1. eNewsletter Sign Up
The New Schuberth E1 Finally a True Adventure Helmet
Discussion in 'Equipment' started by GCecchetto, Aug 28, 2015.
  1. Don Coyote
    Don Coyote Long timer
    Oct 3, 2008
    3,185
    Upper Midwest, US
    After continued use commuting in the E1, i found a couple of tricks. First,the turbulance was much more noticible with the peak in the highest postion. At highway speeds i would lower the peak and it proved to be more stable. Not perfect by any means, i expect Schubert to address this in the E2 or maybe E1 Pro.
    Second, what is the point of those locking levers for the peak? After a few times of locking and unlocking the peak, i just started leaving it unlocked. It never showed any sign of moving around on it's own, as much as it would vibrate in any position. I could see if you wanted it to stay in the top or middle position while going through some brush, but no, they are actually useless. If one of my levers broke off, i don't think i'd waste the time to replace it as long as it could be left in the unlocked position. Think of how much weight you are saving!
  2. mosey.levy
    mosey.levy Long timer
    Jul 13, 2013
    2,473
    NYC
    It really depends on your setup. The peak doesn't bother me in any way unless it's very windy out and on those days I can pop it off in under a minute. On sunny days it's a godsend. Putting it in to the lowest position helps so often. Then back to middle most of the time. I don't get the high position so much.
    5'9". 2015 R1200GS stock windshield usually in high position.
    I'm gonna do a video review soon. If anyone wants me to hit any specific topics let me know.
  3. Viking84
    Viking84 Long timer
    Jun 7, 2015
    1,467
    Norway
    Has anyone had any experience with the built-in comms unit? From what I gather there is a Cardo version (SRC) and a Sena version (S10U) - are any of them any good or am I better of getting an external unit?
    Ks600 likes this.
  4. mosey.levy
    Jul 13, 2013
    2,473
    NYC
    I believe schuberth is coming out with a new unit soon made by sena instead of Scala.
    If you want something now go 10U or 20S.
  5. Motodisiac
    Motodisiac Moto Terrorist
    Jan 13, 2006
    3,963
    City Of Angels
    It's been out for a while, SENA 10U is exactly what Schuberth will be selling as their OEM solution.
    D.
  6. Bad Wolf
    Bad Wolf High functioning sociopath
    Jan 5, 2008
    20,322
    Galactic sector zz9 plural z Alpha
    I wanted to love the 10U ans throught it was a really nice unit, but unless you have a large shell, ot throws off the sizing just enough to create hot spots.
    mosey.levy likes this.
  7. Don Coyote
    Oct 3, 2008
    3,185
    Upper Midwest, US
    Did you have the large unit on a small shell helmet?
  8. Bad Wolf
    Jan 5, 2008
    20,322
    10U is only 1 size. I had the standard 10U in a medium helmet and it was tolerable for up to 4 hours of ride time before the hot spot at my forhead and over my right ear got bad. My more significant other tried in her small helmet and we had pulled it out of there within the first hour.
    Those are the only comlaints I found of the unit. If you use a large shell, the 10U is a very awesome add on item.
  9. Schussboelie
    Schussboelie Kicking up dirt Supporter
    Jul 22, 2013
    991
    Belgium
    I think he was referring to the all new Schuberth SC1 (also produced by Sena) that fits the all new C4 and R2 helmets.
    The 10U is a Sena branded unit and not Schuberth OEM.
    It also exists for the Shoei Neotec for example.
  10. mosey.levy
    Jul 13, 2013
    2,473
    NYC
  11. Motodisiac
    Jan 13, 2006
    3,963
    City Of Angels
  12. mosey.levy
    Jul 13, 2013
    2,473
    NYC
    Go with the 20S. Best one I've seen so far. Unless you wanna spring for the new 30K model :)
  13. Viking84
    Viking84 Long timer
    Jun 7, 2015
    1,467
    Norway
    The 30k is tempting, but it won't be available in time for spring I fear. I also quite like the idea of a fully integrated system, less external bits to get caught in the wind :)
  14. Crowmoto
    Crowmoto Adventurer
    Mar 15, 2017
    74
    nh
    does anyone know if the TT mod has more field of view than the E1?
  15. Don Coyote
    Oct 3, 2008
    3,185
    Upper Midwest, US
    The peak on the Schuberth has some problems with turbulance under certain conditions, but it does an excellent job actually improving visibility under various sun positions. The AT950 peak is a fashion accessory.
    I now have a Caberg Xtrace and can tell there is the same turbulence coming at the top of my head sometimes, but the more rigid peak doesn't vibrate enough to annoy like the Schuberth. It also doesn't adjust and isn't shaped to work as well to adjust to sun conditions as the Schuberth, so a bit of a trade-off there.
    Patiently waiting for the E1 Pro or E2, hoping it isn't some $1000+ electronic gizmo shack...
  16. Viking84
    Viking84 Long timer
    Jun 7, 2015
    1,467
    Norway
    Having tried both in the same shop I'd say they are absolutely identical in terms of fit and field of view. For some reason the helmet just didn't fit my head, so I ended up with an Arai X4 instead :)
  17. I82l8
    I82l8 Been here awhile Supporter
    Mar 17, 2014
    637
    Stouffville, ON
    Is anyone here using goggles with their E1?
    If yes, what goggles do you use?
    Thanks.
  18. Crowmoto
    Crowmoto Adventurer
    Mar 15, 2017
    74
    nh
    Hey I just noticed you have the Rottweiler Mirrors. I bought them months ago and have yet to put them on my 701 because I wanted to find the right hadguards .. did you drill thru the Hdb hand guards? could you possibly send me some pics??
  19. GCecchetto
    GCecchetto Long timer Supporter
    Jun 29, 2013
    2,978
    Woodside CA
    Here you go. In the photo with me pointing at the clearance between the mirror arm and the handguard notice how tight they are as I've installed them. The mirrors don't have a lot of adjustment up and down, so make sure you leave enough room to roll the mirror arm forward to get the view through the mirrors high enough to see down the road behind you. I have the mirrors folded up in the shots, which I also do when riding offroad.
    Crowmoto likes this.
  20. ADVRKD
    ADVRKD Dharma Bum
    Jul 3, 2007
    709
    the empire state
    Touratech lists these for use with the TOURATECH AVENTURO MOD HELMET - https://touratech-usa.com/Store/SCOTT-Hustle-Off-Road-Motorcycle-Goggles
    I have no experience with them, but I may give them a try.
    TT has lowered the price on the aventuro mod helmet. I've had one for two seasons and really like it.
    mosey.levy and I82l8 like this.
