The Toolkit Thread
Discussion in 'Equipment' started by hilslamer, Sep 2, 2007.
  1. darren70
    darren70 Loud pipes matter
    Sep 11, 2013
    3,791
    Hunter Valley
    My wr toolkit
    On big rides i add a front tube and two Ballards tyre levers and a lightweight axle spaner
    No fancy kits here
  2. team ftb
    team ftb Befuddled Adventurer
    Mar 15, 2006
    2,392
    Lost in the jungles of Thailand
    Like you Sprouty I have had great luck with most of my Motion Pro purchases. T6 tire spoon, fork cap tools etc. However the Motion Pro Metric all in one tool pictured below failed;
    The 1/4" driver that inserts into the handle is comprised of three separate pieces that during manufacturing are glued and pressed together. I used mine in the garage for a couple weeks to make sure it worled reliably and accessed everything I needed. It was reliable during the two weeks. First trail ride with it and had a leaking water pump. Went to synch up the bolts on the cover and the driver pieces separated which kept the driver from being able to tighten the bolt.
    Here's a quick Video demonstrating the failure:
    I ended up getting the 3 pieces that comprise the driver portion of the tool welded together and ground down.
    This fixed the tool and it worked fine for a couple years after that. I talked with Motion Pro and found out that this is a problem that has happened faar too often on this tool sadly. So if you rely on this tool I would recommend welding it as I did above to keep the tool reliable and keep it from failing in the field.
    jackbyo likes this.
  3. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    8,591
    Providence, RI
    Yeah, that looks like a marginal design. Unfortunate that they had issue and it didn't get resolved.
  4. LWC3077
    LWC3077 Been here awhile
    Apr 4, 2014
    138
    South Australia
    Thanks for your answers but can you please tell me the part number because i cant actually fully read it on the photo. I got the MP multi tool but never really used it. Now i am reading about all the failures. Think i will keep it out of bike tool kit for sure.
  5. team ftb
    Mar 15, 2006
    2,392
    Haha i was hoping you could see the numbers as my failing eyes could not ID it correctly.
    Good thing about having a younger girlfriend is aside from their ass still being perky the eyes continue to perform. According to her the model number is GTV830. Though even she had difficulty, so not 100 percent it's correct. However let's hope that works for you.
    Regarding the Motion Pro tool it works fine once you get the driver TIG welded. I used it for a long time and just outfitted it with the sockets I needed and a few optional Hex key bits Motion Pro offers. Here in my palm using it to remove a side case on the ole KTM when I drowned it in the river and the drain bolt was stripped.
    Simple and reliable once welded. However since doing my own kit as shown above I am much happier on the trail and in the garage.
    Sent from my SM-G900F using Tapatalk
  6. team ftb
    Mar 15, 2006
    2,392
    Excuse me the correct part number on the Snap-on above is GTM 830
  7. resqdoc
    resqdoc Been here awhile
    May 8, 2010
    382
    The Last Best Place
    :drink
    Very interesting engineering. They have a similar bit driver.
    They include a bottle opener! :drink
  8. phreakingeek
    phreakingeek Big Ear Inc - Virginia Provider Super Supporter
    Sep 17, 2010
    2,457
    VA
    I drove the section of road in the jeep with my wife riding shotgun to look for it...never saw it. Someone probably found it, but without my info inside, I'm not hopeful in getting it back. Aside from the $200 saddlebag, I lost my air compressor, hand tool kit, leatherman, battery jump starter, and the only name brand 'North Face' hoodie I've ever owned....gift from my dad.
    Just ordered a stack of 'business cards' printed on plastic to put in all my gear. I figure for the $30, it'll be something I can toss inside every bag I pack and it will have name, number, email. Also, when i run into someone and get a pic or they take a pic, I can give them a card to contact me later.
    No affiliation and cant comment on quality yet, due to arrive in a week or so...but this is where I ordered from:
    http://www.morningprint.com/product2/card.php?acode=75
    JimVonBaden, jonnyc21 and portabill like this.
  9. resqdoc
    May 8, 2010
    382
    The Last Best Place
    I like the rounded corners.
    I don't know about you guys but normally I have a number of fund raiser type address labels sent by Rocky Mtn Elk Foundation, American Legion, NRA or what not. They make fine identifiers for individual hard sided items like cameras, suit cases, etc.
    On Oct 14, 2016 10:44 AM, "Adventure Rider"
    Lutz likes this.
  10. Mercury264
    Mercury264 Once you go Triple...
    Nov 7, 2005
    25,580
    Masshole
    Holee crap, what a great idea...I have shit tons of those labels lying around :clap
  11. Bengt Phorks
    Bengt Phorks Been here awhile
    Sep 20, 2012
    471
    Nail polish bottles work best and are practically industructable. They come in all sizes and even have a brush inside. Find the size you like, clean it out with Acetone, and fill it with glue. Steal some from your wife or girlfriend. I like to use the small square bottles.
    I carry 2 bottles 1 with the patch glue and the other one with some rubber solvent to clean the patch area on the tire or tube. Naptha is a rubber solvent and
    it can be purchased almost everywhere in a cleverly disguised can called Coleman fuel.
    I use 2 inch radial tire patches for tube and tire repairs because they are strong and can cover a large hole or multiple holes.
  12. Desertskyy
    Desertskyy Always looking for an adventure
    Mar 25, 2007
    281
    So Cal-Ventura County
    I lost the tool bag off the back of my bike this last April. I confirmed that it was picked up when I went back to look for it when talking with someone on the side of the trail. Had my name, address, registration and my insurance info etc. Never heard another word. Took years to build that tool kit. I fixed many bikes and changed many tires on the side of the trail with that kit. I lost about $300 in parts, tools, tow rope etc.
    My new kit is coming along. Probably will never be as good as my old tool kit though
    Got to love how honest people are.
  13. DualMule
    DualMule Been here awhile
    Aug 17, 2010
    627
    Town of Beans
    Many won't return tools, but if you don't have contact information they can't.
    I lost my wallet with $80 in it at a drug store. Someone found it and turned it in to the store, which used my DL and a business card to confirm ownership and contact me. I didn't expect the cash to be in it, but it was.
    Maybe the crows are running off with those shiny tools :-)
    Macho Man2 likes this.
  14. Juan Valderrama
    Juan Valderrama Been here awhile
    Sep 22, 2013
    416
    Bogotá Colombia
    Hola, I made this video (sorry is in Spanish but it is self explanatory) on making a tool kit for a KTM 450 RALLY REPLICA. It's a racing bike and the tools are focused on the race. The motorcycle runs on mooses. The pilot has plenty of rally experience.
    I hope you like it!
    Broadcasting from Bogotá, Colombia.
    YouTube: https://m.youtube.com/c/TallerValderrama
    Facebook: https://m.facebook.com/eltallervalderrama/
    keepshoveling likes this.
  15. jackbyo
    jackbyo @sunnysideup_mc
    Mar 6, 2015
    402
    Sydney
    I know a few folks on here use the chapman tools. I'm thinking of picking up a set and using it as the base of my minimalist toolkit
    Only downside, is that I do like ball head allen bit, which chapman doesn't have... I think might be worth compromising though
    I like the look of the spinner for tight spots, and that you can attach the screwdriver handle/ratchet/extension at the same time.
    The motorcycle set might be in my future
  16. Sitheach86
    Sitheach86 Long timer
    Jan 21, 2016
    3,281
    San Antonio, TX
  17. jackbyo
    Mar 6, 2015
    402
    Sydney
    So I lost my tool roll last week on the trail... bummer, but means I had the excuse to buy all the shit I actually want. Chapman set is on the way, and look what just arrived from Japan!
    These spanners are awesome!
    I bought them individually in these sizes
    • 8mm x 10mm
    • 13mm x 17mm
    • 12mm x 14mm
    FYI: Yes, you can buy the full set of 6 on ebay for about $90, but it doesnt include these combinations! The full set includes redundant sizes like 11x12 and 14x15
    Quality is very nice
    Juan Valderrama likes this.
  18. sprouty115
    May 29, 2012
    8,591
    Providence, RI
    Very interesting. Who makes them?
  19. Smackit
    Smackit Life Is Good Supporter
    Jun 5, 2007
    1,185
    Reno, Nevada & Guangdong China
    Ah yes, my beloved Asahi Lightools... 6 years since I posted, still love them, can't beleive I only paid $25 for the set.
  20. jackbyo
    Mar 6, 2015
    402
    Sydney
    A Japanese tool brand called Asahi. I bought them here
    http://global.rakuten.com/en/store/i-tools/item/341446/
    Scroll down a bit to "electric car" (??) and you can see all the other size combinations.
    A bit of pertinent info from the website
    Features(Lai tools spanner) x little
    -Niigata-Made in Japan-
    -Traditional spanner 25% to 50% lighter than was.
    -Very high quality at the new JIS get the intensity is even better.
    -In chrome-plated specifications look great, fit is excellent.
    -The spanner, Cartman is easy to use in tight spaces.
    -Groove spanner but the flying is possible.
    -Lighter to carry tools for the prevention of low back pain is effective.
    -Over spanner in the conventional sense tempting mortal is a design.
