The Toolkit Thread
Discussion in 'Equipment' started by hilslamer, Sep 2, 2007.
  1. boulet_boulet
    boulet_boulet Long timer
    May 14, 2018
    2,068
    Maine
    Baroquenride, Kinsman and NC1959 like this.
  2. mslim
    mslim Long timer
    Jan 11, 2015
    1,804
    Austin of the Ozarks
    If you're buying new... seriously consider ponying up for Grip-Ons instead of the Irwin off-shore Vise-Grips.
  3. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    8,586
    Providence, RI
  4. Oddfellow
    Oddfellow Beasty Rider Supporter
    Aug 26, 2002
    1,039
    Austin, Texas
    Those are only on-shore if you live in Spain, follow the links! I do like the epoxy and the color though!
    9Realms likes this.
  5. mslim
    mslim Long timer
    Jan 11, 2015
    1,804
    Also available from Snap-On in a different color and only a couple of bucks more but yes, as you say, Made in Spain, (not that there's anything wrong with that) and certainly preferable to the Asian alternative Irwin is using.
    Oddfellow likes this.
  6. sprouty115
    May 29, 2012
    8,586
    Providence, RI
    A Snap On tool for $27? That's insane - I may have to buy three!
    RustySpokes likes this.
  7. 9mm
    9mm Been here awhile
    Apr 18, 2006
    694
    "Southeast of Disorder"
    Ah geez
    First we got a woman only topic
    Then looking good while camping
    Now we got accent color tools
    Oh brother
  8. JimVonBaden
    Feb 11, 2005
    96,037
    Alexandria, VA
    Sounds like your manhood is being threatened. :deal
    Dumphead, 9mm and Oddfellow like this.
  9. Andylaser
    Andylaser Heavy Metal
    Feb 17, 2011
    2,072
    Southampton UK
    Regarding the Wera extension bar with the "wobble function".
    Once you have fitted the socket, you can push down on it and lock it tighter to the bar. This removes the ability for it to wobble.
    SmittyBlackstone, 4serge and nzrian like this.
  10. sprouty115
    May 29, 2012
    8,586
    Providence, RI
    Yes, good point- I forgot to mention that.
    BTW, when I first used it I didn't think it would be much of "useful feature". But as it turns out it's perfect for removing the valve cover bolts on my 690 - one bolt is located in a spot that requires an extension but also a universal (which doesn't fit). So the wobble extension works perfectly.
  11. Rectaltronics
    Rectaltronics Barned
    May 29, 2008
    21,698
    New York F'ing City
    Well, he is only 9mm, after all...
    I think no manly-man's murdersickle toolkit is complete without a nice Hi Point .45 in pink camo...
    https://www.sportsmansoutdoorsuperstore.com/products2.cfm/ID/173622
    Perfect for when you're caught out in the wilderness of a Victoria's Secret.
  12. Bengt Phorks
    Bengt Phorks Been here awhile
    Sep 20, 2012
    471
    I used cables like that for years to keep sticks and weeds from jamming into the rear brake pedal and shift lever.
    I attached the cables to the frame instead of the skid plate.
  13. Bengt Phorks
    Sep 20, 2012
    471
    SmittyBlackstone and dsilver1007 like this.
  14. Bill 310
    Bill 310 Poser Emeritus Super Supporter
    Dec 4, 2002
    5,695
    Slip 35
    Mine just arrived, first rate all around
    I ordered 2 more pair one for each bike's kit
    mslim likes this.
  15. 4serge
    4serge +
    Oct 19, 2007
    147
    Phoenix, AZ
    Motion Pro sells similar extension with a spark plug socket.
    SmittyBlackstone likes this.
  16. team ftb
    team ftb Befuddled Adventurer
    Mar 15, 2006
    2,383
    Lost in the jungles of Thailand
    I use a 3in wobble extension. One has to keep in mind though and be aware that what enables the extension to wobble is that where the socket slots onto is tapered, this will have it lose some strength in theory to a normal extension. Just an FYI for any of those that aren't familiar with wobble extensions.
  17. deguoren
    deguoren 该出手时就出手
    Jan 3, 2011
    284
    big freezer Germany
    I found a very nice folding T handle driver for 3/8, 1/4 and 1/2 sockets. Unfortunately its a bit large for my toolkit (250mm length)
    Is there anything similar but smaller on the market?? Something between this and a Tusk Folding Mini T-Handle in size and functionality?
    Andrew and SmittyBlackstone like this.
  18. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    16,147
    SF Bay Area
    How many times do you need a 1/2" drive for your on bike tool kit? Use a 6" 3/8" drive sliding T handle matched with a 6" 3/8 drive wobbly extension. If you don't want to buy a handful of 3/8" sockets because you already own 1/4" versions throw in a 3/8" to 1/4" drive adaptor. Ratcheting palm drive is optional. You're done.
    If you ride a Japanese bike you may be fine using only 1/4" drive. That's what I keep on my DR650.
  19. deguoren
    deguoren 该出手时就出手
    Jan 3, 2011
    284
    big freezer Germany
    I use 3/8" with adapters now, and yes I need 1/2" for wheel removal. A 1/4" drive on the end of the sliding handle would already eliminate one adapter from the toolkit and reduce the "wobbling"
  20. TigerDude
    TigerDude Adventurer
    Jul 21, 2015
    20
    Acworth GA USA
    A simple t handle with an extension works. I have a KTC T & extension set that came with my moto kit, 3/8". They fit together nicely in a tool pocket. The kit comes with 8,10,12,14 semi-deep sockets.
