The Parts Sourcing Thread
Discussion in 'Some Assembly Required' started by jfman, Jun 16, 2015.
  1. Foxed101
    Foxed101 Monkeywrench
    Aug 1, 2015
    525
    Holland
    Thanks! Found Sayonara Cycles, but couldn't find the wheel. What type is it from?
    #21
  2. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,049
    Reading,Pa
    Honda 80s and 90s Vt600 and vt750 , vt1100 maybe some others , also called shadow maybe other names . Looks like plus minus 1984 model years .
    #22
  3. Foxed101
    Aug 1, 2015
    525
    Holland
    Check, I was looking for a 16inch. But 18 would work as well.
    Still have a set of Nighthawk wheels lying around. Let's try the fit of those. The Nighthawk rear is a 16 inch vs the CX 15 inch. Hope the shaft matches. Thanks for the advice!
    #23
  4. jake28
    jake28 Riding to the horizon.
    Mar 4, 2007
    514
    Bay Area, CA
    Hey team, I'm looking for a flat track style down pipe that will fit a Honda XL125.
    A pipe off a 74 XL125, or many CB and SL100s, and 125s would work.
    I'd appreciate a PM if you have one laying around.
    #24
  5. ae86andkp61
    ae86andkp61 Adventurer Supporter
    Apr 25, 2014
    56
    Downtown Portland, OR
    Looking for a fuel tank fitting to connect to lines to feed a frame-mounted non-vacuum petcock (can't reach the petcock if it is mounted on the tank!!) to replace the trashed stock unit on my JDM Suzuki Goose. Two bolts 44mm apart, two tubes to feed the ON and RES inlets on the petcock below, outlets pointing down or downish, just not completely sideways. Current main tube is about 2.75" long and reserve tube is flush, but I am negotiable on these points. I would also consider a petcock I could just leave open all the time, and control fuel with the petcock below. I found a lot of talk of such a beast on the internet, but no specifics like part numbers or a source. Seems kinda close the GS500 parts, but not quite the same. XS650 isn't quite right either!
    FWIW, I can get a new one on eBay for about $165ish plus shipping from overseas, just hoping to find a cheaper/faster source for what is basically a little cast metal slab with two metal straws and a little filter. Thanks in advance!
    #25
  6. pennswoodsed
    Jan 20, 2007
    1,049
    Reading,Pa
    do you have part # from overseas ?
    Looks like standard japanese petcock , is it 44mm on center of the bolts?
    #26
  7. ae86andkp61
    Apr 25, 2014
    56
    I don't have a part number...I would love to find a Japanese-market parts fiche, but no luck on that front yet. The British Goose Owners Club has a decent little parts number list on their website (in English) that includes a lot of the common wear items, spark plugs, brake pads, oil filters, turn signal bulbs, etc. I was hoping cmsnl.com would have a Suzuki Goose listing, but they don't! I find some stuff by searching yahoo japan with SG350N or better yet NK42A, but my Japanese is quite rusty and was quite poor to begin with.
    Here is the lower petcock, shared with the DR800:
    http://www.cmsnl.com/products/cock-assy-fuel_4430044b01/#.VfRowXsZyRs
    Yes, the upper part is 44mm on the center of the two bolts.
    #27
  8. joexr
    joexr Banned
    Jan 4, 2011
    5,021
    Make a new one or ask a handy friend to help make one or your flange could be reused also . Then you'd just need the upper tube . Use 2 inline filters .
    #28
    Mobil1 likes this.
  9. ADVBedouin
    ADVBedouin Been here awhile
    Aug 2, 2009
    775
    CA. Central Coast
    I'm looking for a specific type of clamp, butt-fit type with 2 T-bolts, & it looks exactly like in these pics.
    I need it to cover a 55mm (2 1/4" dia.) pair of butt-fit exhaust pipes (header to slip-on).
    I found this 57mm dia. aluminum clamp from HGV direct in the UK, but I'd prefer to buy it in the U.S. if possible.
    #29
  10. Mobil1
    Mobil1 Long timer
    Jan 12, 2016
    1,837
    Google exhaust band clamps.
    #30
  11. Mobil1
    Mobil1 Long timer
    Jan 12, 2016
    1,837
    Why does it have to have T-bolts.
    #31
  12. ADVBedouin
    Aug 2, 2009
    775
    CA. Central Coast
    It doesn't, but it's the slimmest profile I could find vs the bigger walker clamps
    #32
  13. Ozarkroadrunner
    Ozarkroadrunner Been here awhile
    Apr 12, 2014
    267
    Georgia and Arkansas
    Try Trident Marine on Amazon.com
    #33
    ADVBedouin likes this.
  14. DRjoe
    DRjoe Long timer
    Sep 6, 2007
    7,216
    Sunshine coast qld
    Try searching for "but joint band clamp"
    Summit racing might have what your looking for.
    #34
  15. Hack'dTiger
    Hack'dTiger n00b schn00b
    Nov 7, 2007
    1,428
    Three letter town, OK
    Trying to mount a 9" single LED, to a YZ front end, on a GenI KLR. Does anyone know of a good (affordable) source of clamp that fits the beefy upper section of a YZ/WR fork? They're tapered, and range from 55-58mm on the upper section.
    #35
  16. Hack'dTiger
    Nov 7, 2007
    1,428
    Old post, so you may have found something, but I just stumbled across this awesome thread. I just found a 9" roundie, in LED, if you're still looking. Sounds like we were in similar boats. I'm impressed with it so far, and will definitely require a dimmer with it's 15000lm (150W). :eekers
    Edit for pic link:
    #36
  17. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    7,102
    Mid Wet Or A Gun
    Day dreaming about a winter project.
    Have a low mile 2002 Suzuki 1200 Bandit and not thrilled about its frame and handling.
    Rumors have it the motor will fit early 86, 87, 88 GSXR 1100 frames.
    Had a 87 GSXR 1100 and was thrilled about that one.
    Also have Carbon Fiber wheels on the B12.
    Would rather use newer USD forks.
    Bad plastic/seat is also not a show stopper.
    So...Anyone got a Oil Cooled GSXR with a bad motor ?
    Pacific North West location.
    Cheers !
    #37
  18. kenny robert
    kenny robert Long timer
    Aug 21, 2015
    1,652
    south orygun
    still looking ? i have just the ticket its a vetter
    #38
  19. kenny robert
    Aug 21, 2015
    1,652
    south orygun
    you will probably have to go by the seal dimensions and type but they can usually be sourced
    have you got it apart ?
    #39
  20. dpforth
    dpforth no inline fours
    Oct 22, 2010
    1,113
    YQQ
    I found this, not exactly the style or size you were looking for but it might be a lead.
    #40
