The Parts Sourcing Thread
Discussion in 'Some Assembly Required' started by jfman, Jun 16, 2015.
  1. jfman
    jfman Long timer
    Mar 10, 2012
    3,512
    Montreal (traveling Americas June '17 to May '18)
    Hello all. I am trying to find strong weld-in flared fittings for an oil tank (not the AN type) that will use conventional rubber hoses and clamps. I need them to be of a good gauge steel because I am having them welded to a pipe from a crash bar.
    They wont be exposed or anything(weled on the inside) but they cant be wimpy. I want the setup to be strong.
    Do you guyz know where I can find these bits?
    Hopefuly from a place that also sells a lot of other things I might need.
  2. Tenni126
    Tenni126 Been here awhile
    Feb 23, 2011
    101
    Austin, TX
    A quick search turned up a company called AP Air that has that kind of stuff. Never used them, but they have what you're talking about. For other fab stuff, I've used weld tab and their stuff is pretty good. Mostly though, the have just tabs and thread fittings and whatnot.
  3. sailah
    sailah Lampin' it
    Aug 12, 2005
    7,597
    Turning expensive metal into scrap
  4. pilot
    pilot ...
    Dec 23, 2002
    35,914
    Right here
    Having trouble finding that obscure part for your build? Ask here.
  5. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    9,369
    ADVmonster, CFL, WNC
    This could be a valuable resource:deal
    Can we have an index in the first thread?
  6. 81cr450
    81cr450 Been here awhile
    Jul 28, 2011
    100
    Piute ATV trails Utah , Dreaming of Baja
    Need a "cheap" but not junk big single round enduro headlight for my Kninja. Ninja 500 ex in k5 frame. Tried eBay but ,light , brings a million hits that don't get it
  7. sanjoh
    Feb 13, 2007
    9,369
    Sounds like you need work on your google fu:D
    Try this
  8. 81cr450
    Jul 28, 2011
    100
    Sorry should have been clearer. 10" big round single, trail tech makes an 8" $250 for halogen $500 for hid.
    http://www.trailtech.net/1832-100-00
    Thanks for the link sanjoh, duals might have to do
    #8
  9. stickbri
    stickbri Adventurer
    Apr 27, 2014
    28
    Looking for a source for seals for the rear shock seal head on a 1981 honda xr 200r. My first shock rebuild.
    #9
    bluemoon1 likes this.
  10. mach1mustang351
    mach1mustang351 Long timer Supporter
    May 12, 2014
    3,905
    Alaska
    I have been searching on the interwebs and cant find anything quite right. What would be the closest tank for a TZ750 flat track tribute? Any ideas appreciated
    #10
  11. joexr
    joexr Banned
    Jan 4, 2011
    5,021
    Google pix of KR's tracker .
    #11
  12. mach1mustang351
    May 12, 2014
    3,905
    Alaska
    Yeah. Done that. Struggling to find something close available to purchase.
    #12
  13. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,049
    Reading,Pa
    I looked at it, it was a Champion style tank ,larger than average . Interesting question . What chassis are you using ?.
    #13
  14. pennswoodsed
    Jan 20, 2007
    1,049
    Reading,Pa
    [​IMG] Redmax has a large champion tank [​IMG]
    #14
  15. mach1mustang351
    May 12, 2014
    3,905
    Alaska
    I was looking at that tank last night thinking it was a good option. I was having a hard time telling if the shape was right or if the bumble bee pattern on KRs tank was hiding that side angle a bit.
    I have a few irons in the fire on a chassis. I have a friend that is willing to donate an XS650 to the cause, I am also sort of hunting a more proper flat track frame. Im still shopping and when I have enough parts it will become a thread
    #15
  16. pennswoodsed
    Jan 20, 2007
    1,049
    Reading,Pa
    Modified(de tabbed) xs chassis have been used on many street bikes and some racers .There is a strong following and availability of parts, especially west coast . See Mike's xs and many others . several good threads on here also.
    #16
  17. dcmspikes
    dcmspikes Adventurer
    Dec 14, 2013
    34
    costa mesa ca
    Do you guys have any recommendations on LED taillights? They are obviously easy to find, but which ones are good?
    #17
  18. dpforth
    dpforth no inline fours
    Oct 22, 2010
    1,113
    YQQ
    I am happy with this one from UFO
    #18
  19. Foxed101
    Foxed101 Monkeywrench
    Aug 1, 2015
    525
    Holland
    I'm looking for a front wheel for a Cx650 c build.
    Something to resemble the rear wheel (cast 5 spoke star) with roughly the same diameter with tires fitted.
    And with dual brakes.
    [WRONG: The only wheel In those lines so far seems to be out of a '84 cb700sc or a '84 or '85 CB750sc. WRONG]
    Edit: misread my notes. Nighthawks have cast double 3 spokes.
    The candidate is a '83 or '84 CBX750 Horizon front wheel.
    But where to get one?
    Also open for better suggestions :D
    #19
  20. pennswoodsed
    Jan 20, 2007
    1,049
    Reading,Pa
    I like those wheels , I don't think we used Horizon name here . This is on ebay.de Sayonara Cycles ? plentiful here wheel.JPG
    #20
