The Parts Sourcing Thread
Discussion in 'Some Assembly Required' started by jfman, Jun 16, 2015.
  1. fireflyr
    fireflyr Dumpster Diver
    Mar 16, 2008
    1,249
    Keene, California
    In the midst of a Marzocchi M1R fork swap on my LM3 and need a pair of brake carrier spacers (7.5mm) to bring the discs out. Front tubes are going from 180mm to 195mm spacing. Thanks.
    7.5mm spacer I’m looking for.
    #61
  2. Malamute
    Malamute Low speed adventurer
    Aug 31, 2018
    710
    Northern Rockies
    Looking for an H-D big twin 58-69 right side only motor case. Also 8 rib knuckle or pan cam cover, pan or earlier shovel cam of moderate lift not requiring head work, distributor (auto-advance for electric start) and its drive gear.
    Would also be interested in STD pan heads for use on shovel cylinders, the outside oiler heads with shovel intake and exhaust flanges.
    #62
  3. Tiz
    Tiz Been here awhile
    Sep 22, 2005
    696
    Milford, CT
    ....So in the process of replacing crank seals I managed to snap a screw off on the clutch boss on my 1986 Yamaha IT200.
    Clutch Boss 43G-16371-00-00
    Part is unavailable. I checked various sites, ebay, general google search - nada.
    Do I give up and part the bike out or is there a solution for this? I swear I was using a torque wrench at the specified 6 NM and it gave out. All the others took that torque.
    --Kevin
    #63
  4. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    8,584
    Phoenix
    that part shows a bunch for sale...
    got a part number or a picture of the broken bolt?
    https://www.ebay.com/p/1523779317
    #64
  5. Malamute
    Aug 31, 2018
    710
    Northern Rockies
    Have you tried to drill it out with a left hand drill bit yet? Or tried a broken screw extractor?
    #65
  6. Tiz
    Sep 22, 2005
    696
    Milford, CT
    Unfortunately all I found were parts listed but "unavailable" from inventory.
    The good news is a beer and some picks helped me back out the busted screw. So now I just need the screw which I think is available.
    Better not ever break that clutch boss.
    Thanks all.
    Had not thought of the LH drill bit but thanks.
    --Kevin
    #66
    Malamute and mach1mustang351 like this.
  7. mach1mustang351
    mach1mustang351 Long timer Supporter
    May 12, 2014
    3,888
    Alaska
    I need a cylinder head for a CB550 SOHC. Mine is a 1975... but I think I read all 500 and 550 are the same.
    thanks
    #67
  8. Malamute
    Aug 31, 2018
    710
    Northern Rockies
    And I never thought about beer. It loosens it up a bit and the pics help turn it out. Cool. :D
    #68
    Tiz likes this.
