The Toolkit Thread
Discussion in 'Equipment' started by hilslamer, Sep 2, 2007.
  1. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    5,547
    Pennsylvania, but living in a toy hauler full-time
    Thanks I found them on Amazon a little cheaper.
  2. CavReconSGT
    CavReconSGT Just the right amount of evil. Supporter
    Jul 7, 2011
    1,818
    CT/NH
    Found a new addition to my toolkit. Nice sharp knurling helps keep the grip even when hands are sweaty/greasy.
    This screwdriver:
    It uses the standard type bits and also has flats to so it can be used with a 17mm wrench.
    From burredgemetalworks
    https://www.facebook.com/BurrEdgeMetalworks/
  3. rokytnji
    rokytnji Been here awhile
    Oct 9, 2018
    584
    Pecos Texas
    One of mine
    Carried on my belt.
  4. Fixnfly
    Fixnfly Not found on the book of faces
    Feb 28, 2008
    2,163
    SWPA
    I have a stupid question...
    Can a spark plug fail immediately or would it give plenty of warning to be replaced before a breakdown?
  5. phreakingeek
    phreakingeek Big Ear Inc - Virginia Provider Super Supporter
    Sep 17, 2010
    2,386
    VA
    It depends on the bike...but they can 'foul' with excess fuel or carbon and cause them to stop working. Typically though, you have some sort of warning that it's not running right before that happens.
    SmittyBlackstone likes this.
  6. Fixnfly
    Feb 28, 2008
    2,163
    SWPA
    So a good running bike that does not burn oil or run rich should not have a plug problem?
    The reason I ask is that I have always kept properly gaped plugs in my bikes and replaced them every few years, I was wondering if it were possible that a plug could just fail without any warning .
  7. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    8,514
    Providence, RI
    Yes, a plug can fail. A plug can crack from a shock (cold water), vibration, etc. It's not very common, but it can happen.
  8. dmmacfarlane
    dmmacfarlane Adventurer
    Sep 21, 2011
    31
  9. dmmacfarlane
    Sep 21, 2011
    31
    I need some help with the master cylinder cap removal tool ... or a length of string? The string is a suitable substitute? Confused. Thanks.
  10. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    15,812
    SF Bay Area
    I bent a wire coat hanger to make a tool.
  11. Johnny4x4
    Johnny4x4 Hope 2 B Cool Sumday Supporter
    Nov 15, 2010
    856
    West Valley City, Utah
    I think this is one of the most important tools in my set.
    I have a jeep and I go rock crawling quite often. one day while crawling, I had a precarious rock smash against and crack a rear brake line. I ended up using my vice grips to crimp and roll the end of the tube a few times and then clamp it so I had "some" brakes to get back down the mountain. It would have been quite a challenge to work a brake and clutch pedal while steering and shifting gears along with the hand throttle.
    I have used them as an extra tie down point, a clamp, a hammer, a pot handle, a crimper, a wire cutter, a button setter, a grommet setter, and as weight to keep a tarp down on a breezy day.
    Just my $0.02, buy good ones in various sizes, stay away from the Harbor Freight ones, you can actually miss-align the jaws by twisting0 a skid plate back into place.
  12. sprouty115
    May 29, 2012
    8,514
    Providence, RI
    At this point, based on what I've read here I don't believe there is anything they can't do...
  13. Renegade6
    Renegade6 Been here awhile
    Feb 23, 2004
    856
    New Boston, TX
    9Realms and SmittyBlackstone like this.
  14. JimVonBaden
    Feb 11, 2005
    95,566
    Alexandria, VA
    If you have strong fingers you can just squeeze the tabs. If not, a length of fishing line wrapped around it works.
  15. ennui
    ennui Been here awhile
    Mar 13, 2019
    122
    z
    SmittyBlackstone and Renegade6 like this.
  16. RustySpokes
    RustySpokes Ordinary average guy Supporter
    May 13, 2004
    2,099
    Between here and there.
    0141AB90-E6D8-49D1-A115-877A6737B2DD.jpeg 36643386-82E3-4730-9908-386D603111A0.jpeg Behold the holy grail of tool kit screwdrivers, unfortunately now discontinued.
    Six blades, three Phillips, three straight blade, all store in the handle so they won’t poke holes in a tool bag or a person. The blades are held captive so you can’t lose them and have normal size shafts so they fit in places those big fat multi tip jobs won’t.
    I gave these away as Christmas presents for a number of years and everybody loved them. I don’t understand why they aren’t available anymore.
  17. Renegade6
    Feb 23, 2004
    856
    New Boston, TX
    I went with this one because of the weight.
  18. dmmacfarlane
    Sep 21, 2011
    31
    Thanks, Jim. Now I see how that works.
    SmittyBlackstone and JimVonBaden like this.
  19. Dread_lion
    Dread_lion Been here awhile
    Jun 8, 2013
    400
    Antwerp, Belgium
    for the people who bought the asahi lightweight spanner sets, can you tell me why you havent bought the thin ones instead?
    They are actually in some cases lighter than their lightweight counterparts, and the set is about half the price of the lightweight one too. Am i missing something here? Just really curious by the way, not trying to sound smart. that they are thinner, should be a good thing i would think, that way you might be able to squeeze them into parts where you sometimes cant.
    https://www.fine-tools.com/thin-spanners.html
    tonyubsdell and SmittyBlackstone like this.
  20. ThorCT
    ThorCT Lets Ride Supporter
    Mar 20, 2008
    337
    Hotlanta
    For me it was because I want the box end part. Gripping from all sides is way more secure than just two.
    Also, of the 12 bikes I have I’ve never needed a thin wrench to do any maint. or more complex breakdown on any of them. A thicker tool gives more contact area so less likely to slip and damage the fastener.
