The Quota thread
Discussion in 'Moto Bellissima: All Other Dualsports' started by Nessman, Mar 22, 2007.
  1. jetpoweredmonkey
    jetpoweredmonkey Copilot: GSD Sharpe
    Apr 13, 2008
    355
    West Sacramento, CA
    I believe all you would need to change clutch parts is a pilot tool for about five bucks.
  2. auto
    auto Been here awhile
    Feb 6, 2007
    453
    south jersey
    There is a splined centering plug that is needed to align the plates.When I did mine,took the motor to a shop and they lined things up. The trans slipped right in then.
  3. ClintToris
    ClintToris Adventurer
    Aug 6, 2019
    19
    Tampa
    Thanks guys,
    I believe these are the same thing (referring to the pics I posted). I guess you can buy a fancy one for $68 or try and make my own. I read all the big twins share the same parts for over 40 years (that's quite nice of them). I guess I'll order the parts and take a trip to the hardware store. Should be interesting tearing it all apart. Screenshot_20190928-114737_Chrome.png
  4. khristopher
    khristopher Adventurer
    Jan 7, 2015
    88
    Durham, NC
  5. Blueboarhound
    Blueboarhound Adventurer
    Sep 30, 2013
    64
    South Central Pennsylvania
  6. usedtobefast
    usedtobefast Been here awhile
    Nov 12, 2007
    277
    SF Bay Area
    Wow, two Quotas in one trip! Great job.
  7. usedtobefast
    Nov 12, 2007
    277
    SF Bay Area
    So I've put ~1000 miles on my new to me Quota now. What a wonderful motorcycle! A bit strange that I like it better than my Racer or my Griso!
    At first I was all worried about everything ... then I gave up the worrying and have just been riding. Yes it leaks a bit of oil. And I have no idea if all the venting hose stuff is dumping rust into my engine. And I can't reset my trip meter. One day I'll get back to all that. :-)
    The new Avon tires have been great. I bought a Hepco & Becker top case for it ... then found out the stock Quota rack is not a Hepco & Becker compatible rack ... then ordered an adapter plate ... so now I have mounted up. Oh, and new grips.
    So I'm about ready to try a multi day trip on the Q ... gotta wait for the Northern CA weather conditions to get better and then head out. Might go the SLO direction.
    Mr. Vintage likes this.
  8. auto
    Feb 6, 2007
    453
    south jersey
    A bit of a end of the season ride with my son.Went up top Sandy Hook state park NJ IMG_7697[1].JPG . Little chilly on the ride home
  9. HighwayChile
    HighwayChile greetings from Wa state
    Aug 19, 2003
    5,001
    Bow, WA USA
    ive had to work so not much Q time. that will change next year.
  10. Garry H
    Garry H Been here awhile
    May 19, 2008
    262
    I have got a Quota 1100ES and am looking for some ECU maps
    Not sure if mine has been updated or not
    Anybody got any they could mail me ?
  11. chain
    chain Go Fly Supporter
    Aug 28, 2002
    4,829
    Central IL
    Cleaning out my garage
    I found some GQ stuff...
    Owners manual
    NIB RH mirror
    Tool kit
    anyone need this stuff ?
  12. Gravelthinking
    Gravelthinking Adventurer
    Jul 30, 2018
    44
    Bloomington IN
    How much you asking for? I'm interested.
  13. chain
    Aug 28, 2002
    4,829
    Central IL
    Sold
  14. asquaredgray
    asquaredgray Adventurer
    May 19, 2018
    38
    Portland
    Anyone ever do a deep water crossing with your Q? Any issues with submerging the alternator? I would expect it to be fine. There are no bearings to muss, etc.
    I’m planning to ride the southern sections of the NVBDR next spring, and I’m reading that there can be some water crossings, depending on weather.
  15. auto
    Feb 6, 2007
    453
    south jersey
    really no difference than any ignition/alternate hanging on the end of the crank of any dirt bike. Do your best to seal it up and a good coating of WD40 before you go and you should be fine.
  16. asquaredgray
    May 19, 2018
    38
    Portland
    On most dirt bikes, isn’t it sealed inside the case behind a cover with a gasket? The MG alternator covers seem purposely designed to vent the works. I would be concerned that sealing it might be bad for the 99.99% of time that it’s not under water. Might be overthinking it, of course. I’m prone to that. :-)
    I had read previously on some Jeep forums that alternators survived submersion functionally, but the real issues were from washing grease out of bearings and leaving dirt in its place. Since there are no bearings when it’s just hanging off the end of the shaft, that wouldn’t be an issue for the Q. Which leads me to the tentative conclusion that it’s ok to submerge it.
  17. Mr. Vintage
    Mr. Vintage Family Dude Supporter
    Jan 19, 2007
    1,060
    The Palouse
    I'm on board with your conclusion, although I may have to study the housing next time I'm in the garage. Seems like as long as the water can get back out you'd be fine.
    Do you have a sump guard of some sort? That would be my greater concern with my Q - I have dorked it on rocks before, and they weren't even hidden underwater.
  18. auto
    Feb 6, 2007
    453
    south jersey
    Then why did you ask? The alternator sits pretty high,I would be more concerned with water getting into the rear if the water is that deep.
  19. asquaredgray
    May 19, 2018
    38
    Portland
    Noting exists, yet. I’ve got a couple of leads locally to potentially custom fab a sump guard. I’ve bent the center stand on a rock before but managed to avoid banging the sump so far. Probably can’t continue to count on that luck, though. :-)
  20. asquaredgray
    May 19, 2018
    38
    Portland
    I asked because, as noted, it’s a “tentative” conclusion. I’m looking for other peoples’ experience, for a reality check. Thanks for your thoughts.
