The New Schuberth E1 Finally a True Adventure Helmet
Discussion in 'Equipment' started by GCecchetto, Aug 28, 2015.
  1. Suncoaster
    Suncoaster Long timer Supporter
    Jul 7, 2015
    1,243
    Where the girls are green and the grass is pretty.
    Using the Sena 10U in mine with no problem at all.
    The handlebar control takes a bit of learning.
    I82l8 likes this.
  2. Don Coyote
    Don Coyote Long timer
    Oct 3, 2008
    3,337
    Upper Midwest, US
    Picked up a used Sena10U here for cheap (it is a custom fit for the E1/C3pro). It does a good job with basic hands free phone use. Radio has worked on the few occasions I've tried it. I don't have the handlebar controls and the button controls are difficult to memorize. Haven't tried any intercom stuff. The included speakers are okay, but become hot spots for me on long rides, been meaning to see about digging them bigger holes.
  3. JDB427
    JDB427 Adventurer
    Jan 6, 2016
    47
    UK
    I find the Sena very quiet (but then I do wear ear plugs). I would be interested if anyone has upgraded the speakers on this particular model??
    Also the remote is ridiculously complicated to learn if you don't use it every day.
    Pairing with a GPS phone and a GPS takes a little studying of the manual to get it all to work properly with Garmin.
    Fitting is excellent though!!
  4. kave
    kave Gravel rules
    Mar 26, 2004
    664
    Sweden
    So, I have found another set for the E1, the Schuberth src pro from carda. It seems older than the sc10ua but connects to the built in antenna in the helmet which the newer SC10UA does not. Any recommendations to which to go for?
  5. Ccieurzo
    Ccieurzo Been here awhile
    May 11, 2015
    194
    Cornfields of the Midwest
    There are plusses and minuses to the SRC Pro.
    Plus: Integrated into helmet collar, nothing sticking off the side of the helmet
    Speakers can be upgraded to JBL speakers-sound is quite good
    Phono plug to speakers also allows you to replace them with in ear headphones
    It works well as a comm unit/phone/NAV/radio
    Minus: It is an older unit, no mesh networking or other fancy capabilities.
    JBL speakers require you to compress helmet foam to reduce ear pain
    They seem to be out of production and are getting hard to find new
    Sena used a ribbon cable between battery and control unit that tends to break after the warranty is up. Easy fix though, see:
    https://advrider.com/f/threads/yes-virginia-you-too-can-repair-a-schuberth-src-comm-set.1123484/
    kave and Don Coyote like this.
  6. birdie_xx
    birdie_xx Long timer
    Oct 30, 2004
    1,068
    x
    I prefer Packtalk Bold from Cardo, but I intalled Sena 20S Evo and Sena 30K on my friend's E1s
