The Official Garmin 62 and 78 Thread
Discussion in 'GPS 101 - Which GPS For Me' started by Emmbeedee, Sep 7, 2010.
  1. jules083
    jules083 Long timer Supporter
    Jan 26, 2011
    8,160
    Richmond, Ohio
    So my 78 has apparently lost its citynav. I was in the middle of a trip and running on AA batteries when, after a gas stop, most of the roads disappeared and it stopped routing. I'm home now but can't seem to find my CityNav DVD. Am I screwed? Any ideas?
    Kind of hate to re-buy CityNav, especially on an older GPS like this one. Works fine otherwise though.
  2. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,410
    Near Ottawa, ON, Canada
    Have you tried a factory reset on the 78?
    Here's how:
    To perform a master reset:
    1. Ensure the device is powered off
    2. Press and hold Page and Enter simultaneously
    3. Power on the GPS while continue to press both buttons
      • NOTE: Immediately release the power button once the GPS powers on
    4. Release on the buttons once the Do you really want to erase all user data? message appears
    5. Select Yes
    The GPSMAP 78, 78s, or 78sc is now reset. You will want to leave the device outside with a clear view of the sky for a minimum of 20 minutes to acquire satellite data.
    *User data consists of waypoints, routes, tracks, and geocaches
    Garmin 78 Reset page
  3. jules083
    Jan 26, 2011
    8,160
    Richmond, Ohio
    Didn't work.
    It still doesn't have CityNav, but the waypoints, routes, and tracks seems to be all still on the unit.
    I tried to make it route to a point, it gives me a straight line.
  4. Emmbeedee
    Mar 19, 2008
    11,410
    Have you connected it to a computer yet? I'd do that, and download\install\run Javawa Device Manager on it to see if it finds errors, and can possibly fix them.
  5. mcnut
    mcnut Long timer
    Apr 26, 2006
    1,757
    Bakersfield CA
    Is CNNA still listed on the GPS's map setup page and enabled?
    Does BaseCamp read CNNA from the GPS?
    Might try reseating the chip.
    Bruce
    NomadCape2 likes this.
  6. jules083
    Jan 26, 2011
    8,160
    Richmond, Ohio
    Just tried Javawa. It said that city nav is installed, but there is no map inside the file.
    It's enabled but the GPS won't read it.
    What do you mean by reseat the chip? I'm not using a memory card if that's what you mean.
    I'm about ready to throw this thing in the crick. What's the lifespan on one of these things? Maybe the circuit board has had enough with the vibrations and threw in the towel? 4 years, 40-50k miles since I bought it.
  7. Countdown
    Countdown Long timer
    Oct 20, 2003
    6,933
    Carson City/Ridgecrest
    After reading many of these stories about Downloading Maps, I went with purchasing City Nav map on a memory stick (Memory chip, Micro SD Card). Stick it in and go, If there is a question, just stick the chip in another unit to test.
  8. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    5,167
    MN and NM
    ^ I don't understand. Can you plug a memory stick into these units? I would have thought you would have to transfer the maps to an SD card. Maybe there is a terminology problem here or I am just ignorant of the capabilities of the 62 and 78.
  9. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,564
    Nelson area, Kootenai, BC, Canada
    They take microSD. I'm guessing that Countdown meant to type "memory card" rather than "memory stick".
    SnowMule likes this.
  10. mcnut
    mcnut Long timer
    Apr 26, 2006
    1,757
    Bakersfield CA
    I would call Garmin and explain the issue, see what they have to say.
    If you registered the unit and map with Garmin I don't see why it would be a problem for them to authorize a download. Get a 4 or 8 gig micro SD, and install to the chip and computer. If you never registered the unit or maps then it's on you not Garmin, but they may still work with you. Call and wait, don't email and the 78 is also a marine unit so using that option will likely reduce the wait dramatically.
    As a last resort ask about an out-of-warranty repair. Often for a reasonable amount they will sell a refurbished unit (always like new in my experience) and give you a free CN download.
    Bruce
  11. highcountrymoto
    highcountrymoto Been here awhile
    Feb 22, 2016
    348
    North Carolina
    Alright - I bought the cycoactive hardwire kit and am getting it assembled. One question: The brown and white wires within the large cable bundle are unused and currently just hanging around after getting the pos and neg wires assembled with the inline fuse and ring terminals. What am I supposed to do with these remaining wires? Just tie them up out of the way? Cut them off flush with the end of the large black cable housing?
  12. highcountrymoto
    Feb 22, 2016
    348
    North Carolina
    Here's what I'm working with
  13. Countdown
    Oct 20, 2003
    6,933
    They are the serial port to GPS which no one uses since it has a USB port.
    Do what ever you want with the unused wires. I would cut them short at different lengths and tape over them.
    SnowMule and highcountrymoto like this.
  14. highcountrymoto
    Feb 22, 2016
    348
    North Carolina
  15. gjn201
    gjn201 Wannabe Ranulph
    Jan 10, 2016
    151
    Australia
    Hi,
    I've got a software update notification that I can't get rid off, any ideas? Garmin express says it's up to date. 4.3.
    G.
  16. mcnut
    mcnut Long timer
    Apr 26, 2006
    1,757
    Bakersfield CA
    Which GPS model?
    So you are receiving the software update notification where? On your computer with GPS connected, on the GPS itself?
    I don't remember ever seeing such a notification on the unit itself and not sure how the unit would even know w/o being connected to the internet.
    Bruce
  17. Countdown
    Oct 20, 2003
    6,933
    I keep getting phone calls I can't understand from people in India, bet your problem is not as annoying as that!
  18. gjn201
    Jan 10, 2016
    151
    Australia
    Gpsmap 64 . Found the problem, I had to delete the message in the garmin connect app as it kept sending it to the GPS.
  19. Emmbeedee
    Mar 19, 2008
    11,410
    Ah, the 64 has that unique feature most of us have never seen on our older units.
    Sent using strings and tin cans and Tapatalk.
  20. ChrisP11
    ChrisP11 Adventurer
    Sep 3, 2013
    58
    I've got a Garmin 62 , that I purchased the TOPO download for. It was downloaded from my PC to a mini SD drive, and now resides on my 62. Due to the hardwire issue, I am looking to buy a Garmin 78 for a future TAT trip, but after contacting Garmin, they are telling me my TOPO download will only work on my 62, and I cannot move it over to a new 78? Does this sound right to you guys? Any suggestions?
