The tipping point is right around the corner.
Discussion in 'Shiny Things' started by MJSfoto1956, Dec 26, 2018.
  1. T.S.Zarathustra
    T.S.Zarathustra Been here awhile
    Apr 26, 2018
    388
    krautman likes this.
  2. liberpolly
    liberpolly Nu, shoyn, nudnick!
    Sep 21, 2015
    5,881
    Seattle
    Wow! Have someone told Tesla engineers?
  3. thumpism
    thumpism Between bikes
    Dec 16, 2005
    6,190
    Richmond, Virginia
    That's already being tested on UPS trucks, is it not?
  4. ninjamunky
    ninjamunky ¡Que buenos son! Supporter
    Sep 30, 2013
    8,258
    Flavortown, OH
    It's already been done anyway. Tata Motors has had an air powered prototype car out for years now, I don't think they've actually sold any of them though. The top speed is like 65km/h and the range is not great.
    Plus according to wiki the efficiency is even worse than ICE, which is pretty impressive considering how bad the efficiency of internal combustion is.
    https://en.m.wikipedia.org/wiki/Compressed_air_car
  5. T.S.Zarathustra
    Apr 26, 2018
    388
  6. liberpolly
    Sep 21, 2015
    5,881
    Seattle
    I'd like to see some math. Sounds totally implausible.
  7. T.S.Zarathustra
    Apr 26, 2018
    388
  8. NikonsAndVStroms
    NikonsAndVStroms Beastly Photographer
    Jun 23, 2007
    73,776
    The Hub of the Universe
    But what's the energy density for compressed air? It might work for a light weight low power vehicle but how large of a tank would you need to get 300 miles in a 2500+lb car that can keep up with traffic?
    Edit: Also for consistent performance you'd want a constant pressure system which would add more size/weight.
  9. liberpolly
    Sep 21, 2015
    5,881
    Seattle
    How long and how fast will the quadrupled Tata go?
    Also, you keep using this word, "algebra", it does not mean what you think it means.
  10. Andrew
    Andrew Optimus Primer Administrator Super Moderator
    Sep 25, 2001
    23,731
    Eastbania
    Lightsail Energy (a defunct startup in Berkeley) promised efficient storage of energy as compressed air, but utterly failed to deliver. Some bits of the story:
    https://en.wikipedia.org/wiki/LightSail_Energy
    https://www.greentechmedia.com/arti...ergy-cheap-compressed-air-storage-hibernation
    https://www.greentechmedia.com/squa...e-failure-of-the-founder-narrative#gs.n=k=9qI
    victor441 likes this.
  11. T.S.Zarathustra
    Apr 26, 2018
    388
  12. ninjamunky
    Sep 30, 2013
    8,258
    Flavortown, OH
    According to the Wiki article I linked earlier it's not a lot compared to gas and lithium ion batteries.
    Compressed air has relatively low energy density. Air at 30 MPa (about 4,350 psi) contains about 50 Wh of energy per liter (and normally weighs 372 g per liter).[citation needed] For comparison, a lead–acid battery contains 60-75 Wh/l. A lithium-ion battery contains about 250-620 Wh/l. The EPA estimates the energy density of gasoline at 8,890 Wh/l;[1] however, a typical gasoline engine with 18% efficiency can only recover the equivalent of 1694 Wh/l. The energy density of a compressed air system can be more than doubled if the air is heated prior to expansion.
    In order to increase energy density, some systems may use gases that can be liquified or solidified. "CO2 offers far greater compressibility than air when it transitions from gaseous to supercritical form."[2]
    NikonsAndVStroms likes this.
  13. liberpolly
    Sep 21, 2015
    5,881
    Seattle
    do show us the math.
  14. Cromoth
    Cromoth fan of the magic carpet ride
    Aug 24, 2010
    1,219
    MA
  15. dirt hokie
    dirt hokie Long timer
    Oct 3, 2007
    2,296
    Eastern shore of MD
    you guy are really missing the the "best" way. Just make cars sail powered. Problem solved...
    Really its all about energy density and efficiency. Right now nothing on the market can compare fossil fuel for energy density, so the alternatives must beat the hell out of IC in efficiency to have a chance, and right now, they cant.
    Compressed air is not a bad idea, it just suffers the same problems as the other alternates.
    T.S.Zarathustra and magnussonh like this.
  16. CodeMonkee
    CodeMonkee Geek Adventurer
    Jul 26, 2001
    7,340
    Orygun
  17. T.S.Zarathustra
    Apr 26, 2018
    388
  18. CodeMonkee
    Jul 26, 2001
    7,340
    Orygun
    Yeah - of all of the 'breakthroughs' in battery tech I do not recall many of them actually making it to market. But then that isn't my domain.
  19. iflysideways
    iflysideways Been here awhile
    Oct 31, 2016
    101
    Delaware
    Maybe some element 115 tech might be the answer? Those pesky UFOs the USN had on hud video had no heat signature, not too much if any wasted energy. Looked like fun as a bonus.
  20. DCrider
    DCrider Live from THE Hill
    May 7, 2008
    8,307
    Washington, DC
