The little/light Camper Trailer Thread...
Discussion in 'Camping Toys' started by Jurgen, Mar 2, 2010.
  1. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    11,724
    Orange County, CA
    maybe a tongue extension and a multi direction pivoting hitch would be a good addition as well.
  2. gweaver
    gweaver NorCal is Best Cal! Supporter
    Aug 20, 2005
    3,412
    Sonoma County, CA
    +1 on the batwing- mount it on the side of the trailer so when it opens, it shades the rear too- that should give you shaded coverage over both doors (assuming you have a side door). I picked up mine from AutoAnything- mounted it on my truck for shade on the side and rear. Works a treat.
    G
  3. keyzard
    keyzard Falls over a lot....
    Aug 14, 2007
    314
    Buffalo Area, NY
    Our 12v ARB knock-off refrigerator (I forgot the manufacturer, and it's in the camper for its winter hibernation) was a game changer for us. We used to use it instead of our propane fridge in the camper for weekend trips. It's an actual compressor fridge, not a cooler, so it will maintain whatever temp you set it to no matter what the ambient temp is. We usually kept ours at 35F. A single deep cell battery of around 100AH plus a 100 watts of solar will run it indefinitely. Maybe a little more complex than you wanted to get but not having to deal with ice is really nice.
    mbabc, katbeanz and motogoat like this.
  4. jjustj
    jjustj Long timer
    Jun 14, 2005
    7,084
    Olympia WA 95 feet
    I owned a Uhaul (Casita like) trailer for years, currently on my 4th camper, however its a class b motorhome. Just saw this and thought it had some nice features, but lackss others . . I also have an enclosed trailer we pull and can camp out of when needed. I do like the thought of the cheap amazon or ebay heaters and or 12volt electric mattress pads for the bed. The only thing better than crawling into a warm bed is having a hot towel after a shower. Yes Im spoiled but, I deserve it! lol. Love the Ideas bantered about on this thread!
  5. coffman300
    coffman300 Long timer
    Jul 8, 2012
    1,129
    stagecoach Nevada
    I don't know what you are doing for power but i made this a few years ago and i made it portable so i can take it when i tent camp also .its just a deep cycle battery and a 100 watt solar panel. I put a 32" tv in the camp trailer and run it through a 125 watt inverter and can watch tv as long as i want at night. It will also run my home made shower unit
    20191106_070242.jpg .
    Rufjeep, Dryslick, mbabc and 2 others like this.
  6. Dryslick
    Dryslick Been here awhile
    Feb 11, 2011
    221
    Lake Berkely, Montana
    The battery pack looks like a great setup, with properly set up controls & switching. Could you provide details of what all you’ve got going on there? For us less than electrically literate? Thanks.
    Davidprej likes this.
  7. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    13,221
    Connecticut
    A lot of campers have a twin propane tank on the tongue. I was wondering is a dirt bike rail there instead would be perfect.
  8. coffman300
    Jul 8, 2012
    1,129
    stagecoach Nevada
    Ok . Its a old ammo box big enough to fit a full size interstate deep cycle battery in. I mounted all of the electronics on a 1/2 " peice of plywood with a thin peice of aluminum glued to it just for looks that i powder coated in silver vein. It has a volt meter, usb ports and 2 12v sockets one inside and one outside on the front of the box next to the + - post so i can use jumper cables if i need to. I put a quick connect for the solar panel on the side of the box.and a 15a circuit breaker in line with the solar controller for protection and i can shut everything off so it has no parasitic draw when im not using it. I plug a 12v 125 watt inverter into one of the power ports then i can plug my camp trailer into the inverter . I've changed all of the lighting in the trailer to led . I can run all of the lights and the tv off of the little inverter at the same time but i only need 1 or 2 lights on at a time.. everything is ran through a fuse block just so i dont start a electrical fire. Before anyone comments its a lead acid battery and the box has vent holes.
    overlander, marret, Hannda and 5 others like this.
  9. Davidprej
    Davidprej Davidprej Supporter
    Dec 27, 2012
    666
    Lafayette, LA
    OK, now that you've explained it in detail, how much for you to make one for us? This is sort of like a tonsillectomy being an easy surgery. Well, it ain't if you aren't a doctor! Very well done, my friend!
  10. villageidiot
    Apr 29, 2010
    11,724
    Orange County, CA
    my quick estimate is theres $300 ish just in parts, nevermind the can, or the labor, powdercoat etc.
    HapHazard and coffman300 like this.
  11. Davidprej
    Dec 27, 2012
    666
    Lafayette, LA
    Ok, I'll give him $310. Done and done!
    Hannda, HapHazard and imnothng like this.
  12. villageidiot
    Apr 29, 2010
    11,724
    Orange County, CA
    thats about right.
    HapHazard and Davidprej like this.
  13. coffman300
    Jul 8, 2012
    1,129
    stagecoach Nevada
    Around $375. The parts you don't see like 4 gauge battery cables, fuse block .terminal blocks on the battery post . You know $20 bucks here and there. But a fraction of the cost if you price a solar generator on line. I've used this setup for 10 day camping with no issues. I do powder coating for a living so that free and i got the box at a garage sale full of nuts and bolt for 5 bucks. I built the whole thing from amazon minus the battery.
  14. villageidiot
    Apr 29, 2010
    11,724
    Orange County, CA
    oh trust me, i get it!
    300ish is 375 all day long!
    HapHazard and nevermind like this.
  15. coffman300
    Jul 8, 2012
    1,129
    stagecoach Nevada
    The solar setup was over half of it. I used to use it camping for a couple of days the put it on a trickle charger when i got home but you really have to watch how far you run the battery down. And its hard on the battery.
    villageidiot likes this.
  16. villageidiot
    Apr 29, 2010
    11,724
    Orange County, CA
    So is that $375 including the panel? If so, that’s a bargain.
  17. coffman300
    Jul 8, 2012
    1,129
    stagecoach Nevada
    Yes roughly
  18. coffman300
    Jul 8, 2012
    1,129
    stagecoach Nevada
    I went back through my amazon history and added it all up and im in the whole thing including solar kit and it = $420.00 the bulk of it was the battery = $105 solar kit $152 and the Guage panel made by blue sea $70
    Hannda and villageidiot like this.
  19. donmac
    donmac casual angler
    Jun 26, 2010
    500
    East Coast
  20. Bultaco206
    Bultaco206 Back-to-back motos suck Supporter
    Feb 11, 2007
    45,800
    Mineral Point, WI
    If you catch them at the right time...I bought from Goal Zero directly and saved hundreds. So much so that I really couldn’t have built my own system for my trailer all that much cheaper. Plus, it’s already been pressed into duty to power the fridge in my house during a couple of power outages.
    garandman and Hannda like this.
