler look. ImageUploadedByTapatalk1422421257.632358.jpg
  5. WECSOG
    Mar 30, 2013
    1,795
    It doesn't have the Triumph scrambler look, but it is a good looking engine. Plus it has that thumper sound that is even more unmistakable than the Harley V-twin sound everybody talks about. A pushrod thumper is a really cool and uncommon engine. You could go for more of an Enfield Bullet scrambler type look and sound.
    The Honda twin doesn't sound like a Trumpet anyway, because it is timed differently.
    It's your bike, though. Those Triumphs are cool looking bikes.
  6. BiellaBound
    Jan 26, 2015
    11
    Yeah man they are beauties.
    I am going to push it as hard to that look as I can. Contrast sump guard.
    I think I am Definitely taking out that Honda engine and making it mine. Also getting a new electrical system would be great.
    The triumph hopefully in a couple years.
    Soon I will set up the build thread. Been siting in my basement mentally dissecting the bike to see where I want to take it.
    There is a lot of awesome as on the bike that just needs some cleaning up
  7. WECSOG
    Mar 30, 2013
    1,795
    Looks like a great project! Let us know here when you start the build thread so we can tag along.
  8. BiellaBound
    Jan 26, 2015
    11
    For sure, probably going to start dissecting soon, first off is the seat, only because I am a Tailor so it should be the easiest challenge.
  9. hugemoth
    Sep 6, 2007
    4,492
    RESIST!
    Last time I had the clutch cover off the 200 I observed a little play in the cush gear that drives the counterbalance shaft. Many cush gears utilize steel springs and when they start to deteriorate, the gear itself gets loud and eventually comes apart. I opened the gear and found rubber cushions instead of springs so no need to replace. Here's a pic of the disassembled gear.
  10. WECSOG
    Mar 30, 2013
    1,795
    Looks pretty well-built. Do you have a source for replacement bushings?
  11. hugemoth
    Sep 6, 2007
    4,492
    RESIST!
    No, haven't looked for the bushings alone, just the whole gear. Replacing the rubber parts requires drilling out the rivets which is probably too involved for most people.
  12. Frey
    Frey motocrossdresser
    Feb 2, 2012
    409
    Columbia, SC
    Hi can anyone help identify this engine? XR200R was in a fire, might buy for cheap, first thing I noticed was electric start, then saw Lifan on the side of the case.
    Any idea of motors abilities? XR200 is 6 speed, would this be? Thanks! :thumb
  13. hugemoth
    Sep 6, 2007
    4,492
    RESIST!
    What is the number on the engine. Should be something like a LF169FML. Looks like the OHC 200, should be a 5 speed, about 16 hp.
  14. Frey
    Feb 2, 2012
    409
    Columbia, SC
    Hi,
    I bought the bike, its a 163FML, It looks just as bad as in the photos but starts sooo easily. I've ordered some parts and will post some pics when I get to putting things together.
    The only thing about these is since they are new there isn't much information. I tried to find which oil filter they use and I guess they don't use an oil filter? That seems crazy, I should get a magnetic drain plug for sure.
    Also does anyone know what headers work? If the XR200, XL125, and XL185 use the same head does that mean they use the same header? Theo one on this bike is a little patched together with some welds.
    Otherwise a very cool/cute bike that I like a lot already.
  15. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,255
    may have a centrefugle oil filter behind the right engine case
  16. shredxcam
    shredxcam Cam
    Mar 23, 2015
    61
    vegas slots
    Oil screen
  17. AGAUBERG
    AGAUBERG Adventurer
    Jun 27, 2015
    25
    Milwaukee, WI
    What?! Really?! I was thinking about getting one of these: http://www.ebay.com/itm/140981274897?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    And you don't think this will put out enough electrical power for street use (headlight with hi-low, tail light, 4 turn signals, gauge cluster lighting, etc.)?
  18. deezildennis
    deezildennis Its a what?
    Jul 28, 2007
    1,019
    in the powa band
    Get ahold of the guys at Tbolt USA and tell them what you want and that you need it to run lights for the street.
    They helped me set up my lifan 140 for street use with lights. The guys at the Planet minis forum can help you out as well.
  19. fullmetalscooter
    fullmetalscooter Let me take this duck off
    Apr 28, 2009
    4,675
    BC
    Anyone know if these 200 cc Lifan bolt into the old cb or cl or xl honda Frames ? Just wondering .
  20. WECSOG
    Mar 30, 2013
    1,795
    Yes, they fit just fine. You might have to do some minor modifications, but nothing serious.
